Un equal weight connecting rod will creat problem?
In summary: I replaced the rod with one that is 100gm greater than the original because the supplier had modified their specs to Euro norms, and the old rod was no longer available.After working 100 odd hours, the engine failed. After dismantling the engine it was found, the oil pump found failed and metal particles found in the sump.Is it possible that the unequal connecting rods would have generated unbalenced dynamics in the engine and made the crank shaft bearings or con. bearing wear faster or make it fail?Yes, it's possible that the unequal connecting rods would have generated unbalenced dynamics in the engine and made the crank shaft bearings or con. bearing wear faster or make it fail. 100
sivam50
Hi..all. I have replaced a connecting rod against a failed one (in a 10 piston Benz engine) which is 100 GM lesser than original one since the supplier has modified to Euro norms and old rod no more availble. Now after woking 100 odd hours, the engine failed. After dismantling the engine it was found, the oil pump found failed and metal particles found in the sump. Is it possible that the unequal connecting rods would have generated unbalenced dynamics in the engine and made the crank shaft bearings or con. bearing wear faster or make it fail?
Sorry for the common man language!
I don't know the answer to the question although I have ran my Honda engine with forged rods that are heavier than OEM spec and all seemed fine. Just my experience.
Well you'll certainly get a vibration with unbalanced rods (ie one of them being significantly lighter than the others). Depends what the metal shavings are, and where they came from. 100 hours seems low for any engine, I'd put my money on the new rod being the cause of the engine failing.
It could just be coincidence though, it's too hard to tell from what you said.
Traditional Quality Control standards state that connecting rod weight must not vary more than 9 grams in any given engine. That stated, you have a situation that is ten times over the normal proven process. Question - how many cylinders is the engine?
You really need to figure out what the failure sequence was. Did something in the crank case break up and metal chips blocked the oil supply and/or wrecked the oil pump, or did the pump fail first and the engine then failed (and wrecked a bearing) through lack of oil?
Whatever, thinking about it from first principles, having different mass rods on cylinders with the same crank angle is going to cause unbalanced loads that the crank was not designed for. Whether you would get away with sets of different mass rods at different angles is not so obvious. It might lead to torsional vibration problems, for example.
100 grams is almost a quarter pound. On something that is making 4-8000 strokes per minute (up and down strokes) that is going to create one hell of a problem. Now, you say that the oil pump failed? That's it? You found metal shavings, but nothing broken or excessively worn?
While the weight difference will cause an imbalance and a vibration, it's highly unlikely that it caused the oil pump or the bearings to fail. The usual vibration induced failure is a cracked or broken part and bearings don't tend to fail unless the crank fails first, and even then I've seen bearings in good condition on either side of the break.
Not aligning the pump so that the shaft and gears don't bind when rebuilding some Mercedes engines certainly will cause it to fail however.
I would have thought binding would lead to instadeath of the box when you tried to put torque thought it.
I think this will remain a mystery until there is a strip down. Would be intersting to see pictures.
Depends how severe the bind is; on my old 617 diesel it was enough to be noticable but not locked up before I adjusted it. If it had been left as it was it would have resulted in excess wear and likely eventual failure.
I had disassembled it to check clearances and wear and didn't quite have things in line. After the adjustment it spun smoothly and freely.
You're right, I'd like to see some pictures too!
I'm guessing one per piston, which would mean 10. (See bracketed section of the second sentence of original post.) :wink:
Unless you own a 60's-70's Mopar 440. :rolleyes:
They really don't like to oil the #4 rod bearing properly, and the results can be catastrophic. Been there, done that. Either Ranger or Stingray (sorry that I can't remember who) gave me a great link to a preventative manoeuvre involving some minor surgery. It was too late for me, but I now know why it went pear-shaped and can advise others.
I agree, however, that 100 gm is a horrific mismatch. I was never anywhere nearly as competitive as Ranger or Stingray or Hypatia, but my piston/rod combos were balanced within a gram of each other.
Danger...I doubt the non balance thing led to catastrophic melt down..prob assembly situation..like maybe fatigued con rod bolt..or oiling..like we figured out with external plumbing cure a while back..
Happy New Year..fellow mopar fiend
1. What is an unequal weight connecting rod?
An unequal weight connecting rod is a component of an engine that connects the piston to the crankshaft. It is responsible for transferring the up-and-down motion of the piston into the rotational motion of the crankshaft. The weight of the connecting rod plays a crucial role in the smooth operation of the engine.
2. How does an unequal weight connecting rod affect engine performance?
An unequal weight connecting rod can cause several problems in engine performance. It can lead to vibrations, increased friction, and uneven wear on the engine components. This can result in reduced power output, decreased fuel efficiency, and potential engine damage over time.
3. What are the common signs of a problem with an unequal weight connecting rod?
Some common signs of a problem with an unequal weight connecting rod include unusual vibrations or noises from the engine, decreased power or acceleration, and difficulty starting the engine. It is essential to address these symptoms promptly to prevent further damage to the engine.
4. Can an unequal weight connecting rod be fixed?
In some cases, an unequal weight connecting rod can be adjusted or balanced to improve engine performance. However, if the difference in weight between the connecting rods is significant, it may be necessary to replace the connecting rod entirely to ensure proper functioning of the engine.
5. How can I prevent problems with an unequal weight connecting rod?
The best way to prevent problems with an unequal weight connecting rod is to ensure proper maintenance of your engine. Regularly check and balance the connecting rods, and address any unusual vibrations or sounds from the engine promptly. It is also essential to use high-quality, properly sized connecting rods to prevent issues.
  • Mechanical Engineering
13K
11K
21K
  • General Engineering
  • STEM Academic Advising
