DEFINITE integral of sinaxsinbx FROM 0 to infinity
In summary, the conversation discusses a person's difficulty in finding a solution to a PDE question and their professor's unhelpful response. Another integral question is also mentioned and the conversation ends with a potential formula for finding the solution, with the limitation of being unable to evaluate it for infinity.
iqjump123
61
Hello, first time poster.
I am putting this question in the PDE section because this was a question I came up while solving a PDE question.
Also, I figured that since this is not a straight homework question, I can post in this category. Mods, feel free to move this post to wherever you see fit. thanks.
I have looked everywhere, including the gredsteyin book of integrals and transforms to find this solution, but I wasn't able to find it. I am especially talking about the one from 0 to infinity as the bounds.
using mathcad just gives me a solution with infinity in it as a variable.
My professor will not tell me what it is, pretty much telling me that I am a fool for not being able to find it. @#%@#%@#%@
Also, another one that I couldn't find it for was:
integral of sin(ax)sin(ax) from 0 to an arbitrary number t?
Any help on this will be appreciated!
Thanks so much.
iqjump123
Thanks so much.
iqjump123
Look at the product formulas here if a and b aren't equal:
http://www.sosmath.com/trig/prodform/prodform.html
If a = b you can use the double angle formula for sin2(θ). I don't think you will find the integral converges for t → ∞.
Thanks for the info!
I figured as such for the ones with the different values for a and b..
I think I will just write out the indefinite forms and write out the limits manually instead of evaluating it.
If anybody else can shed light on this topic, that will be great!
Thanks very much.
You might remember that cos(a+ b)= cos(a)cos(b)- sin(a)sin(b)
Changing the sign on b: cos(a- b)= cos(a)cos(b)+ sin(a)sin(b)
(because cos(-b)= cos(b) and sin(-b)= -sin(b).
Subtracting the first equation from the second, the "cos(a)cos(b)" terms cancel and we have
cos(a-b)- cos(a+b)= 2sin(a)sin(b) so that
sin(a)sin(b)= (1/2)(cos(a-b)- cos(a+ b)[
and, therefore,
sin(ax)sin(bx)= (1/2)(cos((a-b)x)- cos((a+b)x)
From that, it is easy to get
[tex]\int_0^A sin(ax)sin(bx)= (1/2)\int_0^A cos((a-b)x)dx- (1/2)\int_0^A cos((a+b)x)[/tex]
[tex]\frac{1}{2(a-b)}sin((a-b)A- \frac{1}{2(a+b)}sin((a+b)A)[/tex]
But the problem is taking the limit as A goes to infinity!
Hello iqjump123,
Thank you for your question. The definite integral of sin(ax)sin(bx) from 0 to infinity is a challenging one to solve. It requires advanced techniques such as contour integration or Fourier transforms.
As for the integral from 0 to an arbitrary number t, you can use the trigonometric identity sin^2(x) = 1/2 - 1/2cos(2x) to rewrite the integral as:
integral of (1/2 - 1/2cos(2ax))dx from 0 to t
= 1/2x - 1/4sin(2ax) from 0 to t
= 1/2t - 1/4sin(2at) - 1/4sin(0)
I hope this helps. Keep exploring and learning, and don't be discouraged by difficult problems. That's how we grow as scientists. Best of luck!
What is a definite integral?
A definite integral is a mathematical concept used to find the area under a curve on a specified interval. It is represented by the symbol ∫ and has a lower and upper bound, indicating the range over which the integral is to be evaluated.
What is the difference between a definite and indefinite integral?
A definite integral has specific limits of integration, while an indefinite integral does not. In other words, a definite integral gives a numerical value, while an indefinite integral gives a function.
What is the significance of the limits of integration in a definite integral?
The limits of integration determine the range over which the definite integral is being evaluated. They also determine the starting and ending points of the curve being integrated, and therefore, the area being calculated.
How do you solve a definite integral?
To solve a definite integral, you first need to find the indefinite integral of the function being integrated. Then, you plug in the upper and lower limits of integration into the indefinite integral and subtract the results. The resulting value is the numerical evaluation of the definite integral.
What is the application of definite integrals in science?
Definite integrals are extensively used in science to calculate various physical quantities, such as displacement, area, volume, and work. They are also used in fields like physics, finance, and engineering to model real-world situations and solve complex problems.
  • Differential Equations
  • General Math
  • Calculus
  • Other Physics Topics
