wolfknight
- 5
Alright, so, I am writing an aimbot for a popular game, and I need a bit of help with calculating the correct pitch angle for the player. The weapon is a bow, so the arrows are affected by gravity. I am trying to find the pitch angle that accounts for gravity and distance from the Entity you are firing at.
My current code doesn't work, but I will post it anyways. I have researched the correct algorithm (I found it at http://en.wikipedia.org/wiki/Trajectory_of_a_projectile#Angle_required_to_hit_coordinate_.28x.2Cy.29) and have attempted to implement it. However, when the aimbot is being used, for some reason, it stays in the middle of my screen, regardless of the entity's Y value or the player's Y value. I have the velocity correct, and the gravity constant correct, and that is all I know.
Anyways, enough rambling, here is my code:
The gravity constant is -0.05D, and the velocity doesn't matter, as I have compared it to the in-game arrow velocity and it matches.
If anyone can help, I would appreciate it.
Code:
private float getBowPitchFromEntity(Entity e) {
double x = getX(e);
double y = getY(e);
double z = getZ(e);
double velocity = getVelocity();
double posX = Math.pow(x, 2) + Math.pow(z, 2);
double height = y - getY(getPlayer());
return (float)getTrajectory(posX, z, velocity, height);
private double getTrajectory(double x, double z, double velocity, double height) {
double vsquared = Math.pow(velocity, 2);
double vquad = Math.pow(velocity, 4);
double gxsquared = Math.pow(x * gravityConstant, 2);
double gx = x * gravityConstant;
double twoyvsquared = 2 * Math.pow(height * velocity, 2);
double add = Math.atan2(vsquared + Math.sqrt(vquad - (gravityConstant * (gxsquared + twoyvsquared))), gx);
double sub = Math.atan2(vsquared - Math.sqrt(vquad - (gravityConstant * (gxsquared + twoyvsquared))), gx);
return Math.min(add, sub);
