Plastic Engine Block Cooled with liquid metal
In summary, the conversation discusses the possibility of using plastics in high heat and high pressure environments, specifically for engine blocks and cannon barrels. The idea is sparked by research that showed a cooling of a 1600 degree plate to 80 degrees using potassium, sodium, or exotic metallic liquids. The suggestion is to use graphite powder and epoxy composite for the block, with liquid sodium as a coolant and metallic liners for high wear parts. The speaker also mentions considering the weight reduction and ease of production. However, there are concerns about the feasibility of plastic cannon barrels and the advantages over traditional steel barrels.
Mustafa Umut
34
Is there any research done on plastic engine blocks or cannon barrels ?
I interested in using plastics at high heat high pressure environments after learning some researchers cools 1600 degree plate to 80 degrees with potassium or sodium or exotic metallic liquids.
I think it might be possible to produce a block out of graphite powder and epoxy composite ,
use liquid sodium as a coolant and use of metallic liners.
Other high wear parts could be made from metal but think the weight reduction of the engine and the easy of production.
I need your ideas ,
Best ,
Mustafa Umut Sarac
Istanbul
By the way , if you interested to cool something with liquid metals , look to nuclear power stations or ibm news.
Best ,
Mustafa Umut Sarac
Istanbul
I can think of at least a couple other problems with plastic cannon barrels, beyond heat.
If you jacket the barrel with concrete and if you use a liner , you reach somewhere possible.
Best ,
Mustafa Umut Sarac
Istanbul
Best ,
Mustafa Umut Sarac
Istanbul
With all that extra stuff, what would be the advantages over the traditional steel barrel?
What is a plastic engine block cooled with liquid metal?
A plastic engine block cooled with liquid metal is an engine block made from a plastic material, such as polymer, that is cooled using liquid metal, such as liquid sodium or liquid gallium. This type of engine block is becoming increasingly popular due to its lightweight and efficient cooling properties.
How does a plastic engine block cooled with liquid metal work?
A plastic engine block cooled with liquid metal works by circulating the liquid metal through channels in the engine block. As the engine runs, heat is generated, and the liquid metal absorbs the heat, carrying it away from the engine block and dissipating it through a heat exchanger.
What are the benefits of using a plastic engine block cooled with liquid metal?
The use of a plastic engine block cooled with liquid metal offers several benefits. These include reduced weight, improved fuel efficiency, and increased durability. This type of engine block also has better thermal conductivity, allowing for more efficient heat dissipation.
What are the potential drawbacks of using a plastic engine block cooled with liquid metal?
One potential drawback of using a plastic engine block cooled with liquid metal is the cost. The materials and technology involved in creating this type of engine block can be more expensive than traditional engine blocks. Additionally, there may be concerns about the potential for corrosion or leakage of the liquid metal.
Is a plastic engine block cooled with liquid metal suitable for all types of engines?
No, a plastic engine block cooled with liquid metal may not be suitable for all types of engines. This type of engine block is typically used in smaller, more efficient engines, such as those found in hybrid or electric vehicles. Larger, high-performance engines may not benefit as much from this technology and may require alternative cooling methods.
  • Mechanical Engineering
47K
  • Materials and Chemical Engineering
  • Nuclear Engineering
12K
