DC-Transformer circuit help
by Kuzey Cem
Tags: circuit, dctransformer
Kuzey Cem
Kuzey Cem is offline
#1
Feb15-14, 10:39 AM
P: 3
I recently learned that if you send direct current through the primary coil of a transformer, no power would be transferred to the secondary circuit? Why is that?
Phys.Org News Partner Engineering news on Phys.org
SensaBubble: It's a bubble, but not as we know it (w/ video)
WSU innovation improves drowsy driver detection
Faster computation of electromagnetic interference on an electronic circuit board
Averagesupernova
Averagesupernova is offline
#2
Feb15-14, 11:16 AM
P: 2,452
Can you tell us why it works for AC? If so, then you should know why it does not work for DC.
FrankFerrese
FrankFerrese is offline
#3
Feb15-14, 11:18 AM
P: 3
Theoretically, it would work. Since the flux in the core of the transformer increases by the integral of the applied voltage (Faraday's law), in an ideal transformer, the flux would just continue to increase. However, if you tried this with an actual transformer, you would drive the core into saturation and create a lot of heat.
Dr. Frank Ferrese
meBigGuy
meBigGuy is offline
#4
Feb15-14, 05:27 PM
P: 976
A Straight Answer:
A changing current produces a changing magnetic field, which in turn can induce a current in the secondary. If the current is not changing, the magnetic field is not changing, so no current is induced in the secondary.
When you first apply a DC voltage the current ramps up, so the field is changing and an initial current is induced in the secondary. But when the current stops changing (limited by resistance, for example) there will be no current induced into the secondary.
dlgoff
dlgoff is offline
#5
Feb15-14, 05:37 PM
Sci Advisor
PF Gold
dlgoff's Avatar
P: 2,633
Picture time.
http://hyperphysics.phy-astr.gsu.edu...ic/transf.html
Register to reply
Related Discussions
DC transformer General Physics 4
Is Aluminum-Aluminum wound transformer better than Copper-Copper Transformer? Electrical Engineering 13
Transformer Introductory Physics Homework 1
EHT transformer Electrical Engineering 3
