Irritatingly failed resistance calculations
In summary, the conversation is about replacing resistors in a circuit to achieve a specific output voltage at both low and high voltage levels. The purpose of the circuit is to run two oscillators and the voltage divider sampling filtered output from a buck inductor. The calculations for the resistors have been done multiple times, but the results are still uncertain. The target output voltages are 1.172V and 1.25V, and the circuit uses Rds(on) for the FET Q3 and Vfb of 0.6V when the buck DC-DC output is in regulation.
prush242
Gentlemen/Ladies,
Long time reader, first time posting. I have a few projects that I would like to get done, and I realized if I don't start getting them done, I never will. Heh.
I'm making mistakes calculating the resistors I would need for the following. I've done it 5 times now because each time I do the math, I'm coming to different conclusions. This will be my first learnings on surface mount soldering, so I want to be sure the bits are correct, then I can only blame myself for any soldering mistakes. So:
The board has R1=7500ohm, R2=7870ohm, and R3=2100ohm, as a voltage divider sampling filtered output from the 53355 buck inductor (0.6V), and runs at 1.0514V low voltage. At high voltage, R3 is not used, and it runs at 1.172V.
What I would like to do is replace R1 and R2, such that the board, using R1, R2, and R3, runs at 1.172V low voltage, and then using only R1 and R2, runs at 1.25V high voltage. The use of higher voltage is not in question as far as the board is concerned.
I think I'm screwing up the calculations between the different options for R1 and R2:
Vo = 1.17V on low voltage.
R7 = (1.17V - 0.6V) * (7870+2100) / 0.6V
R7 = (0.57V)*(9970)/0.6V
R7 = (55/60)*9970 = 9139ohm for low voltage.
But it has been QUITE some time and I'm not quite sure I am using the formulas correctly. Either way, I think too many numbers are leading me astray. :confused:
Anyone have any thoughts? And thank you, in advance!
prush242 said:
Gentlemen/Ladies,
Welcome to the PF.
Can you upload a schematic? It's hard to follow what you are trying to do.
Welcome to the PF.
Surprisingly enough, yes. Does it help?
Now, as it happens, I have some 8800ohm and 9100ohm resistors. So I tried to calculate the values if I were only to replace R1, leaving R2 and R3 alone, and came up with this:
Vo = 0.6V * [8800/(7870+2100)] + 0.6V
Vo = 0.6V * 0.8826 + 0.6V
Vo = 0.5296V + 0.6V = 1.130V, and:
Vo = 0.6V * [9100/(7870+2100)] + 0.6V
Vo = 0.6V * 0.9127 + 0.6V
Vo = 0.5476 + 0.6V = 1.150V, thus:
Vo = 0.6V * (7500/7870) + 0.6V
Vo = 0.6V * .9530 + 0.6V
Vo = 0.5718V + 0.6V = 1.172V, therefore:
Q3 = 1.172V = operating point at low voltage.
Thus:
Vo = 1.172V low voltage.
R1 = (1.17V - 0.6V) * (7870+2100) / 0.6V
R1 = (0.57V)*(9970)/0.6V
R1 = (55/60)*9970 = 9139ohm for low voltage.
and
Vo = 1.25V at high voltage.
R1 = (1.25V - 0.6V) * (7870+0) / 0.6V R3 is zero, because it isn't used at high voltage.
R1 = (0.65V)*(7870)/0.6V
R1 = (65/60)*7870 = 8525ohm
So, averaged: (8525+9139)/2 = 8832, and I have 8800s and 9100s.
Still going... with 9100ohm:
Low voltage, target is 1.17V
Vo = 0.6V * [R1/(R2+R3)] + 0.6V
Vo = 0.6V * 0.913 + 0.6V
Vo = 0.5476V + 0.6V = 1.148V, 1.9% difference from target.
High voltage, target is 1.25V
Vo = 0.6V * [9100/(7870+0)] + 0.6V
Vo = 0.6V * 1.156 + 0.6V
Vo = 0.694V + 0.6V = 1.294V 3.46% difference from target
Then with 8800ohm
Vo = 0.5296V + 0.6V = 1.130V, 3.48% difference from target.
Vo = 0.6V * [8800/(7870+0)] + 0.6V
Vo = 0.6V * 1.12 + 0.6V
Vo = 0.671V + 0.6V = 1.271V 1.67% difference from target.
I have zero faith in those numbers, given my differing results, but what I get is I could possibly just replace R1 with the 8800ohm resistor. I don't think that's a good idea, because it seems it is too high for low voltage and too low for high voltage.
Hence, I would rather replace both of them but it's getting Lost in Translation.
I hope that helps, as I am at an impasse.
Thanks again anyone, for any thoughts. 8^]
Anyone? Anyone? Bueller? 8^]
I'm having a bit of trouble tracking your work... What does this mean:
And what is the purpose of this circuit? Why do you need such low output voltages, and with that precision? What is Rds(on) for the FET Q3? The Vfb = 0.6V when the buck DC-DC output is in regulation, right?
Thanks for your response, Berkeman!
Purpose: The circuit runs one of two oscillators, presently 12.0MHz and 14.318MHz. When all three resistors are in use, the circuit runs the 12.0MHz oscillator (low voltage). When only two are in use (R3 is unused), the circuit powers the 14.318MHz oscillator (high voltage).
Low voltages and precision: Because that is what’s there on the board. I didn’t make it from scratch. 8^]
Q3 is the feedback divider that samples the output voltage. With Q3 off/open, the VRM is set to output 1.05V. The same logic signal that triggers the higher oscillator enables Q3 through R25, and it shorts around R3, removing it from the string. I think Rds(on) is less than 1 ohm, which means the combo of (1 ohm)||(R3) is a few orders of magnitude smaller than the other pieces.
Vfb: Correct, 0.6V when the buck DC-DC output is in regulation.
I want to change the two oscillators to 14.318MHz and 16.0MHz for low and high respectively. Though it just dawned on me. Once I change the board, it will never run at 14.318, it will always run at 16.0MHz, which changes how I'm thinking this can be done.
1. What are "irritatingly failed resistance calculations"?
"Irritatingly failed resistance calculations" refer to calculations or measurements that do not yield the expected or desired results when determining the resistance of a material or circuit.
2. Why do resistance calculations sometimes fail?
Resistance calculations can fail due to a variety of reasons, such as incorrect input values, faulty equipment, or human error. It is important to double-check all inputs and troubleshoot any potential issues to ensure accurate results.
3. How can I avoid irritatingly failed resistance calculations?
To avoid irritatingly failed resistance calculations, it is important to use reliable equipment and carefully calibrate it before use. Additionally, double-checking all inputs and performing multiple trials can help identify and correct any potential errors.
4. Are there any common mistakes that lead to failed resistance calculations?
Yes, some common mistakes that can lead to failed resistance calculations include using the wrong formula for the given scenario, using incorrect units, and not accounting for all factors that may affect the resistance of a material or circuit.
5. What should I do if I encounter an irritatingly failed resistance calculation?
If you encounter an irritatingly failed resistance calculation, it is important to review all inputs and steps taken to ensure accuracy. If the error cannot be identified, seeking the help of a colleague or consulting additional resources may be beneficial.
  • Electrical Engineering
