Charged particle at relativistic velocity
In summary, a charged particle moving at constant velocity with respect to any inertial frame does not radiate energy. This is due to the fact that Maxwell's equations state that a time-varying electric field generates a magnetic field and vice versa. However, if additional charges are introduced, such as in the case of a moon, the problem becomes more complex and the particle may experience acceleration and radiate energy. The existence of a photon also depends on the frame of reference and whether it is viewed as an electromagnetic wave or a particle.
Privalov
24
Imagine a charged particle moving in vacuum with relativistic velocity. It emits electromagnetic wave with some known energy. This energy can be detected and used somewhere else. I guess this energy should come from particle’s kinetic energy, thus particle should slowly decelerate over time.
However, General Relativity states all inertial points of view are identical. If an observer moves near the particle with the same constant speed, he will believe particle stays still and emits no energy. From his point of view, particle should not decelerate.
Will the particle decelerate, after all?
I came up with the following assumption to resolve this paradox: if radio detector exists somewhere nearby, moving electrons n it’s antenna will attract to the moving particle by electromagnetic force, so particle will decelerate. If there is no radio detector nearby, particle will keep its speed.
However, then comes the next question: electromagnetic wave is a photon. Photon can be seen as a particle. Logically, it can not exist for some observers and does not exist for another observer.
A charged particle moving at constant velocity with respect to any inertial frame doesn't radiate.
That's going a bit far for the GR forum, do you deny a charged moon would radiate?
On topic, a charge with constant velocity will certainly cause a stationary observer to experience a changing electromagnetic field, and hence induce acceleration of charges in a stationary antenna (i.e., radiation of energy). Presumably there will also be a Lenz back-reaction such that it requires work to hold the charged particle at constant velocity.
OK, so my guess was right. Now, can photon exist in some inertial frame of reference and do not exist in another? Is photon the same thing, as electromagnetic wave?
Quote: "According to Maxwell's equations, a time-varying electric field generates a magnetic field and vice versa."
http://en.wikipedia.org/wiki/Electromagnetic_waves
A moon doesn't have constant velocity. It may have constant speed, but not velocity.
Yes, but when you add these other charges, you change the problem from the OP's single charge in vacuum. Different problem, different answer.
Since we are discussing special and general relativity here I think you should explain why you think that the moon's velocity is not constant.
Because it is not going in a straight line at constant speed, for God's sake!
You seem to be talking about Newtonian mechanics not general relativity.
The OP had a simple misconception - confusing acceleration and velocity for when charges radiate. George Jones cleared this up. Why muddy the waters with talk of GR and additional charge distributions?
What is a charged particle at relativistic velocity?
A charged particle at relativistic velocity is a particle that is moving at a speed close to the speed of light. This means that it is traveling at a velocity that is a significant fraction of the speed of light, which is about 300,000,000 meters per second.
What is the significance of a charged particle at relativistic velocity?
A charged particle at relativistic velocity has significant implications in the fields of physics and astrophysics. At these high speeds, particles exhibit behaviors such as time dilation, length contraction, and increased mass. These effects are described by the theory of relativity and have been confirmed through various experiments.
How are charged particles at relativistic velocity studied?
Charged particles at relativistic velocity can be studied through a variety of experimental techniques. These include particle accelerators, which can accelerate particles to high speeds and collision detectors, which can detect and measure the properties of these particles. Scientists also use mathematical and computational models to study the behavior of charged particles at relativistic velocity.
What are the potential applications of studying charged particles at relativistic velocity?
Studying charged particles at relativistic velocity has many potential applications. These include the development of new technologies, such as particle accelerators and medical imaging devices, as well as a better understanding of the fundamental laws of physics. Additionally, studying these particles can help us better understand the behavior of matter in extreme conditions, such as in the early universe or in black holes.
What are the challenges of studying charged particles at relativistic velocity?
Studying charged particles at relativistic velocity presents many challenges, both experimental and theoretical. These particles are difficult to accelerate and control, and their high speeds make them difficult to detect and measure accurately. The theories that describe their behavior, such as relativity, can also be complex and counterintuitive, making it challenging to understand and interpret experimental results.
