A set of generators for a topolgy that is not a basis?
In summary: Thank you!In summary, a basis for a topology generates that topology, but a generating set for a topology is not necessarily a basis. A basis is a subset of the topology such that every open set can be written as a union of basis elements, while a generating set is a subset of the power set of a set whose intersection generates the topology. In general, a generating set is not a basis, but it can be a subbase for the topology it generates.
quasar987
32
It is clear that a basis for a topology generates that topology. (i.e. the smallest topology containing the basis is the topology that the basis is a basis of)
But if we look at a generating set for a topology, is this generating set necessarily a basis?
I am guessing that no in general (although it is true that the set of "generalized open rectangles" is both a generating set and a basis for the product topology) because otherwise a topology would always be determined by simply the union of its generators.
But I have little experience with general topology and since this is just for personnal curiosity, I don't want to waste more time trying to find an example where the generating set is not a basis.
Anybody's got an example?
What is your definition of a generating set for a topology?
Let X be a set and G be a subset of 2^X (the power set). Then the topology of X generated by G is the intersection of all topologies containing G. It is therefor the smallest topology containing G.
You appear to have just answered your own question. Or at least your two definitions imply that a generating set is a basis.
I have not defined 'basis'. I did not think it was necessary, but I noticed that there are many different definitions around.. the one I use is this elegant one: If T is a topology for X, then a basis for T is a subset T' of T such that every open can be written as a reunion of elements of T'.
That is equivalent to a generating set, too by your own definition. I think you're on the wrong track of thinking of basis and spanning set from linear algbra.
Can you show me why?
The objection I have is that another way to look at the topology generated by a set is that it is the topology you get by taking all the unions of the sets in your generating set, then taking all the intersections, and weird mix of intersections and unions.
But if every generating set was a basis, we would not have to take the intersections and the weird mix, since by def of a basis, the only unions would suffice to create a topology.
But basis elements are themselves open sets, so the intersection of finitely many of them is again an open set, and hence is a union of some collection of basis elements.
I guess this is the piece I was missing !
Cheers morphism!
Let X = {1, 2, 3}.
Consider the set G = { {1, 2} , {2, 3} }
The smallest topology containing G is
{ {}, {2}, {1, 2}, {2, 3}, {1, 2, 3} }
{2} isn't a union of elements of G, so G is certainly not a basis for the topology it generates.
Yeah! Hurkyl to the rescue! :cool:
It is the subbase of the topology that generates the topology in the sense as you were talking about generating it.
1. What is a topology and how is it related to a set of generators?
A topology is a mathematical concept that describes the properties of open sets in a given space. A set of generators for a topology is a set of open sets that can be used to define the topology. This means that any open set in the topology can be expressed as a union of these generators.
2. Why would a topology need a set of generators if it already has a basis?
A basis for a topology is a set of open sets that can be used to generate all other open sets in the topology through unions. However, not all topologies have a basis. In such cases, a set of generators can be used to define the topology.
3. How do I know if a set of generators is sufficient to define a topology?
A set of generators is sufficient to define a topology if it satisfies the axioms of a topology. These axioms include that the empty set and the entire space must be open sets, any finite intersection of open sets is open, and any union of open sets is open.
4. Can a set of generators for a topology be infinite?
Yes, a set of generators for a topology can be infinite. In fact, in some cases, an infinite set of generators may be necessary to define a topology, such as in the case of a topology on the real numbers.
5. How is a set of generators different from a basis for a topology?
A set of generators and a basis for a topology both serve the purpose of defining the topology. However, a basis is a minimal set of open sets, while a set of generators may contain redundant or unnecessary open sets. Additionally, a basis can only be used to generate open sets through unions, while a set of generators can also generate open sets through intersections.
  • Topology and Analysis
  • Linear and Abstract Algebra
