Why 2-point correlation function diagram have only two external legs?
In summary, the 2-point correlation function diagram has only two external legs because it represents the scattering process between only two particles. It cannot have more than two external legs as it would represent a higher-order correlation function. The diagram shows the amplitude of the scattering process and provides information on the strength and type of interaction between the particles. It is related to the 2-point correlation function, which is a mathematical function that describes the correlation between two particles. The 2-point correlation function diagram is important in physics as it helps us understand the interactions between particles and can provide valuable insights into the behavior of matter and energy.
ndung200790
519
Please teach me this:
Why 2-point correlation function diagrams have only two external lines.Because of Wick theorem they would have many external legs.
Another thing is whether are there odd number point correlation functions(meaning they are different from 0).
Thank you very much in advanced.
Now,I have understood that,because of normal operator(N: operator) being in Wick theorem statement.
Well, because of the number of external 'legs' (2), they are called '2-point correlation functions', or '2-point Green functions'. If they had N-external 'legs', they would be called 'N-point correlation functions/Green functions'.
1. Why does the 2-point correlation function diagram have only two external legs?
The number of external legs in a correlation function diagram represents the number of particles involved in the scattering process. In a 2-point correlation function, only two particles are involved, hence the diagram only has two external legs.
2. Can a 2-point correlation function diagram have more than two external legs?
No, a 2-point correlation function diagram can only have two external legs because it represents the scattering between only two particles. If there were more particles involved, the diagram would be a higher-order correlation function.
3. What information does the 2-point correlation function diagram provide?
The 2-point correlation function diagram shows the amplitude of the scattering process between two particles. It provides information on the strength and type of interaction between the particles.
4. How is the 2-point correlation function related to the 2-point correlation function diagram?
The 2-point correlation function is a mathematical function that describes the correlation between two particles at different points in space. The 2-point correlation function diagram is a visual representation of this mathematical function.
5. Why is the 2-point correlation function diagram important in physics?
The 2-point correlation function diagram is important in physics because it allows us to understand the interactions between particles at a fundamental level. It is a powerful tool for studying the properties of different physical systems and can provide valuable insights into the behavior of matter and energy.
  • Quantum Physics
