Register to reply
Poincare Invariance of vacuum
by ChrisVer
Tags: invariance, poincare, vacuum
Share this thread:
ChrisVer
#1
May8-14, 05:43 PM
P: 754
Suppose I have a field [itex]\hat{X}[/itex]...
What kind of operator should it be in order to develop a vev which doesn't break the Poincare invariance?
I am sure that a scalar field doesn't break the poincare invariance, because it doesn't transform.
However I don't know how to write it down mathematically or prove it...
Also, because I don't know how to "prove" it, I am not sure if there can exist some other [itex]X[/itex] field/operator which would keep the poincare invariance untouched after getting a vev...So why couldn't it be a fermion? or a vector field?
Is it the same as looking at the Lorentz group? So that you have the scalar in (0,0)repr, while the fermions can be in (1/2,0) or (0,1/2) and vectors in (1/2,1/2)?
But who tells me that the vacuum shouldn't be a spinor or vector?
Phys.Org News Partner Physics news on Phys.org
Optimum inertial self-propulsion design for snowman-like nanorobot
The Quantum Cheshire Cat: Can neutrons be located at a different place than their own spin?
A transistor-like amplifier for single photons
Vanadium 50
#2
May8-14, 06:15 PM
Mentor
Vanadium 50's Avatar
P: 16,182
Quote Quote by ChrisVer View Post
In which direction does the background point?
ChrisVer
#3
May8-14, 06:43 PM
P: 754
what is the background?
Vanadium 50
#4
May8-14, 07:17 PM
Mentor
P: 16,182
I'm sorry. I mean vacuum. In what direction does it point?
Orodruin
#5
May9-14, 02:54 AM
P: 231
Apart from scalar fields, rank 2 tensor fields may develop a vev proportional to the metric tensor without breaking Lorentz invariance since the metric by definition is invariant.
ChrisVer
#6
May9-14, 05:28 AM
P: 754
I thought that a general metric breaks poincare invariance (and brings instead general coord transfs)?q
For minkowski metric, doesn't it transform like a 2nd rank tensor?
Orodruin
#7
May9-14, 05:45 AM
P: 231
Exactly, and since the form of the metric is preserved, it looks the same in all frames. Thus, a vev proportional to the metric does not break Lorentz invariance.
ChrisVer
#8
May9-14, 12:21 PM
P: 754
is there any source dealing with such a thing (vev of the minkowski metric)? I am not even sure how the metric would act on the vacuum...
Einj
#9
May9-14, 01:13 PM
P: 305
A VEV coming from a scalar field is Poincarč invariant for the following reason (I'm excluding the case of the VEV being proportional to the metric since I'm not very familiar with it). Under a Lorentz transformation [itex]\Lambda[/itex] a generic field transforms as:
U^\dagger(\Lambda)\phi(x)U(\Lambda)=S(\Lambda)\phi(\Lambda x),
where U([itex]\Lambda[/itex]) belongs to the representation of the Lorentz group acting on the physical states while [itex]S(\Lambda)[/itex] belongs to the representation acting on the operators.
The vacuum is clearly Lorentz invariant. If you want for your VEV to be Lorentz invariant it must be:
\langle 0|\phi(x)|0\rangle=\langle 0|\phi(\Lambda x)|0\rangle,
however, because of the invariance of the vacuum:
\langle 0|\phi(x)|0\rangle=\langle 0|U^\dagger(\Lambda)\phi(x)U(\Lambda)|0\rangle=S(\Lambda)\langle 0|\phi(\Lambda x)|0\rangle,
and so it must be [itex]S=1[/itex] which is true for a scalar field.
Register to reply
Related Discussions
Vacuum states invariance Quantum Physics 8
Diffeomorphic Invariance implies Poincare Invariance? Special & General Relativity 117
Minkowski vacuum: Poincare invariant, quasi-free state Quantum Physics 2
Poincare Invariance from General QFT Beyond the Standard Model 33
Charge Conjugation Invariance of the Vacuum Beyond the Standard Model 0
