Finding critical temperature from equation of state
In summary, the conversation discusses the use of derivatives to determine the critical temperature for different equations of state. The popular contradiction method is used to show that no critical temperature exists for an ideal gas, while for other equations of state, the same method can be used to find the critical temperature. It is also mentioned that the critical temperature is the highest temperature at which a gas can be liquefied, but the absence of a critical temperature in an equation does not necessarily mean that the gas cannot be liquefied at that temperature in reality.
lkh1986
99
Given the equation of state PV=nRT. So, I get the first derivative and second derivative (P with respect to V) and equate them to 0. Then, I found out that they cannot be equal to 0, so I make the conclusion that no critical temperatue exists for an ideal gas.
If the van der Waals equation is given, I can find the critical temperature by using the same way, namely equate the first and second derivatives to 0. Yeah, critical temperature exists for this case.
But how about other kind of equation of state? Let say P(V-nb)=nRT or (P+a)(V)=nRT. Can we use the same method? (I think we can). And is the CRITICAL temperature here refers to the CRITICAL point on the graph of the plot P versus V? As in the critical/stationary point in the field of mathematics?
I am given an equation in a book. Then first I assume there exists a critical point (although it may not exist). Then, I get the first and second derivatives. Then I equate them to 0. And after some calculations, I get 0.25 = 0.125, which is clearly wrong. So, this contradicts with my previous assumption that a critical temperature exists. Therefore, NO critical temperature exists this gas. Is this kind of contradiction method accepted? Because I am told that this popular contradiction method is widely used in mathematics.
Since critical temperature is the highest temperature in which a gas can be liquefy, so if a gas doesn't have a critical temperature, I can say that the gas cannot be liquefy. Is this correct? Thanks.
Yes you plot P versus V and then at the point of inflection you set the 1st and 2nd derivatives to zero. This is where the critical pt exists. When you only have an equation and no graph whatsoever, you work out the derivatives and see if the critical pt exists.
If you're not sure about your answer , post the equation of state you're working on. If you're very sure that your calculation is correct and the results are contradictory then yes no critical pt can be predicted by this equation.
Suppose an equation of state cannot predict Tc for a gas. Does that mean the gas cannot be liquified at Tc? Absolutely not. The equation itself is limited and cannot explain liquifaction for this gas at Tc but that doesn't mean that the gas in reality has no Tc.
I would like to clarify a few points about finding critical temperature from an equation of state. First, it is important to note that the equation of state PV=nRT is only applicable to ideal gases, which do not exist in the real world. Therefore, using this equation to find the critical temperature may not accurately reflect the behavior of real gases.
Secondly, the method of equating the first and second derivatives to 0 to find the critical temperature assumes that the gas follows a certain type of equation of state, such as the van der Waals equation. This may not be applicable to all types of equations of state, as you have mentioned.
Furthermore, the critical temperature refers to the temperature at which a gas undergoes a phase transition from gas to liquid. This is typically represented on a phase diagram as the point where the liquid and gas phases coexist. It is not necessarily the same as a critical point in mathematics, although the concept of a stationary point can be applied in both cases.
In conclusion, while the method of equating derivatives to 0 can be useful in some cases, it may not always give accurate results for real gases. It is important to consider the limitations and assumptions of the equation of state being used. Additionally, the concept of critical temperature should not be confused with a critical point in mathematics.
1. What is the equation of state?
The equation of state is a mathematical relationship that describes the relationship between the physical properties of a substance, such as temperature, pressure, and volume. In the context of finding critical temperature, the equation of state is used to determine the temperature at which a substance undergoes a phase transition from a gas to a liquid or a liquid to a solid.
2. How is the critical temperature defined?
The critical temperature is the temperature at which a substance exists in both its liquid and gas phases simultaneously. Above this temperature, the substance can only exist as a gas, and below this temperature, it can only exist as a liquid. The critical temperature is a unique property of each substance and is determined by its equation of state.
3. What is the significance of finding the critical temperature?
Finding the critical temperature is important because it allows us to understand and predict the behavior of substances under different conditions. It is also a crucial parameter in various industrial and scientific processes, such as the production of liquefied natural gas and the design of refrigeration systems.
4. How is the critical temperature calculated from the equation of state?
The critical temperature can be calculated by solving the equation of state for the temperature at which the pressure and volume of the substance become equal. This is known as the Boyle temperature, and it is a critical point on the phase diagram of the substance. The critical temperature can also be determined experimentally by observing the behavior of the substance under varying temperature and pressure conditions.
5. What are the limitations of using the equation of state to find the critical temperature?
The equation of state may not accurately predict the critical temperature for certain substances, particularly those with complex molecular structures or those that exhibit non-ideal behavior. Additionally, the equation of state assumes that the substance is in a thermodynamic equilibrium, which may not always be the case in real-world situations. Therefore, experimental measurements are often necessary to confirm the critical temperature predicted by the equation of state.
