mkerikss
- 18
Consider the implicit (not actually sure wether that's the correct english word, my material is in Finnish and I'm Swedish-speaking ) method
xj+1=xj+h/2(f(tj,xj)+f(tj+h,xj+1))
a)Write an appropriate Runge-Kutta scheme
b) What is the methods rank when we use the equation x'=ax ? I have absolutely no clue if rank is the correct word but it is a number that describes some kind of order. Unfortunately I can't describe it better than that because I don't really know what it is and that is one of my questions.
c)What is the methods stability area?
In a), I'm not sure if the different numerical methods have different schemes, but one I've used in an earlier exercise is
__t____________t1_____t2_______tn
x1
x2
xn
Is this correct?
In b), I'm really lost. I've figured out that x'=f(x)=ax. The one previous time I've done an exercise about "rank" the solution was to use Taylor expansions, and then all x, x', x'' eventually disappeared, which if I recall correctly implies that the rank is 2. But I have no idea how to do that in this particular exercise.
I've also seen one example of calculating stability areas. Just to check that I have understood correctly, does this mean that I can write an equation where xj+1=Anx0, solve A:s eigenvalues and their absolute values have to be <1. Then I can solve h. Or is this a different situation?
Thanks for your help!
