Difference between Power Sets and Sample Space
In summary, the conversation covers the concept of a probability space, which is defined by a sample space, events, and a measure. The power set, which is the set of all subsets in the sample space, and the sample space itself are both collections of all possible outcomes. However, they differ in that the power set considers all possible subsets while the sample space considers all possible events. Additionally, the powerset can be defined using set builder notation, and it is always different from its corresponding set.
thrillhouse86
80
Hey All,
In my probability theory class we have just started learning about how a probability space is defined by a sample space (which contains all possible events), events and a measure.
We briefly went over the idea of the Power Set, which seems to be the set of all subsets in your sample space. My question is what is the difference between the Power Set and the Sample Space ? aren't they both just a collection of all possible outcomes ?
Thanks
The powerset is the sample space of the experiment:
'Of all subsets of X, what is the chance that this subset is one specific subset Y. provided an even distribution'
Well, then your chance happens to be 1/|P(X)|..
This is of course nothing special. This is just because the powerset is the defined as the set of all subsets.
If you ask, 'what is the chance that you have one specific subset which meets property Q'
Then your chance is also simply 1/|{x sub X : Q(x)}| ...
The powerset can be defined with the identity property (the property which is always true), which is x = x basically. So we get P(x) = {x sub X : x = x}.
Edit: not sure you know 'set builder notation', but if Phi(x) and Theta(x) are formulae in x, such as x > 3, or x ^ 2 = 3 et cetera. See {Phi(x) : Theta(x)} as the set of all x for which both formulae are true.
Simple example:
Sample space {1,2,3}
Power set {(),(1),(2),(3),(1,2),(1,3),(2,3),(1,2,3)}
mathman said:
Simple example:
That's not an example of a sample space and a powerset, that's A: a set, and B: the power set of that set.
If A is a sample space, then B is the powerset of a sample space.
A sample space is with respect to some experiment.
When I learned probability theory, it was taught on an abstract basis. A sample space was defined on the basis of Kolmogoroff axioms and did not require a particular experiment. In essence a sample space was a measure space with total measure = 1.
Yes, all and well, the first set was a possible sample space. But so was the second.
You just gave a sample space, and the powerset of that space as an illustration that powerspaces and sample sets are some-how different concepts, which they are, but not via this logic, because a powerset is of course always different to its set.
Perhaps he is talking about the set of all events, and asking why that is not just the power set ...
What is a power set?
A power set is a mathematical concept that refers to the set of all possible subsets of a given set. It includes the empty set and the original set itself.
What is a sample space?
A sample space is a set that contains all possible outcomes of a random experiment or trial. It is used in probability theory to represent the range of possible outcomes.
What is the difference between power sets and sample space?
The main difference between power sets and sample space is that a power set is a set of sets, while a sample space is a set of outcomes. The elements of a power set are subsets of a given set, while the elements of a sample space are individual outcomes.
How are power sets and sample space related?
The power set of a set can be used to represent the sample space of a random experiment. This is because the power set includes all possible subsets, which can be seen as all possible outcomes of the experiment.
Can power sets and sample space be used interchangeably?
No, power sets and sample space cannot be used interchangeably. While they are related concepts, they serve different purposes. Power sets are used in set theory, while sample space is used in probability theory.
  • Set Theory, Logic, Probability, Statistics
