Need help calculating angle with coefficient of static friction
In summary: I'm sorry, I don't understand. Could you please clarify? It sounds like you're trying to find the angle at which the box will slide down the plank, using the equation for static friction. However, you're not sure what the mg term is for. Could you please clarify what you're trying to do?
Fireant
There's a box sitting on a plank. The coefficient of static friction is 0.33. I want to figure out at which angle the box will begin to slide if the plank is tilted.
I know the factors that come into play are FN, Fg or Fgx, and Fs.
So far I have
Fnet= FN-Fs-Fg
=FN- μs-sin∅
=cos∅-0.33-sin∅
This doesn't look right... can anyone help me out?
What are the conditions for impending motion using Newton's second law?
I would suggest looking at the horizontal and vertical scalar equations of motion of the block and solving for [itex]\theta[/itex].
I'm having a bit of difficulty following your work. Could you clarify your last expression? (It looks like [itex]F_{net} = \cos\theta-0.33-\sin\theta[/itex] to me.)
Im assuming there's no acceleration, so Fnet= 0N.
This is the symbol for theta: θ
I used this symbol for "angle":∅
""""I'm having a bit of difficulty following your work. Could you clarify your last expression? (It looks like F_{net} = \cos\theta-0.33-\sin\theta to me.) """"
That's pretty much it! Except using angle to substitute for theta.
I don't know how to get to the angle...
I'm missing mass from the equation too right?
That's right. Impending motion, if you are unfamiliar with the term, is the point right before motion starts.
There's one more condition dealing with static friction. What would that be? (Remember how static friction works; is there a maximum value? What is it?)
Fireant said:
That's pretty much it! It's wrong... I don't know how to get to the angle...
The first place to start is by drawing a free body diagram of the situation. We know the block is tilted at some angle [itex]\theta[/itex] at which the box will just start to move, so what forces act on the block?
Next, sum the forces in the [itex]x[/itex] and [itex]y[/itex] directions (I would suggest using a coordinate system aligned with the ramp.). From these two equations (plus an expression relating the frictional force and the normal force) you should be able to find [itex]\theta[/itex].
0.33 ?
Force of gravity in the x compenent, the normal force, and the force of friction.
So you mean :
x
Fnet= Fgx
=mg(sin∅)-Fs
=mg(sin∅)-μs
and
y
Fnet=FN
0= mgcos∅
So far so good?
One more thing: The weight of the box is 10kg
[itex]\mu_s[/itex] is the coefficient of static friction, not the force of friction. So, what is the force of friction in this case?
You're almost there!
So... since
μs= Ff/FN
0.33=Ff/mg
Ff=0.33(10)(9.8)
Ff=32.34N
Static friction is given by [itex]F_s \leqslant \mu_s N[/itex], so [itex]F_{s,max}=\mu_s N[/itex]. So, from this and the FBD we can get the friction force as a function of mass, gravitational acceleration, and the angle [itex]\theta[/itex].
What is this force, and how can we substitute it to find [itex]\theta[/itex]?
Hint: the final answer will be independent of mass and gravitational acceleration.
You're saying
Fsmax=m(μs)FN
and I'm not sure what to subsitute the force with...
so technically...
if i know Fg and FN, I can figure out the angle?
So
tan∅= 32.34/9.8
∅=73°
Close, but not quite.
[itex]F_{s,max} = \mu_sN = \mu_s mg\cos\theta[/itex].
Then if [itex]ma = 0 = mg\sin\theta - \mu_s mg\cos\theta[/itex], what is [itex]\theta[/itex]?
Sorry for the latency in response, just got out of class.
No I really appreciate your help... getting my noggin working...
Fsmax=musN
=mus(mg)(costheta)
0=mgsinθ-mμs(mg)cosθ
that's the part where I'm confused... how do i isolate theta?
Fsmax=musN
=mus(mg)(costheta)
Maybe you could try moving [itex]\mu_s mg \cos\theta[/itex] to the other side and using trigonometry? Also, what can you do with the [itex]mg[/itex] term?
1. What is the coefficient of static friction?
The coefficient of static friction is a value that represents the amount of friction between two surfaces when there is no motion between them. It is denoted by the symbol μs and is dependent on the materials and surface conditions of the two surfaces in contact.
2. How do you calculate the angle with coefficient of static friction?
The angle with coefficient of static friction can be calculated using the formula θ = tan-1(μs), where μs is the coefficient of static friction. This formula assumes that the surface is flat and there is no external force acting on the object.
3. What is the significance of calculating the angle with coefficient of static friction?
Calculating the angle with coefficient of static friction can help determine the maximum angle at which an object can be placed on a surface without slipping. This is important in understanding the stability of objects on inclined planes or surfaces.
4. What are some common applications of calculating the angle with coefficient of static friction?
Some common applications of calculating the angle with coefficient of static friction include designing ramps, determining the maximum angle at which a car can safely drive on a curved road, and analyzing the stability of objects on inclined surfaces.
5. How can the coefficient of static friction be measured?
The coefficient of static friction can be measured experimentally by gradually increasing the angle of an inclined plane until the object placed on it starts to slide. The angle at which this occurs can then be used to calculate the coefficient of static friction using the formula mentioned above.
