Relationship between force and Velocity in Magnetic Fields
In summary, the force on a charged particle is -i and j. Find the x and y components of velocity using the F in the y direction with the wrong magnitude.
Typhon4ever
51
A negative particle is moving in a uniform magnetic field pointing in the negative k direction. The force on the particle is -i and j. Find the x and y components of velocity. (I left out the numerical data in the question). I used F=q*v*B and in order to find the x component I used the F in the x direction with is wrong. You need to use the F in the y direction to find x component. Why?
The force on a charged particle acts perpendicular to the direction of travel and the B field following right hand rule for cross products of vectors:
F = q(E + v x B) where F, E and B are vector quantities and x means cross product.
I thought that the F that is perpendicular to the velocity is the scalar quantitity and we need to decompose it into x and y vectors quantities and use the F in these x and y directions to find the corresponding x and y velocities.
True F is perpendicular to the v but it is also perpendicular to the B. the equation you wrote F=qvB
gives the magnitude of F.
I'm confused. If there is a force in the -i direction on the particle as well as a force in the j direction and we want the i and j velocities why don't we just use the corresponding forces in the corresponding directions? A force in the -i direction will affect the i velocity won't it?
Hmm. I was using F=qvB sin(theta) but I don't know sin(theta). I should have used F=qv x B because I know then that F is perpendicular to v so I must choose the perpendicular force. Correct? Or are you still able to use the angle version.
Geometrically, the force is perpendicular to both the velocity and the magnetic field. The relationship is written mathematically as a vector cross product - so that is what you should use.
There are lots of ways to evaluate the cross product - |u x v| = |u||v|sinθ is one of them.
However, this relation only computes the magnitudes, the question is asking about directions.
If you put the magnitudes equal to 1 for each vector you can find sinθ - but it is more convenient to evaluate the vector cross product directly.
It is even easier to do it using the right-hand rule.
I'm not sure what you mean by putting the magnitudes equal to 1. How exactly do you find sin theta that way?
I misspoke ... my apologies.
I got confused because you have not provided all the information given to you about the problem.
You appear to have given us the force direction and magnitude, the magnetic field direction only, and only the sign of the charge.
I assumed which more information was available to you without checking first.
ok to be specific the charge is -5.00 nC, B=-(1.28T)k, Magnetic F= -(3.30×10^-7 N)i+(7.60×10^−7 N)j. Does that change anything?
That changes the magnitude and direction of the force for starters... which changes the plane that the velocity is in. But it confirms what I thought - you have to do the vector math.
rewriting as vectors... $$\vec{F}=\begin{pmatrix}-3.30\\7.60\\0\end{pmatrix}\times 10^{-7}\text{N} \; ;\;
\vec{B} = \begin{pmatrix}0\\0\\-1.28\end{pmatrix}\text{T}\; ;\; \vec{v}=\begin{pmatrix}v_x\\v_y\\v_z\end{pmatrix}\text{m/s}\; ;\; q=-5.00\times 10^{-9}\text{C}\\
\vec{F}=q\vec{v}\times\vec{B}$$... do you know how to do a cross product?
Note - you can only find the x and y components of the velocity.
Fortunately, that is all they ask for.
1. How does force affect the velocity of an object in a magnetic field?
The force exerted on an object in a magnetic field is directly proportional to its velocity. This means that the higher the force applied, the faster the object will move.
2. What is the relationship between magnetic field strength and velocity?
The strength of the magnetic field also plays a role in determining the velocity of an object. The stronger the magnetic field, the greater the force exerted on the object and therefore the higher its velocity.
3. Can the direction of force and velocity change in a magnetic field?
Yes, the direction of both force and velocity can change in a magnetic field. This is because the force is always perpendicular to the velocity and the magnetic field, resulting in a constant change in direction as the object moves.
4. How does the mass of an object affect its velocity in a magnetic field?
The mass of an object does not directly affect its velocity in a magnetic field. However, a heavier object may require a greater force to achieve the same velocity as a lighter object in the same magnetic field.
5. What are some real-world applications of the relationship between force and velocity in magnetic fields?
The relationship between force and velocity in magnetic fields is used in various applications such as electric motors, generators, and particle accelerators. It is also used in magnetic levitation systems, where the force exerted on a magnet is used to levitate an object above a track.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
