Exploring the Riemann Hypothesis and Its Implications for Prime Numbers
In summary: I am not sure where you are mailing your results to, but I suggest you try mailing them to a few professors. None of whom have responded.
Borogoves
23
let [tex] \zeta(z)=\sum_{n \in \mathbb{N}} n^{-z}[/tex] ~ {{a+ib}}>1
then, [tex] \zeta(z)=0[/tex] iff z=-2n where n is a natural number.
[tex]pi(x)=\int_0^\infty\frac{dx}{\xS[x+1]} gamma(x+)[/tex]
where S[x+1]= [tex] \sum_{n \in \mathbb{N}} n^-{x+1}[/tex]
I have discovered that [tex]pi(x)=\int_a^b\frac{dx}/logx[/tex] = 1/log b+ 2/log b + 3!/logb +...
furthermore, [tex]pi(x)-\int_^x\frac{dx}[/tex]+1/2 [tex]\int_^x(1/2)\frac{dx}[/tex] (logx)^-1 ~ (x^1/3) /logx
is this already kmown ?
line one you need to explain: what does {{a+ib}}~>1 mean?
line 2 is false, since your expression for zeta does not exist at the points you claim are roots.
there are zeroes of zeta (with the proper definition) at other points than those you claim.
latex problems have rendered your post mostly incomprehensible. While you still can't view latex in preview mode, you can edit it after you post. I suggest you do so. While you are at it, you might want to give some justifications for whatever it is you are claiming.
latex has not displayed as intended.
It is a definition, it cannot be false.
{{a+ib}}>1 where the former is the norm.
a(bc)=/= (ab)c and a(ab)=a^b (ab)b=ab^2
I'm claiming that the integral is bound by ~ (x^1/3) /logx where x is large, say >10^10
1/log b+ 2/log b + 3!/logb +... is of continued fraction form
i think i have caught up with his reasoning he wants to prove RH by writing that:
[tex] \int_{0}^{\infty}dx[x]/x^{s+1}=\zeta(s) [/tex]
and then for s=1/2 somehow he obtains a bound for the integral, where s=a+ib
The expression you give is not a valid expression for the zeta function for Re(z)<1. You have not got the correct definition of the function. I suggest you take one second to look at the series and think. What happens if you put z=-2 in?
I was refferring to the real zeroes. stop the niggling remarks
Niggling remarks? You asserted that *the only zeroes* of zeta(z) are at negative even integers. That is false, and to compound the error the expression you give for zeta(z) isn't even defined at those points. Those are not niggling remarks. You did not say you were referring to only the real zeroe, and if you don't have the correct definition of the zeta function what makes you think the rest of your argument is valid?
Your latex is still incorrect.
I define zeta to be:
[tex] 1/s-1 \-s \int_{0}^{\1}dx\h(x)x^s-1 [/tex]
Evidently, somebody is attempting to edit my posts.
Borogoves:
You don't seem to care about your work enough to write it correctly.
Of what you've written, the stuff I can make out seems to be patently false. (e.g. that first equation with integral in your opening post... the left hand side is a function, and the right hand side is a constant!)
Furthermore, you don't seem to be paying any heed to the criticisms and advice you've been offered.
If things don't quickly take a turn for the better, I'm going to close this thread.
I have mailed my results to a few professors ,none of whom have responded.
applying mellins transform to get:
[tex] \zeta (s) = \frac{1}{s-1} -
s \int_0^1 h(x) x^{s-1} \, dx [/tex]
[tex] \phi : \kappa \longrightarrow\sigma [/tex]
where h(x) is the gauss kuzmin wirsing operator
[tex] \int_0^(pi/2)\ 1\fract 1\ sqrt{sin\theta - 1 }{2!cos\theta-1}... \dx ~ 1/ log 3! + 1/ log 5! + 1/ log 7![/tex] in continued fractions.
is this known ?
please try to correct the latex, I cannot get it to display my results.
Spaces are helpful. Use them liberally. And don't use a backslash (\) unless you're actually trying to invoke a LaTeX command, like the command "\int" to get it to produce an integral, or the command "\frac" to produce a fraction.
I've edited your first LaTeX image in #11 to be what I think you want, as a demonstration. I also put some weird spacing in the code so you can see that you don't have to worry about it appearing in the output.
(You may need to reload the page to see the new image)
And, of course, you can click on the image or edit your post to see what the new LaTeX code looks like.
Borogoves..you can try to submit your work to "clatech math archive" or something similar they seem to accept math and physics papers...
By the way could anybody write the Gauss-Kuzmin operator h(x)?..thanks.
The dirichlet series [itex]\sum_{n=1}^\infty n^{-s}[/itex] converges when the real part of s is greater than 1, not when it's norm is greater than 1. real part of s greater than 1 implies the norm is greater than 1, but the converse is not true. You may consider this a "niggling remark", but mistakes like this make people stop reading and not bother responding to you.
You mean h(x) is the Guass map here: h(x)=1/x-[1/x] where [] denotes the floor. The gauss-kuzmin-wirsing operator is the frobenius-perron operator of this map (or the transfer operator, or other names), though it's relation to zeta is similar.
I don't know where "phi", "kappa", or "sigma" came from though.I suggest you take a look at https://www.physicsforums.com/showthread.php?t=8997 for some latex info. Take the time to present whatever it is you are doing in a legible manner. The less effort it takes to decipher your posts, the better the responses you'll get. A quick latex tip, {} are used for grouping things like
[tex]\sum_{n=0}^{blah\ blah\ blah}\sqrt{\frac{2}{blah\ blah}}[/tex]
the method by borogoves is somehow described in the web:
http://en.wikipedia.org/wiki/Gauss-Kuzmin-Wirsing_operator
[tex] \zeta(s)=(s/s-1)-s\int_{2}^{1}dxG[x^{s-1}] [/tex]
then i don,t know how he managed to get an asymptotic¿? approach to this integral..the idea is not bad but perhaps it could be mor useful to describe a Gauss-Kuzmin operator so:
[tex] \sum_{p}p^{-s}=(s/s-1)-s\int_{0}^{1}dxG_{p}[x^{-s+1}] [/tex]
1. What is the Riemann Hypothesis?
The Riemann Hypothesis is a famous mathematical conjecture proposed by German mathematician Bernhard Riemann in 1859. It states that all non-trivial zeros of the Riemann zeta function lie on the critical line with a real part of 1/2.
2. Why is the Riemann Hypothesis important?
If proven true, the Riemann Hypothesis would have far-reaching implications in number theory and other areas of mathematics. It would also have practical applications in cryptography and coding theory. Its proof has been called the "holy grail" of mathematics.
3. What is the current status of the Riemann Hypothesis?
The Riemann Hypothesis remains unsolved and is considered one of the most challenging and significant open problems in mathematics. Many mathematicians have attempted to prove or disprove it, but it remains unproven to this day.
4. How would one go about proving the Riemann Hypothesis?
There is no one definitive method for proving the Riemann Hypothesis. Many attempted proofs have relied on complex mathematical techniques and have ultimately been unsuccessful. The consensus among mathematicians is that a new, groundbreaking approach will be needed to solve this problem.
5. What are some potential consequences if the Riemann Hypothesis is proven false?
If the Riemann Hypothesis is proven false, it could have significant implications for other areas of mathematics that have relied on it. It could also lead to a better understanding of the distribution of prime numbers and other fundamental mathematical concepts. However, there is no evidence to suggest that the Riemann Hypothesis is false, and many mathematicians believe it to be true.
  • General Math
  • Linear and Abstract Algebra
  • General Math
