Is having to borrow 40k $ in student loans a good deal for a MEng degree
In summary, the speakers discussed the value of obtaining a Master's degree, specifically in engineering. One speaker shared their experience of getting an MSEE from a top-10 public university for $10k out of pocket in 1991. They were able to pay off their loans quickly and found that the degree opened up many job opportunities and allowed them to work on more interesting projects. The speaker also noted that while it is possible to gain the same knowledge through on-the-job learning or taking classes at night, it is often difficult to find the time and focus to fully learn the core theoretical material. The speaker believes that the degree was the best "bang for the buck" in their academic background. However, they acknowledged that the decision to pursue
Link
134
At an Ivy League Engineering school
I have an MSEE from a top-10 public university which cost me about $10k out of pocket at the time (1991). I paid off my loans within a few years of entering the work force, and I would say that it has paid for itself many times over, not only in terms of better salary and a wider range of job opportunities, but more importantly for me, the knowledge obtained while working on the degree allows me to work on more INTERESTING things - in my case, in the field of signal processing and communication algorithms.
Could I have picked up the same requisite knowledge on the job or by reading or taking classes at night? In principle yes, but in practice most (but by no means all) engineers are too busy on the job and too occupied with other things at night to focus on seriously learning the core theoretical material associated with a strong master's degree. It's hard, hard work and (in my opinion) you can only do it justice by studying full time. I'm glad I did.
In terms of both financial and time commitment, I think the master's degree yielded the best "bang for the buck" of my entire academic background.
Only you can answer this question in your particular situation. But assuming you put that degree to good use once you have it, I doubt you would have any cause to regret it in the future.
Try to minimize loans by working part-time jobs. That was my approach.
$40K is a lot of debt for someone leaving university, and it will bite into one's cost of living later on, particularly if one wishes to attend graduate school.
Having a MEng degree is good, and better if one masters the material as reflected by high GPA.
you have to go to graduate school after getting an MEng? I thought it was equivalent to a masters degree, i.e unless going into research or academia it would be fully sufficient for working as a professional engineer?
No, he thought you were talking about a BS in ME. A master's of engineering is a graduate degree. That said, you aren't able to obtain any funding for your degree? TAing, RAing, anything?
An MEng is quite sufficient for working as a professional engineer. What type of engineering will your degree be in?
Its Mechanical/Aeronautical. I want to work for NASA someday:)
Yeah I do get some funding but my estimations show I have to borrow that much unless parents pay up, which isn't a nice thing to ask i guess:P
What about tuition waivers for TAing or RAing? Those usually come with a small stipend and benefits. $40k is a very large amount of debt. Do you have any debt from your undergraduate schooling?
Truth be told, I don't think it's worth $40k just to get a MEng from an Ivy League institution. You'll get the same jobs and a very similar salary by going to good public school. And the salary difference will be made up by not being $40k in debt!
If said Ivy is anyone other than Cornell, probably not.
No that money includes undergrad+grad. Does the deal get better?:P i read on the NYT that its quite normal for professional degrees students to graduate with 80-90k in debt (undergrad+grad) nowadays?
And won't the Ivy League label give more perks?:)
Oh and thanks, your responses are really useful and informative. Appreciate it:)
If one has an undergraduate engineering degree, then an MS or MEng is good. But still, try to minimize the loans, by working or getting an assistantship (teaching or research). Even getting out of grad school with $40K of debt is undesirable.
These days a professional should try to obtain at minimum a Master's degree, and in some cases a PhD is preferable, depending on the field of science or technology. Of course, one can return years later for a PhD, but that becomes difficult if one has a family.
So the $40k would cover both undergraduate and graduate school? Like a two-in-one program? $40k for both degrees is not bad at all.
As for graduating with $80-$90k in debt being normal, I find that hard to believe with respect to engineering and science students. I did not have to pay for graduate school and neither did any of my friends. We were TAs and RAs. Debt from undergraduate school is more common in science and engineering than debt from graduate school.
The Ivy League label will give perks, sure, but not $40k for grad school worth of perks. It might be easier to get interviews, you might get a slightly higher salary, and you'll potentially have access to some fantastic professors.
However, it sounds like YOU want that Ivy League label. There's nothing wrong with that, but you should know that going $40k into debt is not something to be taken lightly.
If you have aspirations of being a professor, the Ivy League label will help more there than in industry. But you're going for what is considered a terminal degree, so it does not sound like you want to enter academia.
Normally "professional degree" implies a doctor or lawyer, so $80k-$90k in that case wouldn't be too surprising.
Maybe it's because I'm in California and see so many barely literate jackasses with $40k loans for CARS (not to mention $800k loans for houses, but let's not even go there) that I can't really find fault with a guy investing $40k for a degree - or is it degrees - that will pay him dividends for his entire career, assuming he puts it to good use.
And my opinion holds even if he has cheaper options at public universities: better in my opinion to go to the school you really want to attend (as long as it's worth it to you), because life doesn't come with a rewind button and you won't get a chance to go back and do it the way you really wanted to.
so how much do you think would be appropriate to borrow in my situation?
1. Is it worth taking on $40,000 in student loans for a MEng degree?
The answer to this question depends on various factors such as the cost of the degree, potential salary after graduation, and the individual's financial situation. It is important to carefully consider the long-term implications of taking on such a large amount of debt.
2. How much will the monthly payments be for a $40,000 student loan?
The monthly payments for a $40,000 student loan will vary depending on the interest rate and repayment plan. It is important to carefully research and calculate the estimated monthly payments to ensure that they are manageable within one's budget.
3. Can I receive any financial aid or scholarships to help cover the cost of the MEng degree?
Yes, there are various forms of financial aid and scholarships available to students pursuing a MEng degree. It is important to research and apply for as many opportunities as possible to reduce the amount of student loans needed.
4. How long will it take to pay off $40,000 in student loans?
The length of time it takes to pay off $40,000 in student loans will depend on the repayment plan and the individual's ability to make consistent payments. It is important to carefully consider the repayment plan and budget accordingly to pay off the loans in a timely manner.
5. Will having a MEng degree increase my earning potential enough to justify taking on $40,000 in student loans?
The earning potential with a MEng degree will vary depending on the field and job market. It is important to research potential salaries and job opportunities in the desired field to determine if the potential increase in earnings will justify taking on $40,000 in student loans.
  • STEM Academic Advising
