Adding power flux densities from multiple sources
In summary, the power density (Pd in W/m^2) at a distance r (in meters) for a transmitting antenna with gain Gt is given by:Pd = ( Pt * Gt) / 4 * Pi * r^2 where Pt (in Watts) is the power transmitted from the antenna, Erms is the RMS electric field (in V/m) at the location, and 377 ohms is the intrinsic impedance of free space.
Wotwot
The Power density (Pd in W/m^2) at a distance r (in meters) for a transmitting antenna with gain Gt is given by:
Pd = ( Pt * Gt) / 4 * Pi * r^2 where Pt (in Watts) is the power transmitted from the antenna.
All these variables are scalar values so if there were multiple antennas and we wanted to calculate the total power density due to all of them at a given point, you could calculate the individual power density due to each one and add them together.
Now, the power density in the far field is also given by:
Pd = Erms^2 / 377
where Erms is the RMS electric field (in V/m) at the location and 377 ohms is the intrinsic impedance of free space.
Having already calculated the total power density, we can substitute it into the above equation and find a value for the total RMS electric field due to all the sources at the point of interest.
This is where things seem to go wrong.
The electric field is a vector quantity and so when multiple fields meet, they have to be added using vector addition. You can't add two RMS electric field values together unless they are totally in phase. However, using the above methodology, we seemed to have arrived at a value for the total RMS electric field. It would seem the answer has to be wrong because we haven't taken the phase differences into account. But since these equations are scalar, where do you do that?
Does anyone have any suggestions?
Pd = Erms^2 / 377
When the source signals are at the same frequency, then the relative phases of the receive signals at various points need to be taken into account. It's not so much a vector addition, it is a magnitude and phase addition problem.
If the sources are not at the same frequency, then adding the RMS powers would seem to work.
If we assume the frequencies of the multiple sources are the same, where in the above equations would you take phase information into account. OR is it implied that simple power density additions cannot be done for same frequency sources?
You would calculate the each E(r) magnitude and phase, add the resulting E(t) components at the receiving point, and use your equation for the power.
You will end up with nulls and anti-nodes for a radiation pattern from an antenna array:
http://en.wikipedia.org/wiki/Phased_array
As a scientist, it is important to always consider all factors and variables in a given situation. In this case, it is essential to take into account the phase differences between the multiple sources of power. This can be done by using vector addition to calculate the total electric field at the point of interest.
One approach could be to use the complex representation of the electric field, which takes into account both magnitude and phase. By adding the complex electric fields of each source, you can then take the magnitude of the resulting complex field to find the total RMS electric field.
Another approach could be to use the principle of superposition, which states that the total electric field at a point is equal to the vector sum of the individual electric fields at that point. This can be applied to the RMS electric fields as well, taking into account their phase differences.
It is also important to note that in real-world scenarios, the power density and electric field will vary at different points due to factors such as distance and obstacles. Therefore, it may be necessary to use numerical methods, such as numerical integration, to accurately calculate the total electric field at a given point.
Overall, it is crucial to consider all variables and use appropriate methods to accurately calculate the total electric field when adding power flux densities from multiple sources.
1. What is a power flux density (PFD)?
A power flux density is a measure of the power per unit area received from a radiation source. It is typically expressed in units of watts per square meter (W/m2).
2. Why would I need to add PFDs from multiple sources?
In many scientific and engineering applications, it is necessary to take into account the combined effects of multiple sources of radiation. Adding PFDs from different sources allows you to determine the total PFD at a given point in space.
3. How do I calculate the total PFD from multiple sources?
To calculate the total PFD from multiple sources, you simply add the individual PFDs together. This assumes that the sources are not interfering with each other, and that they are all contributing to the PFD at the same location.
4. What is the importance of adding PFDs from multiple sources accurately?
Adding PFDs from multiple sources accurately is important for ensuring the safety and efficiency of various systems, such as telecommunications networks, satellite communications, and wireless devices. It also allows for more accurate analysis and prediction of the effects of radiation on the environment and human health.
5. Are there any limitations to adding PFDs from multiple sources?
Yes, there are some limitations to adding PFDs from multiple sources. This method assumes that the sources are not interfering with each other, which may not always be the case. Additionally, if the sources are not all contributing to the PFD at the same location, a more complex calculation may be necessary.
