Hysteresis losses in an inductor - resistance proportional to frequency?
In summary: Also covers eddy currents a bit.For eddy currents see http://en.wikipedia.org/wiki/Eddy_currentFor the skin effect see http://en.wikipedia.org/wiki/Skin_effect. The skin thickness δ is inversely proportional to the square root of the frequency. This means the resistance is inversely proportional to δ.Power inductor and transformer cores are constructed in laminations isolated electrically from each other to minimize eddy currents. Skin effect is in the wires, not the core, far as I know, but I cold well be wrong - anybody? Low-signal inductors sometimes use powdered iron to effect the same thing.
Silversonic
130
Consider an inductor, with a core of ferromagnetic material, connected to an a.c. power supply. Explain why the contribution of the hysteresis losses to the resistance of the coil is theoretically proportional to the frequency of the oscillator.
The energy lost per second, i.e. the power, is simply the amount of times the hysteresis loop of the material is 'completed'. So the power used is proportional to the frequency. However, how do I then show from this that the resistance is also proportional to the frequency? It feels like I'm over-simplifying it, but is it simply because I^2 = P/R and since I is not proportional to the frequency, this means R is? I've looked hard, and it may be simple. A textbook of mine says to consider representing the hysteresis losses as a resistor in parallel with the inductor - why parallel? I would have assumed the correct approach would be to consider it in series - after all, in a circuit diagram we consider the resistance of an inductor as being placed in series with the inductor.
You got started off right - the loss is proportional to frequency since frequency = no. of times the loop is traversed per second. The energy dissipated per cycle is proportional to the area within the loop. The additional increase in R with frequency, on top of the above loss mechanism, is due to skin effect, eddy currents, etc.
As for R in series vs. in parallel with L - it can be either way. In either case you get, for a given frequency, a real component plus a positive reactive component. With series it's R + jwL, with parallel it's wL/√(1 + w2L2/R2)exp{j(π/2 - tan-1wL/R)}. The argument in the exponent is always positive.
Hey thanks for the reply. I've taken note of the skin effect and eddy currents too, but how would you show that this increase in R with frequency is proportional?
Also, doesn't the skin effect only effect the currents in the core, but not the circuit? I know that the skin effect cancels out the field in the interior of the core, and thus lowers the inductance.
As I said, it's the area under the B-H curve, as defined by the H end-points (proportional to excitation current). It should be intuitive that the more times the curve is traversed, the more the power loss, since each traverse represents so many Joules of energy. If the energy per traverse is Q, then power loss = fQ.
Eddy current power loss is proportional to the square of the frequency. Also covers eddy currents a bit.
Power inductor and transformer cores are constructed in laminations isolated electrically from each other to minimize eddy currents. Skin effect is in the wires, not the core, far as I know, but I cold well be wrong - anybody? Low-signal inductors sometimes use powdered iron to effect the same thing. Other core materials are inherently electrically non-conducting.
Thanks for the help Rude_man. I apologise but there is one thing that is not intuitively obvious to me;
I understand completely that the power less is proportional to the frequency of the oscillator and that was what I originally understood. What is not intuitive to me is how this means the resistance is proportional also. Maybe because it's so simple that it essentially goes without saying. I would be fine if the answer is because the current is completely independent of the frequency and thus (R = P/I) the resistance is proportional. I believe this is true.
This is what I have been given for the theory explanation of this experiment;
"At higher frequency the more effectively do the induced currents cancel the field in the interior of the core. This leads, at high freq., to the skin effect where the field and eddy current are confined to a surface layer whose thickness is δ. The variation of the inductance is associated with the skin depth".
Although it does not state where this skin effect occurs, the core or the circuit, it specifically mentions that the eddy currents, which form in the core, witness the skin effect as opposed to the currents in the circuit. I have here no mention that the skin effect has any effect on the resistance of the inductor, only its inductance. Although if the skin effect DOES have an effect on the current of the circuit then it WOULD make sense to me how the resistance of the circuit/inductor would be affected. Later it goes on to mention that the variation of resistance is associated with energy dissipation (with no mention of the skin effect).
For constant current, which implies constant H, power dissipation goes as R, right? P = i2R. If you understand that power loss is proportional to frequency in the hysteresis curve, then it follows at once that R is proportional to frequency, right? That's just basic logic, if A=B and B=C then A=C.
However, this does assume constant current. If you assume constant voltage, then H drops with frequency (since L goes up and so does reactance wL) and the entire hysteresis curve takes on a new shape.
I have no quarrel with your text - obviously it's a wider source of info than me. But I know this: skin effect results in resistance increase in wires! Look at the website I sent you. I quote from a section of it: " The skin effect causes the effective resistance of the conductor to increase at higher frequencies where the skin depth is smaller, thus reducing the effective cross-section of the conductor. The skin effect is due to opposing eddy currents induced by the changing magnetic field resulting from the alternating current. "
It should be easy to be convinced that if you reduce the cross-sectional area of a wire, that the resistance increases!
P.S. resistance is always associated with energy dissipation. Pretty hard to get around i2R!
1. What is hysteresis loss in an inductor?
Hysteresis loss in an inductor is the energy that is dissipated as heat due to the magnetic properties of the inductor's core material. It occurs when the magnetic field in the core is repeatedly switched back and forth, causing the material to heat up and lose energy.
2. How does hysteresis loss affect the performance of an inductor?
Hysteresis loss can cause a decrease in the efficiency of an inductor, as the energy that is lost as heat is not contributing to the intended output of the inductor. This can also lead to an increase in the temperature of the inductor, which can affect its overall lifespan and reliability.
3. Why is hysteresis loss proportional to frequency?
Hysteresis loss is directly proportional to frequency because as the frequency of the alternating current passing through the inductor increases, the rate at which the magnetic field is switched back and forth also increases. This results in more frequent and faster changes in the magnetic field, leading to a higher amount of energy being lost as heat.
4. How can hysteresis loss be minimized in an inductor?
One way to minimize hysteresis loss in an inductor is to use a core material with a lower hysteresis coefficient. This means that the material will dissipate less energy as heat when subjected to changing magnetic fields. Additionally, designing the inductor with a lower frequency of operation can also help reduce hysteresis losses.
5. Are hysteresis losses present in all types of inductors?
Yes, hysteresis losses are present in all types of inductors. However, the extent of the losses may vary depending on the type of core material used and the frequency of operation. For example, inductors with iron cores have higher hysteresis losses compared to those with ferrite cores.
  • Electrical Engineering
  • Classical Physics
  • Electromagnetism
11K
