(Structural Analysis) Moment Distribution Method: Help?
In summary, the beam on pg 7 of the pdf uses a modified stiffness factor for all 3 spans, while the beam on pg 2-3 uses 4EI/L for the fixed span and 3EI/L for the span that is pinned. However, the beam on pg 7 of the pdf is solved in one step, while the beam on pg 2-3 is solved in a more complicated way.
Khamul
24
Hello everyone, as the thread title implies, I'm in a bit of a bind when it comes to understanding the Moment Distribution Method for displacement methods of analysis.
In particular, I am having a lot of trouble in determining Stiffness Factors. I have attempted to browse my book and online for clarification, but I feel like every source I look at contradicts the other.
For example...page two and page three of this pdf:
http://www.sut.ac.th/engineering/civil/courseonline/430332/pdf/04_MomentDistribution.pdf
It states that if the far end member is fixed, then the stiffness factor, K, is K=4EI/L. Okay.
But page 4 of this pdf then goes on to state that K(ab) = 3EI/L, even though the far end D on this is fixed.
Could someone please help me make sense of this? :(
1) You can always use 4EI/L for all members. If you choose to do this, then the moment distribution process will be a bit longer and you will have to repeatedly "carry-over" the moments back and forth until they become small enough ("small enough" is based on your own judgement).
2) Alternatively, you can use the "modified stiffness" moment distribution method. In this case, one way to do it for your beam is to observe that there is a pin at the end of one of the spans. This means that you can choose to use 3EI/L for that span. Leave the other spans as 4EI/L. The advantage, in general, of using a "modified stiffness" is that you only "carry-over" the moments one-time.
It is unfortunate that the beam in question is not solved by either method 1) or 2) in your attached file, even though they mention both of these methods on pg 2, pg 3, as you mentioned (or did I just miss it?). Nevertheless, it appears that they solve a variety of problems later on...
Note the beam on pg 7, for example -- Here, they use a modified stiffness factor for all 3 spans. They get the 2EI/L by observing "symmetry" in the first span. This problem is solved in one step, but it is a simpler problem. Later on, in other examples, 6EI/L pops up, which is the modified stiffness factor for "anti-symmetry."
I've attached my own notes on the subject. It's only 8 pages, and would probably be worth your time if you are still "in a bind." It is adapted from "Elementary Theory of Structures" by Hsieh and Mau. Back when I learned this stuff that was the best text on the subject. I think Hibbeler has since gotten in on the action.
  • afreiden_moment_dist_no_joint_trans.pdf
1. What is the Moment Distribution Method?
The Moment Distribution Method is a structural analysis technique used to determine the forces and moments within a structure by considering the distribution of moments at each joint. It is commonly used for analyzing statically indeterminate structures.
2. How does the Moment Distribution Method work?
The Moment Distribution Method involves breaking down a complex structure into smaller elements and analyzing each element separately. The method uses the principle of virtual work to distribute the moments at each joint until equilibrium is achieved, allowing for the determination of forces and moments within the structure.
3. When is the Moment Distribution Method used?
The Moment Distribution Method is typically used for analyzing statically indeterminate structures, meaning structures that cannot be fully analyzed using traditional methods such as equations of equilibrium. It is also commonly used for analyzing structures with non-linear behavior or complex loadings.
4. What are the advantages of using the Moment Distribution Method?
Compared to other structural analysis methods, the Moment Distribution Method is relatively simple and straightforward. It also provides accurate results for both linear and non-linear structural systems. Additionally, it can handle complex loading conditions and can be applied to a wide range of structural types.
5. What are the limitations of the Moment Distribution Method?
Although the Moment Distribution Method is a useful tool for structural analysis, it does have some limitations. It is not suitable for analyzing structures with large displacements or significant changes in stiffness. Additionally, it can be time-consuming for larger and more complex structures, and it may not provide accurate results for structures with irregular geometries or loadings.
  • General Engineering
