JesseWendt
- 5
Need help with motor sizing/torque calculation - Building a Ski Rope Tow.
I am building a homemade ropetow in my backyard. I have done a lot of research and unfortunately I have been away from physics for about 15 years, so I am having trouble calculating my motor size and transmission options. I will lie out what I am trying to accomplish below.
Here are the specs:
-The hill is 300 feet long at a 20% grade
-The rope is approximately 650 feet long and 200 lbs.
-I can use anywhere between a 1 to 2 hp motor operating at 1750 RPMs (would prefer to stay on 110 power and definitely can't go to 3 phase)
-The gear reducer can be 10:1 15:1 or 20:1
-The pulleys to attach to the output shaft range from 6" to 14" mostly in even numbers.
-I would like to be able to pull three 200 lb people up said rope at once
-I would like the rope speed to be approximately 7-10 fps.
I am open to ideas. I have nothing purchased at this point.
My plan was to use a 15:1 reducer with a 14" pulley for speed that works out to
1750rpm/15 = 116.667 RPM output
circumference of pulley is 3.663'
speed is 427.39011 feet/minute or 7.1 fps
This would be completely fine for speed if it can handle the load. My biggest concern is not overloading the motor.
Any help or suggestions would be appreciated.
Jesse
Here are the specs:
Jesse
