Calculating critical density of mass, from Hubble time, for exercise
In summary, Jorrie's calculator (Lightcone) helps calculate cosmic history tables, including the Hubble times in past years. The basic facts are that Θ = 1/H and the Hubble radius R = cΘ. By using the formula ρ = 3/(8πG Θ^2) and replacing Θ with Hubble time, one can calculate the critical density of mass in various units. For example, in g per m^3, it is 8.66146267 × 10-24 g per (m^3). In amu per cubic meter, it is 5.2160552 amu per (cubic meter). This means that the critical mass density of
marcus
Dearly Missed
24,775
792
Jorrie's calculator (Lightcone) makes cosmic history tables which tell you among other things the Hubble times in past years. For convenience let's temporarily use greek Theta Θ to stand for THubble so we don't have to write so much.
Basic facts (definitions actually) are that Θ = 1/H and the Hubble radius R = cΘ.
Someone asked me this recently: if they want to work out critical density of mass they use:
ρ = 3/(8πG Θ^2)
And replace Θ with Hubble time.
What mass unit would this be in? And would they have to convert it at all?
I think that's a good simple exercise in quantitative cosmology so I want to reply to the question in open thread. I use google calculator:
If you open Lightcone it tells you the current Hubble radius R = 14.4 billion lightyears. So that means Θ = 14.4 billion years.
So you can type this into the google window:
3/(8 pi G (14.4e9 years)^2)
If you paste that into google window, you get:
8.66146267 × 10-27 kg / m3
So that is the answer to the question "what mass unit would it be in?" Google tends to give you answers expressed in standard metric units, like kilogram. If you want the answer in grams per cubic meter then you should type this in:
3/(8 pi G (14.4e9 years)^2) in g per m^3
If you paste that in, it will realize you want the answer in terms of g per m^3 and it will say:
Or you can paste in:
3/(8 pi G (14.4e9 years)^2) in g per cubic kilometer
and then it will tell you:
8.66146267 × 10-15 g per (cubic kilometer)
Basically you get the answer in whatever units you want and specify to your calculator.
Likes 1 person
Space news on Phys.org
I got to thinking about what units would be more meaningful and tried typing in this:
3/(8 pi G (14.4e9 years)^2) in amu per cubic meter
If you paste that into google you get:
So that is the mass of about 5 hydrogen atoms. In a cubic meter.
An "amu" (atomic mass unit) is officially 1/12 of the mass of a carbon atom which consists of 6 protons and 6 neutrons surround by 6 electrons---the common isotope of carbon.
So a hydrogen atom masses about 1 amu, and an oxygen atom masses about 16 amu, and a water molecule masses approximately 18 amu.
So you can see that the critical mass density of the U as a whole is on average about 5 hydrogen atoms per cubic meter. Only a small fraction of that is ordinary matter!
The conventional critical density needs to be discounted for the cosmological constant by this amount
3/(8 pi G (17.3e9 years)^2)
If you just want MATTER (dark and ordinary) then paste in
3/(8 pi G (14.4e9 years)^2) - 3/(8 pi G (17.3e9 years)^2)
And THAT makes more sense to evaluate in atomic mass units, so try:
3/(8 pi G (14.4e9 years)^2) - 3/(8 pi G (17.3e9 years)^2) in amu per cubic meter
When I put that in, I get:
1.60216497 amu per (cubic meter)
so the mass of about 1.6 hydrogens in a cubic meter, but 85% of that is dark matter so only 15% is ordinary, and 15% is 0.24 amu per cubic meter.
So only about a QUARTER of a hydrogen atom's worth of ordinary matter in a cubic meter
1. What is the critical density of mass?
The critical density of mass is the amount of matter per unit volume that would result in a flat universe. It is a theoretical concept used in cosmology to understand the overall density of the universe.
2. How is the critical density of mass calculated?
The critical density of mass is calculated using the Hubble time, which is the inverse of the Hubble constant. This constant is used to measure the rate of expansion of the universe. The formula for calculating the critical density is: ρcrit = 3H^2/8πG, where ρcrit is the critical density, H is the Hubble constant, and G is the gravitational constant.
3. What is the significance of calculating the critical density of mass?
The critical density of mass is important because it helps us understand the overall structure and fate of the universe. If the actual density of the universe is greater than the critical density, it will eventually collapse under its own gravity. If it is less than the critical density, the universe will continue to expand forever. The critical density also provides insight into the amount and types of matter present in the universe.
4. How does the Hubble time factor into calculating the critical density of mass?
The Hubble time is used in the calculation of the critical density because it is directly related to the expansion rate of the universe. The Hubble constant, which is used in the formula for critical density, is equal to 1/H, where H is the Hubble time. This means that the Hubble time is the inverse of the Hubble constant and is therefore an integral part of the calculation.
5. Are there any limitations to calculating the critical density of mass?
While the critical density of mass is an important concept in understanding the universe, its calculation is based on several assumptions and simplifications. For example, it assumes a homogeneous and isotropic universe and does not take into account the effects of dark matter and dark energy. Additionally, the value of the Hubble constant is still a topic of ongoing research and debate, which can affect the accuracy of the calculated critical density.
  • Cosmology
  • Cosmology
