New Reply
Experimentally measuring torque.
Share Thread Thread Tools
Jul4-12, 07:05 AM   #1
What experimental methods are there for measuring the static (and dynamic if possible) torque required to turn a simple tooth gear? This tooth gear is used to rotate 4 wheels, 2 of which are connected to the shaft and 2 are on another shaft with the two shaftes connected with a toothed belt to rotate both.
I know i could use a torque sensor but was wondering what other methods there was.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Jul6-12, 03:41 AM   #2
In our testfield we used calibrated DC-motors. Calibrated means we had the motors on a braking rig first to assess velocity / power / current characteristics. DC-motors for the ability to run at diffeent speeds. Once you know the shaft power and speed required to rotate your gear, you can compute the torque easily.
Jul6-12, 08:29 AM   #3
Depending on the accuracy you need to achieve, a simple torque wrench might be able to give you a reasonable value.
New Reply
Tags
experiment, measuring torque, torque
Thread Tools
Similar Threads for: Experimentally measuring torque.
Thread Forum Replies
Experimentally Calculate Wind Turbine Torque Classical Physics 3
Measuring drag coefficient experimentally Classical Physics 4
Question about Experimentally Measuring Mass Chemistry 1
Measuring Interference Experimentally General Physics 0
measuring torque Classical Physics 6
