Find equation of tangent line given only x. Please help
In summary: That's the equation of the tangent line.Now, you were asked to find the equation of the tangent line to the curve y = (x^3 - 4x + 2)(x^4 + 3x - 5) at x = -1. The equation of the tangent line is y = 2x - 33. That's it, that's all you need to write.
111
Find equation of tangent line, given x = -1. Not given y. I am used to having this when I am given both y and x.
Differentiate
(3x^2 - 4)(4x^3+3)
Multiply
12x^5 - 9x^2 - 8x^3 - 12
Plug in -1, find slope
12(-1)^5 - 9 (-1)^2 - 8(-1)^3 - 12
= -5.3
Plug in -1 to the original equation to find Y
-35
Find equation
y1- = m (x1 - x2)
y+35 = -5.3 (x+1)
y+35 = -5.3x -5.3
y = -5.3x - 5.3 - 35
y = -5.3x -40.3
I have a feeling this is wrong though, because I have gotten many similar questions wrong. How can I figure this out?
Differentiate
(3x^2 - 4)(4x^3+3)
Multiply
= -5.3
-35
Find equation
y1- = m (x1 - x2)
y+35 = -5.3 (x+1)
y+35 = -5.3x -5.3
y = -5.3x -40.3
Hello 939. Welcome to PF !
When you graph the function, (x3 - 4x + 2)(x4 + 3x - 5) , what is y ?
SammyS said:
Hello 939. Welcome to PF !When you graph the function, (x3 - 4x + 2)(x4 + 3x - 5) , what is y ?
Hi Sammy, thanks!
When I graph it, y is -35 exactly.
Knowing y and x, is it possible to find the equation doing:
y-y1 = m (x-x1)
y+35 = -5.3 (x+1)
etc?
I'm assuming that the equation is y = (x^3 - 4x + 2)(x^4 + 3x - 5)
939 said:
Differentiate
(3x^2 - 4)(4x^3+3)
If y = f(x) * g(x), dy/dx [itex]\neq[/itex] f'(x) * g'(x), which is what you seem to be doing here. You should be thinking "product rule."
939 said:
Multiply
= -5.3
-35
Find equation
y1- = m (x1 - x2)
y+35 = -5.3 (x+1)
y+35 = -5.3x -5.3
y = -5.3x -40.3
Sorry, yes you are right about the equation. And regarding the product rule yes, you are also right!
So, when I find it using the product rule, I insert the -1, and then that gives me the slope?
So the product and then plugging in gives me 2...
Provided I did that right, can I find the equation by doing:
y+35 = 2(x+1)
= 2x+2 - 35, I believe...
y+35 = 2(x+1)
Your arithmetic is correct, but you're being sloppy in how you present it.
Keep your equations separated. The first equation is y+35 = 2(x+1)
Add -35 to both sides to get a new equation y = 2x - 33
1. What is the equation of a tangent line?
A tangent line is a line that touches a curve at a single point, and has the same slope as the curve at that point. It can be represented by the equation y = mx + b, where m is the slope and b is the y-intercept.
2. Why is it important to find the equation of a tangent line?
Finding the equation of a tangent line is important because it allows us to determine the slope of a curve at a specific point. This information is useful in many applications, such as optimizing functions, finding the rate of change, and analyzing the behavior of a curve.
3. Can the equation of a tangent line be found with only the x-coordinate?
Yes, the equation of a tangent line can be found with only the x-coordinate. This is because the slope of a tangent line is equal to the derivative of the function at that point, which can be calculated using only the x-coordinate.
4. What steps are involved in finding the equation of a tangent line given only x?
To find the equation of a tangent line given only x, you will need to follow these steps:
  • 1. Find the derivative of the function using the power rule or another differentiation method.
  • 2. Plug in the x-coordinate into the derivative to find the slope of the tangent line at that point.
  • 3. Use the point-slope formula, y - y1 = m(x - x1), where m is the slope and (x1, y1) is the given point, to find the equation of the tangent line.
5. Are there any limitations to finding the equation of a tangent line with only x?
Yes, there are limitations to finding the equation of a tangent line with only x. This method only works for functions that are differentiable at the given point. If the function has a sharp point or cusp at the given x-coordinate, the tangent line cannot be found using this method.
