Register to reply
About lighting strikes and sources
by bottecchia
Tags: lighting, sources, strikes
Share this thread:
bottecchia
#1
Nov29-13, 10:47 AM
P: 3
Hello everyone.
I would like to know why we simulate in programs like atp lighting strikes with current sources and not with voltage sources.
Could anyone help?
Thank you :)
Phys.Org News Partner Engineering news on Phys.org
Eye implant could lead to better glaucoma treatment
Electricity helping the blind navigate
Lawsuits challenge US drone, model aircraft rules (Update)
mfb
#2
Nov29-13, 11:31 AM
Mentor
P: 11,869
No idea about lightning strike simulations, but from the electrics side:
If you put a small resistor (whatever gets hit by lightning) in series with a large resistor (all the air) and attach it to a voltage source (cloud-ground), the current through the resistors doesn't depend significantly on the resistance value, but voltage does.
bottecchia
#3
Nov29-13, 11:58 AM
P: 3
so why we cannot simulate the lightning strike with a voltage source?
we will have a small resistance and a high voltage so we will produce a high current between the cloud and the ground.
does anyone know what is wrong in my thoughts?
nsaspook
#4
Nov29-13, 12:37 PM
P: 641
Quote Quote by bottecchia View Post
It's represented by the equivalent of a current source because once we exceed the breakdown voltage of air to the grounding point the measured current is almost equal to the short circuit current for a wide range of path resistances (a high impedance source). The impedance of the object in the path of current flow determines the amount of voltage generated across that object as the voltage will rise to the level needed to maintain constant current.
bottecchia
#5
Nov29-13, 03:40 PM
P: 3
Quote Quote by nsaspook View Post
wow..... thank you man you are my hero... :)
mitre
#6
Dec2-13, 12:51 PM
P: 1
Could you be more specific?
nsaspook
#7
Dec3-13, 10:43 PM
P: 641
Quote Quote by mitre View Post
This mighty help.
http://www.dehn-usa.com/manager/file...Img&idValue=38
davenn
#8
Dec3-13, 10:57 PM
Sci Advisor
PF Gold
davenn's Avatar
P: 2,629
thanks nsaspook
nice informative link
Dave
Register to reply
Related Discussions
Generators - Voltage Sources or Current Sources? Electrical Engineering 7
Lighting strikes Classical Physics 21
Lighting a candle, blowing it out and relighting it by lighting the smoke? General Physics 3
Why are most electrical sources, voltage sources? Electrical Engineering 4
The lighting. Forum Feedback & Announcements 5
