Difference between gapless excitations and Goldstone bosons
In summary, gapless modes refer to excitations that require an infinitesimal amount of energy, while Goldstone modes/bosons emerge in systems where a continuous symmetry is spontaneously broken. However, a gap may develop in a previously gapless mode if additional interactions are introduced. Gapless modes can also be described using fundamental equations in a "relativistic" form, even though they may not exhibit true relativistic effects.
sam12
I have been looking around on the web and in books to clarify this, but can't find a good explanation describing relationship/difference between gapless modes/excitations and Goldsone modes/bosons in Condensed matter physics.
Does the term "gapless modes" mean that no energy is required for these modes/excitations or that only an infinitesimal amount of energy is required for such excitations? If Goldstone modes/excitations require some(small) amount of energy (as mentioned in Ref:http://web.mit.edu/8.334/www/lectures/lec3.pdf), how can they ever be gapless?
Does a previously gapless mode/excitation develop a gap or remain gapless if a continuous symmetry is spontaneously broken in a system?
Gapless means that it takes an infinitesimal amount of energy to excite some mode. We are comparing energy to the vacuum state, so even if there is no gap, an excitation will still have at least kinetic energy. In a gapless spectrum this energy can be arbitrarily small, as in eq. (II.14) of those notes. In a theory with a mass gap, the lowest-energy excitations have a finite energy (with respect to the vacuum) even at zero momentum. Typically this has the interpretation of either a physical or effective mass of the particle states of the theory.
The Goldstone mechanism explains how a gapless mode emerges in a vacuum where a continuous global symmetry is broken. The Landau-Ginzburg model in eq (II.12) is a good example. If we consider the spectrum of fluctuations around ##\psi = 0##, we find a mass gap set by the parameter ##\sqrt{t}##. However, ##\psi = 0## is not the true vacuum of the theory when ##t<0## (and ##\sqrt{t}## becomes imaginary). If we minimize the Hamiltonian and expand around ##\bar{\psi}## we find that the excitations can be described by the gapless mode ##\theta(x)##.
It is possible for a system to develop a mass gap if we allow additional interactions. For instance, if we couple the complex scalar ##\psi(x)## in the LG model to a gauge field, we will find a mass gap. In the false vacuum we have the massive field ##\psi(x)## and a massless gauge field ##A_\mu(x)##. In the true vacuum, we have a massive real scalar ##\bar{\psi}## and a massive gauge field ##B_\mu(x)##, that is actually composed of the 2 degrees of freedom from ##A_\mu## and the single degree of freedom from the would-be Goldstone boson ##\theta(x)##. This model is related to what is usually called the abelian Higgs model.
The gap mode vanishes in the limit k->0. So a long wavelength exitation looks different than the vacuum over a large extent of space, yet it is energetically practically degenerate, i.e. there are different vacuum states. That is the definition of a broken symmetry, so every gapless mode can be viewed as resulting from symmetry breaking. The other direction does not always work as interactions have to be short range for broken symmetry modes to be gapless.
In the context of field theory, a gap in dispersion relation really means a mass. So a gapless excitation, like goldstone boson, doesn't have a mass hence is always relativistic. This is like the situation of photon in relativity.
I would be careful with the word "relativistic". If E is a linear function of k for a gapless mode, then it may be called massless as it is dispersion free and hence a wavepacket will move with the constant speed v= E/hbar k. However, almost never does this speed coincide with the speed of light in vacuo, so it is certainly not relativistically invariant, which is already clear by the solid matrix forming a special system of reference.
I think this depends on what you mean by "relativistic". Of course in solids most gapless excitations don't move in the speed of light and real relativisitc effects are not present. But for gapless particles, fundamental equations in the "relativistic" form are often used to describe their motion, like slightly modified Dirac equations which is applied to electrons in graphene. This also gives us some analogous "relativistic" phenomenon in CMP.
1. What are gapless excitations and Goldstone bosons?
Gapless excitations and Goldstone bosons are both types of particles that can exist in certain physical systems. Gapless excitations are particles that have no energy gap between their ground state and excited states, while Goldstone bosons are particles that arise due to the spontaneous breaking of a continuous symmetry in a system.
2. What is the difference between gapless excitations and Goldstone bosons?
The main difference between gapless excitations and Goldstone bosons is that gapless excitations arise due to the properties of the system itself, while Goldstone bosons arise due to the breaking of a symmetry. Additionally, while gapless excitations have no energy gap between their ground state and excited states, Goldstone bosons have a small but non-zero energy gap.
3. How do gapless excitations and Goldstone bosons impact physical systems?
Gapless excitations and Goldstone bosons can have a significant impact on physical systems. For example, gapless excitations can lead to phenomena such as superconductivity and superfluidity, while Goldstone bosons can play a role in phase transitions and the behavior of magnetic materials.
4. Can gapless excitations and Goldstone bosons be observed in experiments?
Yes, both gapless excitations and Goldstone bosons have been observed in various experiments. In condensed matter physics, for example, gapless excitations have been observed in systems such as graphene and superconductors. Goldstone bosons have also been observed in experiments studying phase transitions and symmetry breaking.
5. Is there a relationship between gapless excitations and Goldstone bosons?
Yes, there is a relationship between gapless excitations and Goldstone bosons. In some cases, gapless excitations can arise due to the presence of Goldstone bosons, and the behavior of Goldstone bosons can be described using the same mathematical framework as gapless excitations. However, they are distinct phenomena with different origins and properties.
  • Atomic and Condensed Matter
  • STEM Academic Advising
  • Quantum Physics
  • Thermodynamics
  • Beyond the Standard Models
  • Other Physics Topics
