About incompatibility and interference terms
In summary: Substituting this into the previous equation, we get:|<c|a>|^2∑_b |<a|b>|^2 = |<c|a>|^2Which is the desired result. Similarly, if we assume that [B,C] = 0, we can show that the probabilities are equal.In summary, the equality of probabilities in the two experiments depends on the commutativity of the observables involved. If [A,B] = 0 or [B,C] = 0, then the probabilities are equal. I hope this helps clarify the issue. Thank you for your attention.
xboy
134
In Modern Quantum Mechanics page 44-46, Sakurai compares two experiments:
1. Here three observables A,B,C are measured. The probability of obtaining the results a,b and c respectively are then :(|<c|b>|^2)(|<b|a>|^2). Summing up over all values of b we'll find [tex]\Sigma[/tex][tex]_{}b/tex](<c|b>|)^2(|<b|a>|)^2
2. But if we don't measure B,the probability of getting c if we have already got a becomes|<c|a>|^2
So the two probabilities are different.According to Sakurai the two probabilities are equal is [A,B]=0 or [B,C]=0.
I'm trying to prove this but haven't been able to find a good proof yet.All help will be appreciated.
Thank you for bringing up this interesting topic from Sakurai's Modern Quantum Mechanics. The two experiments mentioned in the post are indeed different, and the equality of their probabilities depends on the commutativity of the observables involved.
To prove this, let's first define the probabilities mathematically. In the first experiment, we have three observables A, B, and C with the corresponding eigenstates |a>, |b>, and |c>, respectively. The probability of obtaining the results a, b, and c is given by:
P(a,b,c) = |<c|b>|^2|<b|a>|^2
Summing over all possible values of b, we get:
P(a,c) = ∑_b |<c|b>|^2|<b|a>|^2
On the other hand, in the second experiment, we have only two observables A and C, and the probability of obtaining c if we have already obtained a is given by:
P(a,c) = |<c|a>|^2
Now, to show that these two probabilities are equal, we need to prove that:
∑_b |<c|b>|^2|<b|a>|^2 = |<c|a>|^2
Expanding the left-hand side, we get:
∑_b |<c|b>|^2|<b|a>|^2 = ∑_b |<c|b>|^2|<a|b><b|a>| = ∑_b |<c|a><a|b><b|a>|^2
Using the identity |<c|a><a|b> = <c|b> (which can be derived from the completeness relation), we can rewrite this as:
∑_b |<c|a><a|b>|^2 = ∑_b |<c|a>|^2|<a|b>|^2
Now, if we assume that the observables A and B commute, i.e. [A,B] = 0, then we can rewrite the above as:
∑_b |<c|a>|^2|<a|b>|^2 = |<c|a>|^2∑_b |<a|b>|^2
Using the completeness relation again,
The concept of incompatibility and interference terms is a fundamental aspect of quantum mechanics that helps explain the behavior of particles at the quantum level. In the context of the two experiments described by Sakurai, incompatibility refers to the fact that the two probabilities are different when B is measured in the first experiment and not measured in the second experiment. This is due to the fact that in quantum mechanics, the act of measurement can affect the state of the system being measured.
Interference terms, on the other hand, refer to the mathematical terms that arise when multiple observables are measured simultaneously. In the first experiment, the interference term is given by the sum over all values of b, while in the second experiment, there is no interference term since B is not measured.
Sakurai's statement that the two probabilities are equal only when [A,B]=0 or [B,C]=0 is known as the compatibility condition. This means that if the operators A and B commute (i.e. [A,B]=0), then they can be measured simultaneously without affecting each other's results. Similarly, if B and C commute, they can also be measured simultaneously without interference.
To prove this, you can use the commutation relations [A,B]=AB-BA and [B,C]=BC-CB and substitute them into the expression for the probability in the first experiment. You will find that the sum over all values of b will simplify to just one term, which is equal to the probability in the second experiment. This shows that the two probabilities are equal when [A,B]=0 or [B,C]=0.
In summary, incompatibility and interference terms are important concepts in quantum mechanics that help explain the results of experiments involving multiple observables. The compatibility condition, as stated by Sakurai, provides a condition for when the two probabilities will be equal. Further exploration and understanding of these concepts will help deepen our understanding of the strange and fascinating world of quantum mechanics.
1. What is incompatibility and interference in scientific terms?
Incompatibility and interference refer to the inability of two substances or systems to coexist or function together without causing disruption or hindrance to each other's properties or processes.
2. How does incompatibility and interference occur?
Incompatibility and interference can occur due to various factors such as differences in chemical composition, physical properties, or competing reactions between the substances or systems.
3. What are the consequences of incompatibility and interference?
The consequences of incompatibility and interference can range from minor changes or disruptions in the properties or processes of the substances or systems to more severe reactions or failure to function altogether.
4. How can scientists identify and prevent incompatibility and interference?
Scientists can identify and prevent incompatibility and interference by conducting compatibility tests and considering factors such as chemical properties, environmental conditions, and potential reactions between substances or systems.
5. Are there any methods to mitigate the effects of incompatibility and interference?
Yes, there are methods to mitigate the effects of incompatibility and interference, such as modifying the chemical composition or physical properties of the substances or systems, changing environmental conditions, or using protective barriers or coatings.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
