Linear Transformations Confusion
In summary, the problem is that I don't know why T1 and T2 being linear implies that c1T1 + c2T2 is linear other than by noting that multiplying the transformations by c and adding them together is a linear combination, but that doesn't seem to be a very good proof. The second part there would seem to follow from this though just based on the fact that transforming some vector x is the same as multiplying it by the standard matrix of T.
Screwdriver
129
Not really a problem per se; more of an issue with some aspects of linear transformations. We've learned that a linear combination of linear transformations is defined as follows:
[tex](c_1T_1+c_2T_2)(\vec{x})=c_1T_1(\vec{x})+c_2T_2(\vec{x})\,\,\,\,\,\, \vec{x}\varepsilon \mathbb{R}^n\,\,\,c\varepsilon \mathbb{R}[/tex]
And if T1, T2 are linear, then so is c1T1 + c2T2 and
[tex][c_1T_1+c_2T_2]=c_1[T_1]+c_2[T_2][/tex]
Where [T] is the standard matrix of T and c is some constant.
The problem is, is that I don't know why T1 and T2 being linear implies that c1T1 + c2T2 is linear other than by noting that multiplying the transformations by c and adding them together is a linear combination, but that doesn't seem to be a very good proof. The second part there would seem to follow from this though just based on the fact that transforming some vector x is the same as multiplying it by the standard matrix of T.
Also, linear transformations don't make much sense in general. I was told that they're basically the same things as functions, but then all of a sudden we're adding them together and multiplying them left and right which never happened with f(x). Does that matter? Can I just think of those Ts as fs? If so, I think that will help a lot because, as it is, the T seems very strange and foreign to me.
I would appreciate any tips on such matters :smile:
What a transformation T being linear actually means is that T(a*x+b*y)=a*T(x)+b*T(y) where a and b are scalars and x and y are vectors. From that you shouldn't have any problems showing c1*T1+c2*T2 is linear if T1 and T2 are. I think you are confusing the consequences of a theorem with the definition of linear.
Thank you for your help.
So if T1 and T2 are linear then:
[tex]T_1(p\vec{x}+q\vec{x})= pT_1(\vec{x})+qT_1(\vec{x})[/tex]
and
[tex]T_2(r\vec{x}+s\vec{x})= rT_2(\vec{x})+sT_2(\vec{x})[/tex]
Where c, p, q, r and s are all constants.
I want to show that:
[tex]c_1T_1(p\vec{x}+q\vec{x}) + c_2T_2(r\vec{x}+s\vec{x}) = c_1pT_1(\vec{x})+c_1qT_1(\vec{x})+c_1rT_2(\vec{x})+c_1sT_2(\vec{x})[/tex]
If that's the case, then I'm pretty much done, since that result comes just by subbing in the definition of a linear transformation for T1 and T2 and distributing the c.
I really want to know about the function thing though; can I interpret transformations as functions, ie. think of T as f?
Sure you can think of them as functions. It's sort of implicit in the notation T(x), yes? What might be confusing you is that the product of two linear transformations T1 and T2 acting on a vector x is T1(T2(x)). It's really a composition of functions. That's not the same as the product of two real functions which would be f1(x)*f2(x). They are different things.
That's a huge relief :tongue:.
Yes, the T(x) notation makes sense. The problem is that we use square brackets a lot in the notion and I'm never quite sure whether or not it means the standard matrix or just square brackets for the sake of square brackets. I'm also not sure whether or not it matters since
[tex](T)(S)=T \circ S[/tex]
but also
[tex][T]=[T \circ S][/tex]
That might just be a coincidence (or completely wrong)?
I think it's probably a formal distinction between the linear transformation and its matrix. But in the end it doesn't make much difference, does it? The composition of two matrices is just the matrix product.
I see now. Thank you so much :smile:
1. What is a linear transformation?
A linear transformation is a mathematical function that maps a vector from one vector space to another vector space, while preserving the basic structure of the vector space. This means that the transformation preserves the operations of addition and scalar multiplication.
2. How is a linear transformation different from a regular transformation?
A regular transformation can involve any type of function, while a linear transformation specifically follows the rules of linearity. This means that for a linear transformation, the output is directly proportional to the input and the transformation can be represented by a matrix.
3. How do I know if a transformation is linear?
To determine if a transformation is linear, you can check if it follows the properties of linearity. These include the preservation of addition, scalar multiplication, and the transformation of the zero vector to the zero vector. You can also represent the transformation using a matrix and check if it satisfies the properties of matrix multiplication.
4. Can a linear transformation be applied to any type of data?
No, a linear transformation can only be applied to vector spaces. This means that the data must be represented as a set of vectors with defined operations of addition and scalar multiplication. For example, a linear transformation can be used for data in the form of coordinates, but not for categorical data or text.
5. What are some real-life applications of linear transformations?
Linear transformations have many practical applications in fields such as physics, engineering, and computer graphics. For example, in physics, linear transformations can be used to model the transfer of energy or the motion of objects. In computer graphics, they are used to rotate, scale, and translate images on a screen.
