Calculating Magnetic Force on Charged Particle in a Magnetic Field
In summary: i had two semester of calculus: differential and integral. taking 3rd and last semester of calculus in the fall. so yes, i have differential and integral.
warnexus
90
magnetic force = charge * velocity * magnetic field
they ask for distance but this was the only relevant equation for this problem to corresponding section
veloctity = 8.4* 10 ^ 6 m/s
magnetic field = 190 Gauss
perpendicular = sin (90) = 1
magnetic force = (1.6 * 10 ^ -19 C) (8.4 * 10 ^ 6 m/s )(190 G)
Which path do the electrons describe in the field?
This will help to solve the problem.
I would start by writing F= ma equations for all three axes. (Might two suffice?).
Good problem.
Good problem.
all 3 axes, even if z axis is not mentioned. we have to resolve components using a force diagram?
okay here goes:
F_x = m * a_x
F_y = m * a_y
F_z = m * a_z
What I alluded to is that perhaps one of the axes never sees any motion. Since mag force is always perpendicular to the B field, which axis do you suppose that might be?
PS certainly the z axis is in on this.
magnetic force perpendicular to the magnetic field. the y -axis is perpendicular!
Z-axis is the most important one...
And please, do not use cartesian coordinates to solve equations of motions. This is just overkill for this problem.
okay here goes:
F_x = m * a_x
F_y = m * a_y
F_z = m * a_z
OK, now what are F_x, F_y and F_z in terms of q, m, velocities, etc? Also, write x_double-dot in lieu of a_x, etc.
Request not granted :grumpy:. And the answer is in x, not z. :smile:
Right. So there are only two equations, in x and in z.
F_x is force in the x or force sub x(probably should have done that)
you mean like this:
F_subx = m* a..
F_subz = m* a..
you mean like this:
F_subx = m* a..
F_subz = m* a..
No. Look at what I wrote.
You need to introduce q, B, and velocity components in lieu of forces F_x etc.
For a_x you should write d2x/dt2 etc.
oh I see.
charge* velocity* magnetic field = mass * (d^2 * x)/(d*t^2)
may you explain how you got acceleration to be d^2 * x)/(d*t^2). I went through the chapter called amperes law where this question was associated with and don't see the equation like that of (d^2 * x)/(d*t^2)
d as in distance, t as in time, and what is x and we need to find time?
warnexus said:
oh I see.
d as in distance, t as in time, and what is x?
Question: have you had calculus incl. elementary differential equations? I never know what level of student I am dealing with.
This is a pretty sophisticated problem, involving coupled motions. I.e. the initial x velocity generates a z velocity, and the z velocity in turn generates an x velocity. I wouldn't try to solve this in a non-calculus manner. Maybe mfb knows how ...
i had two semester of calculus: differential and integral. taking 3rd and last semester of calculus in the spring
OK. Then I can say that I meant d2x/dt2 to be "the second derivative of x with respect to time". Aka "acceleration in the x direction". Etc.
My way you wind up with two second-order linear differential equations in x and z. Solve for x and there's your answer. The equation in x is the same you get from a spring-mass oscillator.
(You're not asked for the z solution which is similar but not exactly the same as a spring-mass oscillator).
oh i see. interesting.
btw how come magnetic field is given in Gauss, the previous questions that involved with magnetic field were given in Tesla? Wouldn't Tesla have to be used?
1 Tesla = 10,000 Gauss. Your teach is trying to make life even more miserable than it has to be ... tell him you won't do any more problems in any other than SI units... :smile:
Actually, pure physicists tend to use the cgs system which includes the Gauss. Applied physicists and engineers gravitate towards the SI system, aka 'rationalized mks" system ("meter, kilogram, second").
he did teach us how to convert units super fast in the first physics lecture. he really want us to convert units in some assigned problems. but it's for practice which I totally needed but am getting better at. for this one it would be :
90 Gauss * (1 Tesla/10,000 Gauss) = .009 Tesla.
okay now to plug these values in:
charge * velocity * magnetic field = (mass of an electron) (2nd derivative of position respect to time)
(1.6 * 10 ^ -9 C) * (8.4 * 10 ^ 6 m/s) (.009 T) = (9.1 * 10 ^ -31 kg) (2nd derivative of position respect to time.
well I am left with acceleration given as a constant value of 1.3 * 10 ^ 26 m/s^2 . I could integrate this twice if this was a function so I can get distance but its just a constant value
Right!
Don't mess with numbers now. You need to get your equations first.
So why not start with the z-axis. What does F = ma look like for it? Keep in mind that the velocity is in x and the B field is in y direction, so use the appropriate velocity component ...
Right, but the deflection in z-direction is important.
It is not. There is a very simple solution if you know some basics about that type of motion involved here.
rude man said:
Right!Don't mess with numbers now. You need to get your equations first.
well if we start with the z axis, the z axis is the axis that is towards you. there is no velocity in the z, so its zero
charge * velocity * magnetic field = m ( acceleration)
0 = m(acceleration)
mass * acceleration is also zero
Oh no? If the initial velocity is in the x direction and the B field is in the y direction, you don't expect to see any velocity buildup in the z direction?
Write your F = ma for the z axis.
is that because the direction of velocity is perpendicular to the magnetic field that's why there is velocity build-up?
i will try to write one out.
(charge) (velocity)(magnetic field) = (mass of an electron) (acceleration_sub z)
That's good, but which velocity component is the appropriate one?
Remember, F = qv x B is a vector equation.
(charge)(velocity sub_z)(magnetic field) = (mass of an electron) (acceleration sub_z)
Nope. What direction does the velocity have to be in order for the B field, which is in the y direction, to give motion in the z direction?
velocity would need to be in the y direction
No. Velocity has to be at right angles to the B field and to the z direction in order to produce motion along the z direction, right? And don't write the full names, use q for charge, B for mag field, v for velocity ...
BTW do you use vectors in your physics course?
Yes, Vectors was covered... Oh I see now! Kinematic Equations! Now I know.
  • #31
OK, so back to writing the equation for the z motion ...
  • #32
q v sin(90) B = m * a..
1. What is the formula for calculating magnetic force on a charged particle in a magnetic field?
The formula for calculating magnetic force on a charged particle in a magnetic field is F = qvBsinθ, where F is the force, q is the charge of the particle, v is its velocity, B is the strength of the magnetic field, and θ is the angle between the velocity and the magnetic field.
2. How do you determine the direction of the magnetic force on a charged particle?
The direction of the magnetic force on a charged particle can be determined using the right hand rule. Point your thumb in the direction of the particle's velocity, your fingers in the direction of the magnetic field, and the direction your palm is facing is the direction of the magnetic force.
3. What is the unit of measurement for magnetic force?
The unit of measurement for magnetic force is Newtons (N).
4. Can the magnetic force on a charged particle be zero?
Yes, the magnetic force on a charged particle can be zero if the particle is moving parallel to the magnetic field (θ = 0) or if the particle has no velocity (v = 0).
5. How does the strength of the magnetic field affect the magnetic force on a charged particle?
The strength of the magnetic field directly affects the magnetic force on a charged particle. The stronger the magnetic field, the greater the force on the particle will be. This can be seen in the formula F = qvBsinθ, where B is the strength of the magnetic field.
