Does my understanding of work, velocity, and friction make sense
In summary, when pushing a crate along the floor at a constant velocity, there is no work done because its velocity is constant. However, when considering work done on an object, you must consider the net force on the object, which is zero in the example.
Niko Bellic
Is this following correct? :
When you push a crate along the floor at a constant velocity for a long time, you get tired which indicates that you are tranferring some of your energy to the object, i.e. you are doing "work" on the object. But according to the definition of work[1] which equates work to a change in kinetic energy (change in velocity), there is no work done on the crate since its velocity is constant. This is because while you do in fact do work on the crate, the force of friction does equal work in the opposite direction of you, causing the net work done on the crate to be zero.
In the other definition of work where work is a line integral[2], although you are exerting a force on the crate over a distance which results in a positive value of W, the force of friction is equal and opposite, resulting in two integrals that void each other.
[1] http://upload.wikimedia.org/math/b/f/2/bf240d906ff97b33fc3e60f2508ab671.png
[2] http://upload.wikimedia.org/math/7/6/8/7680d79cfc1c61f21fe00e1089a9493b.png
THANKS!
THANKS!
This all sounds fine. Another way to think about it is that to compute the work done on an object, you must consider the net force on the object, which is zero in the example you are considering. But yes, in such an instance, the work done by all the individual forces acting on the object must sum to zero.
Note that equation [2] is the definition of work, whereas equation [1] is a theorem about work which can be derived starting from that definition. This theorem is called the work-energy theorem. I guess my point is that the work-energy theorem not a definition of work, but rather a result that follows from the definition.
Your understanding of the concepts appears to be absolutely fine.
When you apply a force to the moving object, you are performing work on the object so, its kinetic energy must increase but, at the same time frictional force is doing a negative work on the object or extracting the energy of the object. The power given by you to the object is opposite and equal to the power of the frictional force. And therefore the velocity of the object remains same and the energy dissipated by you appears as heat energy due to friction.
Thanks.
1. What is work and how is it related to velocity and friction?
Work is defined as the amount of force applied to an object over a distance. It is related to velocity and friction in that work is directly proportional to the velocity of an object and the force of friction acting upon it. In other words, the higher the velocity and friction, the more work is being done.
2. How does friction affect the amount of work done?
Friction is a force that opposes motion. This means that when there is friction present, more work is required to move an object at a certain velocity. Friction reduces the efficiency of work by converting some of the energy into heat. Therefore, the amount of work done will be less when friction is present.
3. Can velocity and friction be used to calculate the amount of work done?
Yes, the formula for calculating work is work = force x distance. Velocity can be used to calculate the force required to move an object, and friction can be used to calculate the distance over which the force is applied. By plugging these values into the formula, we can determine the amount of work done.
4. How does understanding work, velocity, and friction help in real-world applications?
Understanding these concepts is crucial in various real-world applications such as engineering, transportation, and sports. For example, engineers need to consider the amount of work required to move a structure, while transportation systems need to take into account the friction of vehicles on roads. In sports, understanding these concepts can help athletes improve their performance by optimizing their movements and reducing friction.
5. Is it possible to have an object with a high velocity and low friction?
Yes, it is possible to have an object with a high velocity and low friction. This can occur when the object is moving in a low-friction environment, such as in outer space where there is no air resistance. In this scenario, the high velocity of the object would not be affected by friction, allowing it to maintain its speed for a longer distance.
