Is Euclid's Fourth Postulate Redundant?
  • Thread starter lugita15
In summary, there is a question about whether Euclid's fourth postulate, which states that all right angles are equal, is a redundant postulate. While it may not be necessary for students to understand this postulate, it is argued that it is not redundant because it is possible to deduce it from the other four postulates. David Hilbert's proof of the fourth postulate is considered, but it is suggested that it should be shown that the fourth postulate can be derived from the other four postulates alone in order to confirm its redundancy.
lugita15
1,554
Euclid's Elements start with five Postulates, including the fifth one, the famous Parallel Postulate. Less well known, however, is the Postulate that forms the basis for the fifth: the fourth one, which states that "all right angles are equal." Students who see this for the first time might find this puzzling, because obviously two angles which are equal to a 90 degree angle are equal to each other, since Common Notion 1 says that "things which are equal to the same thing are are also equal to one another". But then they realize that the matter is so straightforward: the definition of a right angle is an angle produced when two lines intersect each other and produce equal adjacent angles, and it's not clear why an angle produced by one such pair of lines should bear any relation to an angle produced by another such pair of lines.
So Euclid's fourth Postulate is not redundant for the reason that beginning students might think. But my question is, is it nevertheless a redundant postulate, although for far less trivial reasons? David Hilbert, in his Foundations of Geometry (Grundlagen der Geometrie in German), claims to prove Euclid's fourth Postulate in theorem 15 (on page 19 of the PDF or page 13 according to the book's internal page numbering), prefacing the proof by saying "it is possible to deduce the following simple theorem, which Euclid held - although it seems to me wrongly - to be an axiom."
Now it's fair to say that Hilbert was working in a different (and more rigorous) system of axioms than Euclid was, but I think Hilbert's proof should be seriously considered for two reasons. First of all, why would he dub Euclid's decision to call "all right angles are equal" a Postulate as "wrong" if it merely reflected a stylistic difference concerning what you choose as starting assumptions and what you consider theorems? But more importantly, by tracing back all the assumptions used in the proof of theorem 15, it seems to me that only four of Hilbert's axioms are ultimately used: IV 3, IV 4, IV 5, and IV 6. And I don't think Euclid would have objected to any of these statements:
1. IV 3 follows directly from Euclid's Common Notion 2.
2. IV 4 is partly stated in Euclid's Book I Proposition 23, which doesn't depend on the fourth postulate, and the part of IV 4 which (I think) is not stated is easily provable in Euclid's system.
3. IV 5 follows from Euclid's Common Notion 1.
4. IV 6 is just part of Euclid's Book I Proposition 4, which doesn't depend on the fourth postulate at all.
So could Euclid have proven his fourth Postulate as a theorem instead of just assuming it?
Any help would be greatly appreciated.
Thank You in Advance.
Mathematics news on Phys.org
I think you need to show that the fourth postulate follows from the other four alone to consider that it is redundant to Euclid.
Well, I showed that all of Hilbert's assumptions in the proof were either assumed or proven by Euclid independent of the fourth postulate, so what more is needed?
I'm not so sure that you did - you certainly asserted that this was the case.
You should be able to work it backwards so that you can start from Euclid to get his fourth without assuming it.
It should be straight forward enough to show step-by-step, and provides a way to confirm what you've done.
Which is what you need - or did I misunderstand your question?
I would say that this is a fascinating question that has been debated by mathematicians for centuries. Euclid's Elements is a foundational work in the history of mathematics, and the question of whether or not his fourth postulate is redundant is an important one.
On one hand, Euclid's postulates were meant to be self-evident truths that did not need to be proven. The first three postulates are relatively straightforward and can be easily understood and accepted. However, the fourth postulate, stating that all right angles are equal, does seem to require some explanation and justification.
On the other hand, as you have pointed out, Hilbert was able to prove this postulate using only four of his own axioms. This raises the question of whether Euclid could have done the same, and if so, why did he choose to include it as a postulate rather than a theorem?
One possible explanation is that Euclid's system of geometry was not as rigorous as Hilbert's. In Euclid's time, the concept of proof and axiomatic systems were still developing, and it is possible that he did not have the same level of rigor that Hilbert had.
Another explanation could be that Euclid's postulates were not meant to be absolute truths, but rather starting assumptions that were necessary for his system to work. In this case, the fourth postulate may have been included as a way to ensure the consistency and coherence of the rest of the postulates and theorems.
In conclusion, whether or not Euclid's fourth postulate is redundant is still a matter of debate among mathematicians. While Hilbert was able to prove it using only four of his own axioms, it is possible that Euclid's intentions for including it as a postulate were different. Further research and analysis may shed more light on this question, but for now, it remains an intriguing and open topic for discussion.
1. What is Euclid's Fourth Postulate?
Euclid's Fourth Postulate, also known as the parallel postulate, states that if a line intersects two other lines, and the interior angles on the same side of the intersecting line add up to less than 180 degrees, then the two lines will eventually intersect on that side.
2. Why is there debate about the Fourth Postulate?
There is debate about the Fourth Postulate because it is the only postulate out of Euclid's five postulates that is not self-evident and can be derived from the other four postulates. This has led to attempts to prove it as a theorem rather than accepting it as a postulate.
3. Is Euclid's Fourth Postulate redundant?
This is a highly debated question among mathematicians. Some argue that it is redundant because it can be derived from the other four postulates, while others argue that it is necessary to maintain the consistency and completeness of Euclidean geometry.
4. What are the implications if Euclid's Fourth Postulate is proven to be redundant?
If the Fourth Postulate is proven to be redundant, it would mean that Euclidean geometry can be based on only four postulates instead of five. This could potentially lead to a simpler and more elegant system of geometry.
5. Has Euclid's Fourth Postulate been proven to be redundant?
There is still ongoing research and debate surrounding the Fourth Postulate, but as of now, it has not been definitively proven to be redundant. However, there have been attempts to provide alternative axioms that could replace the Fourth Postulate, such as the Playfair's Axiom.
  • General Math
  • General Math
