Why is the time dimension different from the 3 space dimensions
In summary, the concept of time as a dimension is based on the coordinate time of a Lorentz inertial frame in a Galilean spacetime. In this context, time is considered a dimension because it can be rotated along with the other three dimensions in spacetime. However, in more complex spacetimes such as Minkowski or Lorentzian, the idea of time as a separate dimension is not accurate and may be explained by theories like string theory or loop quantum gravity.
scottbekerham
48
General relativity states that our universe is four dimensional curved space so time dimension is not separated from space dimensions .Why then is the time dimension different from the 3 space dimensions ? and why there must be 3 space dimensions and not 4 for example ?
I'm having a simular issue understanding the time "dimension".
In 3D you need 3 coordinates for a location, what is the fourth coordinate for? Is it equivelant to "meet me at xyz @ 10:30am"? Is that 4D coordinates?
Exactly.
It is in a Galilean spacetime but not in a Minskowski or Lorentzian spacetime.
What is the time coordinate a reference to?
Time between two events is the length of the path in spacetime not a dimension of spacetime.
In simple spacetimes we can chose a map or chart where one dimension uniquely represents time, however in more complex spacetimes that is not possible.
There is no known reason why spacetime has to be be 3+1 (3 spatial dimensions plus one time dimension) and not 4+1, 2+1, etc. Various speculative theories such a string theory or loop quantum gravity may be able to explain this, but those theories are actually not really full-fledged theories yet, and they have never been tested against experiment, so there's currently no way to know if they're right.
Yea, back to my trouble with understanding why time is referred to as a dimension.
In at least some remote sense, is the time dimension similar to an index for the other 3Ds when measuring a distance?
Many seem to do so, something I do not understand.
Clearly time is a dimension in Galilean spacetime and I do not believe anyone would disagree with that. In a Galilean spacetime time is the same for all observers, and "10:30" is "10:30" for everybody however that is not the case in a Minkowski or Lorentzian spacetime.
Why some people persists in calling time a separate dimension in Minkowski or Lorentzian spacetime is beyond my comprehension, because I consider it inaccurate. Because they just do so as a matter of speaking.
Passionflower said:
...they just do so as a matter of speaking.
Oh:redface:
I actually thought about it, trying to understand in what sense it was a dimension.
Why not 3D + a constant [STRIKE]for forces[/STRIKE]
nitsuj said:
Oh:redface:
In the case of a 4 -manifold, if you decided to keep anyone [itex]x^{\alpha }[/itex] = const. then you're just defining a hyper-surface of that [itex]x^{\alpha }[/itex], kind of like keeping t = const., thereby defining a 3 - surface at some instant of time. If you want a 4 - manifold though (as is needed with space - time) you need four functions [itex]x^{\alpha }[/itex] as ,roughly speaking, keeping one or some constant defines a sub manifold of that 4 - manifold.
My cats breath smells like cat food...
I have no idea what your saying. What you are calling manifolds, were called dimensions in the previous post.
What I'm trying to say is that if you keep one of the coordinates constant then you can't have a 4 - dimensional space - time. If, say, you kept time constant then you're looking at a 3 - dimensional surface at that instant of time. Now you have me wondering what cat food smells like though.
Yes, that's right. When people talk about time as a dimension, they are referring to coordinate time of a Lorentz inertial frame. It is a dimension in the sense that switching to another Lorentz inertial frame, what was previously coordinate time is now mixed up as coordinate space and coordinate time. In a sense, you can rotate the axes in spacetime, just as you can rotate them in space.
It is better to say that time directions are different from space directions. A time direction is a direction in spacetime in which a stationary observer moves. Let's say some guy A is stationary, moving only in time. Another guy B moving at speed v relative to A will have a different time. But we can make B stationary too, by considering A to be moving at speed -v relative to B. Since B can be considered stationary, he too defines a time direction. Since we can have people moving at all sorts of velocities relative to A, and we can similarly define many other time directions. However, there are no observers moving faster than the speed of light relative to A. All the faster than light directions are therefore considered space directions.
No wonder nitsuj (or any relativity newbie) are confused about this if they keep getting this kind of apparently contradictory answers:-passionflower: no, time is not a dimension -atty: yes, it is.
At least atty clarifies that he is talking about coordinate time (dt^2 in a Lorentzian manifold line element, with positive or negative sign depending on the signature convention used:(3,1) or (1,3)), which is clearly a dimension in Lorentzian spacetimes, if it wasn't we wouldn't talk about 4-spacetimes instead of 3-spaces.
I guess Passionflower must be referring to proper time (d[itex]\tau^2[/itex] or ds^2 in Minkoski line element) when he says that in Minkowski spacetime time is not a dimension, if so he should have made that clear IMO considering not everyone will know the difference.
I think there is no necessity that time and space are the same. Because time is closely related to space measurement, change in space components affects time component. I think this is the only reason that time is another dimension. Also, looking at the tensors, sometimes just those special properties of time lead to the special features of geometry of space-time.
c is constant
nitsuj said:
c is constant
C isn't a coordinate though.
Oh good point! c is not a coordinate.
3D + a constant for forces
is hardly me suggesting time is a coordinate.
Did you see post #16?
In your original post, "forces" was crossed out. It simply read 3D + a constant by which I assumed you meant keeping one of the four coordinate functions constant.
I did see,
Does that mean a ticking clock is propertime and not considered a dimension?
And Coordinate time (as in meet me at xyz at 10:30) is a coordinate and in that sense is a dimension.
nitsuj said:
I did see,
Roughly speaking, yes.
nitsuj said:
I did see,
Coordinate time and coordinate location only has meaning if you know the coordinate system in which they are specified. So your example would be better put to say, "meet me at xyz at 10:30 Eastern Standard Time" which defines an event in one coordinate system and would be the same event as "meet me at xyz at 7:30 Pacific Standard Time" which defines an event in a different coordinate system.
Oh sorry, I was talking about the imaginary planet ticktocka. They don't have time zones there, or traditional clocks. they all just count up. The clock in the example just happened to be at 10:30. Which is equally meaningless to you as timezones to inhabitants of ticktocka.
It is not difficult to regard at least one universe model as one consisting of four spatial dimensions. The 4-D universe is populated by 4-dimensional objects. A typical characteristic of these 4-D objects is that they are very short along their X1, X2, and X3 dimensions (we can describe their sizes in the first 3 dimensions using the inch unit). But the size of the 4-D objects along their X4 dimension may be of the order of 10^13 miles or much more. So, one thing making the 4th dimension so different is the shape of the objects occupying the 4-D space (long along X4 and short along X1, X2, and X3).
But the most remarkable aspect of this model is that some aspect of observers exhibits a 3-D characteristic that moves along the observer's X4 axis at the speed of light. And as the observer moves along X4 he experiences a continuous sequence of 3-D worlds. And special relativity theory tells us that observers moving at different velocities relative to each other experience different instantaneous 3-D cross-section views of the 4-D universe.
So, time is associated with the 4th dimension only because nature, for some inexplicable mysterious reason moves the consciousness along the 4th dimension at light speed. That does not make X4 a time dimension--no more than a path along a highway is regarded as a time dimension just because you can mark off clock times along the highway corresponding to the time when points along the highway points are passed.
Here is a sketch showing a black coordinate system and a blue coordinate system. The blue system represents the inertial frame for a blue guy moving at relativistic speed relative to the black frame. We identify an instant of time for each observer which represents "NOW" for each observer. But notice that the instantaneous 3-D space experienced as "NOW" for each observer is different. At that instant of time, the observers are occupying two different 3-D worlds.
So, the blue guy's 3-D world intersects an earlier time along the black X4 axis as compared to the "NOW" time for his own blue X4 axis. Thus, the blue guy sees the black X4 clock running slower than his own. But, the black guy sees the blue guy's clock running slower. But, these effects are strictly a result of the different 3-D cross-section views of the two observers. So, time dilation simply results from differences in continuous sequences of 3-D cross-section views of 4-D objects in a 4-D universe.
If the inhabitants of ticktocka use only one standard coordinate system of xyzt, then they can consider time to be absolute and all stationary clocks in that one coordinate system will have proper times equal to the coordinate times. But if some of them use a different coordinate system that is offset in space and/or time and/or moving with respect to the "standard" coordinate system, then the clocks that are stationary in that second coordinate system will have proper times equal to the coordinate times in that second coordinate system.
The values assigned to the four parameters x,y,z and t for a given "event" can all be different between the two coordinate systems. It doesn't matter whether we call them "values" or "parameters" or "coordinates" or "dimensions", these terms all mean the same thing. They are just the four numbers that we use in a coordinate system (which is also called a Frame of Reference) to specify a particular location at a particular time.
bobc2 said:
It is not difficult to regard at least one universe model as one consisting of four spatial dimensions...
Just with the caveat that the OP refers to GR and the model you present is an SR (flat universe) model.
well locally in GR you have Poincaré invariance, that's where the 'difference' between time and space appears
  • #31
The imaginary planet Ticktocka doesn't exist anymore. However I imagine they did use xyzt for location of an event.
ghwellsjr: "But if some of them use a different coordinate system that is offset in space and/or time and/or moving with respect to the "standard" coordinate system, then the clocks that are stationary in that second coordinate system will have proper times equal to the coordinate times in that second coordinate system. "
Why are you forcing this point, we're clearly talking about a planet here. Okay, yes your point regarding timezones is a good one, thanks for the contribution.
  • #32
I'm trying to answer your questions with regard to the terms "proper time", "coordinate time" and "dimensions". Have they been answered to your satisfaction?
  • #33
Oh sorry, Yea my question regarding this have been answered to my satisfaction. And thanks for the help. I thought you were purposefully throwing in a red heering with the timezone thing, since I see it as a moot point when differentiating between propertime and coordinate time.
What a trip to consider this stuff so deeply. The rhythmic ticking of a clock seems a different measurement than the display on the clock. One measures the flow and will always be right from my perspective, the other is directly referenced from the frame where the clock was syncronized. The clock as a whole brings these two together (space-time) and gives a usefull measurement for coordinating events. Given our small variances in relative velocities, this goes unoticed as being seperate. Just my understanding though, not sure of the accuracy of details.
  • #34
My understanding is that time is a dimension, the 4th dimension, and it is at 90° to the other 3 dimensions, xyz, which are also all 90° from one another. I read this in an old library book, so the info may be somehow obsolete.
Please be easy on me, this is my first post here.
Wes
  • #35
I assume when you say the axes are at 90 degrees to each other that the bases are orthogonal (because in SR orthogonality of vectors doesn't necessarily imply that they are perpendicular). This isn't generally true for all metrics that act as solutions to Einstein's equation. You can usually tell which basis isn't orthogonal to which by looking for respective cross - terms of them in the metric.
