New Reply
Stability of an ODE and Euler's method
Share Thread Thread Tools
Nov23-12, 10:35 AM   #1
I have been thinking about numerical methods for ODEs, and the whole notion of stability confuses me.
Take Euler's method for solving an ODE:
U_n+1 = U_n + h.A.U_n
where U_n = U_n( t ), A is the Jacobian and h is step size.
Rearrange:
U_n+1 = ( 1 + hA ).U_n
This method is only stable if (1 + hA) < 1 ( using the eigenvalues of A). But what does this mean!?? Every value of my function that I am numerically getting is less than the previous value. This seems rather useless, I don't get it? It appears to me that this method can only be used on functions that are strictly decreasing for all increasing t ???
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Nov23-12, 09:48 PM   #2
Recognitions:
Homework Helper Homework Help
Does this help http://courses.engr.illinois.edu/cs4...stability.pdf?
Nov24-12, 11:52 AM   #3
Math 2012
Recognitions:
Quote by Master J View Post
Yup. Euler's (forward difference) method IS "rather useless". In fact compared with almost any other numerical integration method, its not so much "rather useless" as "completely useless".
But it's a nice example of something that "obviosuly" look like a good idea, but turns out not to be.
Nov29-12, 09:48 AM   #4
Well, I'm still confused.
Say I have an ODE who's solution family y(t) is unstable. That is, for increasing t, the solution curves diverge from eachother. In this case, J = df(y, t)/dy < 0.
So does this mean that ANY numerical method I use to solve this ODE will be unstable? With reference to http://courses.engr.illinois.edu/cs4...stability.pdf? there is a condition for all the methods, even the trapezoid rule etc. to be stable. And in each of these it implies that numerical values for each succesive value of y(t) are less than the previous, ie. y(t+h) < y(t).
So, in essence, what I gather here is that unless an ODE has the property that the magnitude of each value of the function y is LESS than the previous value, then it CANNOT be solved with a numerical method accurately?
Or, in another way, errors will always grow in solving an unstable ODE?
All this seems rather strange to me then. We cannot solve an ODE accurately unless the function is monotonically decreasing? What rather tiny area of applicability then!!
New Reply
Thread Tools
Similar Threads for: Stability of an ODE and Euler's method
Thread Forum Replies
Integrating Euler's equations for rigid body dynamics with Euler's Method Differential Equations 0
stability criteria for explicit method Differential Equations 0
Test Stability using Routh Stability Method Engineering, Comp Sci, & Technology Homework 2
Euler methond and the improved Euler method Differential Equations 4
Differential equations, euler's method and bisection method Calculus & Beyond Homework 3
