New Reply
join two broke pieces of the same material
Share Thread Thread Tools
Jun21-12, 09:13 AM   #1
Hello, if I broke for example a piece of wood in two pieces I give the atoms enough force to separate in the break point with the others, so why putting the two pieces together and pressing them the atoms don't join again ?
Thank you!
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Jun21-12, 11:24 AM   #2
mfb
Mentor
This is possible with metal, but it has to be extremely clean and in a vacuum.
If you break wood, you modify the surfaces, if you try to combine them again you get a lot of ripples which do not fit. And on a molecular level, you need energy to combine the parts as well, which would be released as heat afterwards.
Jun21-12, 01:23 PM   #3
why would I need energy if atoms attract each others?
Jun21-12, 01:35 PM   #4
Recognitions:
Gold Membership Gold Member
Quote by scientifico View Post
Deformation of the material during breakage would prevent you from joining them cleanly afterward.
Jun21-12, 05:01 PM   #5
mfb
Mentor
Atoms do not generally attract each other. Some do, some do not. In many cases, you have to add some energy to the system first, even if you can extract more energy afterwards.
Think of a wood fire: It burns, and it can release a lot of heat. But if you just place wood somewhere, it does not begin to burn. You have to add energy first.
New Reply
Thread Tools
Similar Threads for: join two broke pieces of the same material
Thread Forum Replies
I broke latex! Forum Feedback & Announcements 25
I think I broke Wolfram?!?! Calculus & Beyond Homework 31
Broke freezing at last! General Discussion 41
Just broke my arm again General Discussion 178
if it ain't broke don't fix it Computing & Technology 1
