| New Reply |
water at 4 degree Celcius has maximum density |
Share Thread | Thread Tools |
| Nov23-12, 07:11 PM | #1 |
During winter why not all the water molecules on the water surface that have 4°C go deep under the water?
| Nov23-12, 08:38 PM | #2 |
Recognitions:
They basically do. Water at the bottom of the frozen-over pond will be at about 4°C. That's also why lakes freeze starting from the top.
| Nov23-12, 10:31 PM | #3 |
| Nov24-12, 12:23 AM | #4 |
Recognitions:
In practice, almost always, but it isn't necessarily true under all conditions. Certainly, there cannot be any water warmer than that. If there is, it will rise to the top, until it either meets colder water and cools, or until it gets to the very top and meets ice, in which case it will melt some ice and cool down. So in equilibrium, the warmest water you can have is 4°C.
However, all water in the pond could be colder than 4°C. That really should only happen right before the entire thickness of water freezes through, because while there is still a lot of water, the heat is lost only from the surface, and whatever little heat there is coming from the ground will keep the bottom at these 4°C. But if for whatever reason there is no heat from bellow, it could, in principle, be colder. But certainly, you could say that there is no water warmer than 4°C, and whatever temperature the warmest water is, it is at the bottom. |
| Nov24-12, 12:29 AM | #5 |
Thank you very much
| Nov24-12, 03:26 AM | #6 |
Admin
Note in the ocean things get slightly different - deep ocean water is colder, usually between 0 and 3°C.
| Nov24-12, 03:30 AM | #7 |
| Nov24-12, 04:04 AM | #8 |
Admin
I believe it is a combination of salinity and high pressure that changes water properties. Perhaps there is more to it, I don't know details. Sorry.
| Nov24-12, 04:09 AM | #9 |
Recognitions:
At high pressure, the maximum density will certainly be at a lower temperature, so it's probably a factor. But I don't know how significant that would be or how the salt will play into it.
| Nov24-12, 05:41 AM | #10 |
Thank you guys
| Nov24-12, 12:08 PM | #11 |
Do not try to apply the 'anomalous' density curve for pure (fresh) water to sea water.
For sea water the density continues to increase as temperature decreases all the way below zero (C) to the freezing point. There is no anomalous maximum. Of course the actual value of freezing point depends on the salinity, as Borek said. The reason icebergs float is tha they contain a large quantity of entrained air. |
| New Reply |
| Thread Tools | |
Similar Threads for: water at 4 degree Celcius has maximum density
| Thread | Forum | Replies | ||
| Finding the maximum or minimum value of a funtion to the nth degree? | Precalculus Mathematics Homework | 4 | ||
| Difference between a kelvin and a celcius degree | Biology, Chemistry & Other Homework | 7 | ||
| Evaporating water at 40 Celcius | General Physics | 14 | ||
| Maximum Density of Water | General Physics | 45 | ||
| maximum density | General Physics | 4 | ||
