Can Carbon Be Melted in a Magnetic Field and Inert Gas?
  • Thread starter cragar
  • Tags
    Carbon
In summary,If carbon has the highest melting point of any of our known elements, then how do they melt it? The only thing I could think of is containing it in a magnetic field and maybe using like an electric arc furnace.What do you see as the problem?
cragar
2,552
If carbon has the highest melting point of any of our known elements , then how do they melt it , the only thing I could think of is containing it in a magnetic field and maybe using like an electric arc furnace.
Chemistry news on Phys.org
so what container do they put it into , and how do they keep the oxygen away from it .
I can imagine it can be contained in containers that have high melting points due to the alloys used. Though, not my field of expertise!
ya i don't know , carbon has a higher melting point then brick and some rocks
which are pretty high .
You don't have to use a container. Take a block of substance and heat it in one point at the top - when it starts to melt it doesn't melt in the volume, but just in the place it was heated. This way substance itself works as a container :wink:
ok i could see that , how do we keep oxygen away from it so it doesn't burn.
You do it in an oxygen-free environment? That's a pretty easy part.
Agreed. Vacuum or inert gas. Both used in commercial applications on the large scale, so no problems with implementation.
methods
Different carbon compounds have varying melting points so perhaps you melt carbon by placing a carbon compound in a container comprising carbon compounds with a higher melting point?
its very simple. you need a controlled environment. remove the O2 and substitute it with an inert gas. bring the environment up to ( ) pressure and introduce an plasma or ( ). why would you want to know this anyway? are you looking for a challenge? NASA Challenge?
I was just thinking about it one day , thanks for the answer.
Of course you know that carbon doesn't melt at standard pressure, it sublimates.
The reason I responded to this, this way is because I am in my prototype stage of production. I’ve tested several different theories and I am stuck on this one. So we will see. Thanks again and very good question. At least for me.
Considering that carbon sublimes at ambient pressures, I would go with the "inert gas" option.
Would there be really be a difference between vacuum and inert gas atmosphere as far as subliming vs. melting? The relevant pressure seems to me to be the partial pressure of carbon and not that of an inert gas.
To some extent you are correct, however, there is the difference between evaporation and boiling--pressure will prevent bubbles from expanding within the liquid.
Ok. So this is what I did. Pressure is important and so is replacing the “air” with an inert “gas”. Have you ever welded? or brazed?. If not you will have to picture a steel frame which is lined with plexi/glass which is also lined with fire bricks. On the top part you have a regulator which is attached to your inert gas and the bottom part a valve exhaling air which is heavier then your inert gas. You need to do the math... volume in = volume out. Also the specific gravity of your gas and air. Once the air is replaced shut off your volume out and keep your volume in running until you have achieved you desire pressure. You are protecting the carbon and preventing oxidation. With out it carbon explodes or should I say porosityis created. That’s why tig welding mild steel is tough. then melt with plasma or electrical field. This information should not be considered true and unless you are an expert do not try this experiment. All information is considered read only and is not intended for practical use.
Ok. So this is what I did. Pressure is important and so is replacing the “air” with an inert “gas”. Have you ever welded? or brazed?. If not you will have to picture a steel frame which is lined with plexi/glass which is also lined with fire bricks. On the top part you have a regulator which is attached to your inert gas and the bottom part a valve exhaling air which is heavier then your inert gas. You need to do the math volume in = volume out. Also the specific gravity of your gas and air. Once replaced shut off your volume out and keep your volume in running until you have achieved you desire pressure.
You are protecting the carbon and preventing oxidation. With out it carbon explodes or should I say creats porosity. That’s why tig welding mild steel is tough. then melt with plasma or electrical field. This information should not be considered true and unless you are an expert do not try this experiment. All information is considered read only and is not intended for practical use
1. How do they melt carbon?
Carbon can be melted through the process of heating it to a high temperature. The melting point of carbon is very high, at around 3,500 degrees Celsius. This can be achieved by using a furnace or other high-temperature heating equipment.
2. What happens when carbon is melted?
When carbon is melted, it transforms from a solid state to a liquid state. This means that the bonds between carbon atoms are broken, allowing the molecules to move more freely. The liquid carbon can then be used for various purposes such as casting or forging.
3. Why is melting carbon important?
Melting carbon is important because it allows us to manipulate and shape the material into different forms. This is useful in various industries such as metallurgy, where melted carbon is used to produce steel, and in electronics, where melted carbon is used to create semiconductors.
4. Can carbon be melted at room temperature?
No, carbon cannot be melted at room temperature. As mentioned earlier, the melting point of carbon is very high and requires extremely high temperatures to melt. However, it is possible to transform carbon into a liquid form at room temperature through the process of sublimation, where solid carbon is heated and vaporized.
5. What are some common methods used to melt carbon?
Some common methods used to melt carbon include electric arc furnaces, induction furnaces, and open-hearth furnaces. These methods involve using high temperatures to heat the carbon and melt it into a liquid form. Other techniques, such as laser melting and electron beam melting, are also used in more specialized applications.
  • Classical Physics
  • Biology and Medical
  • Chemistry
  • Materials and Chemical Engineering
