New Reply
what creates the "star points" in telescope pictures of stars?
Share Thread Thread Tools
Jun8-12, 06:31 PM   #18
Recognitions:
Gold Membership Gold Member
Quote by turbo View Post
Not with a space telescope. You need widely-space optical telescopes and interferometry to pull that off.
You sure about that? Have you seen this picture? http://en.wikipedia.org/wiki/File:Be...8Hubble%29.jpg
It's from the Hubble Space Telescope in UV.
Jun8-12, 08:11 PM   #19
Quote by SHISHKABOB View Post
can't we see Betelgeuse as a disk?
No. But we can determine its diameter using interferometry.
Jun9-12, 12:54 AM   #20
Recognitions:
Quote by hipparchos View Post
Does the image I linked above not prove otherwise?
Jun9-12, 11:43 AM   #21
Quote by rbj View Post
my question was motivated by seeing similarly bright objects in the same photo, where some had diffaction spikes and others had no sign of any diffraction spike. this is still a curiosity.
The assumption that they are similarly bright is questionable. First, not all of the light from the brightest stars is counted because parts of the CCD that collects the light become saturated. But more importantly, the images you see are heavily processed. Usually the interesting stuff in an astrophoto is dimmer than the brightest stars, and so the image is "stretched." The pixels on the bright end are all crowded together at similar brightnesses, and on the dim end, pixels that formerly had similar brightnesses end up with dramatically different brightnesses. Check out this link for a description of the processing that goes on even just to show you a preview image of "raw" Hubble data: http://archive.stsci.edu/hst/preview...orrection.html. Go here http://archive.stsci.edu/cgi-bin/hst...name=J8JY04060 and try viewing the image of V838 Mon using several levels of Pixel Correction (GIF Only), starting at "None." Using the None setting, you won't even see V838 Mon, one of the most fascinating objects in Hubble History.
Jun9-12, 01:16 PM   #22
Quote by Drakkith View Post
Yes, it does.
Jun9-12, 02:32 PM   #23
No. The Hubble's resolution is 0.05 arcsec, essentially the same as the apparent diameter of Betelgeuse.
Jun9-12, 06:16 PM   #24
Recognitions:
Care to explain how the Hubble captured that image then?
Jun9-12, 06:44 PM   #25
The picture was taken in ultraviolet light. Hubble has better resolution R in UV than visible light. A crude estimate is (using R in arcseconds = 0.21 λ/D, where λ is wavelength in microns and D is mirror diameter in meters) R = 0.21 x0.122/2.4 = 0.011 arcseconds for the smallest wavelength ultraviolet light, 122 nm, visible to the Faint Object Camera that took the image. However, http://hubble.esa.int/science-e/www/...odylongid=1464 gives an even smaller value, 0.0072 arcseconds.
New Reply
Thread Tools
Similar Threads for: what creates the "star points" in telescope pictures of stars?
Thread Forum Replies
What are "self-similar pictures of bifurcations and fractals"? Beyond the Standard Model 1
"A high-energy photon creates a pi+ pi- pair." ??? Advanced Physics Homework 4
Magnetic implant creates "6th sense" Biology 8
Russia Creates "Flying Saucer" Computing & Technology 0
