(log√125 + log √27 - √8)/ log 15 - log 2 = 3/2
  • Thread starter lionely
  • Tags
    Log
In summary, the first equation simplifies to (3/2 log 15)/ log 13 = 3/2 and the second equation simplifies to x = a^4.
lionely
576
1)Without using tables, show that
What i tried was
(3/2 log 5 + 3/2 log 3 - 3/2 log 2)/ log 5+log 3 - log2
then from here I don't know where to take it.
2) Find the value of x if log x2/ log a^2 = log y^4/logy
I tried this 2logx - 2loga = 4 log y- log y
2logx = 3logy+ 2 loga
then here I get stuck..
What i tried was
You miss some parentheses.
ehild
What i tried was
Since you want the problem to reduce to something simple (3/2) you should combine the log terms and simplify from there.
lionely said:
1)2) Find the value of x if log x2/ log a^2 = log y^4/logy
If we have
[tex]\log(x)=y[/tex] then what is x?
10^y = x?
Yes, so now do the same thing. Set the equation so that it is in the form [itex]\log(x)=y[/itex] and then make x the subject. Oh and y will be some complicated expression.
And once you've done that, remember the rules
[tex]a^{x+y}=a^xa^y[/tex]
[tex]a^{\log_{a}(x)}=x[/tex]
I'm kind of confused if I have this
log x = 3logy - 2loga
I duno how to get rid of log a to make it log (x) = y
log y^4/logy=4log(y)/log(y)=4
ehild
oh.. so it's 2log x = 4 + 2log a
x^2= a^8
x=a^4?
ehild noticed some mistakes which you should first address.
[tex]\frac{\log(a)}{\log(b)}\neq \log(a)-\log(b)[/tex]
What you're thinking of is
[tex]\log\left(\frac{a}{b}\right)=\log(a)-\log(b)[/tex]
Oh, Umm should it should be
log x^2/ log a^2 = 4
2log x = 8 log a
log x = 4log a
10^a^4 = 10^x
x= a^4?
And for the first one
is it (3/2log5 + 3/2log 3 - 3/2log 2)/ (log 5+ log 3) - log 2
= 1/2log log + 1/2log 3 - 1/2log2?
I think you made some mistake when copying the problem. It should be
(log√125 + log √27 - √8)/ (log 15 - log 2 )= 3/2.ehild
2log x = 8 log a
log x = 4log a
10^a^4 = 10^x
x= a^4?
Yes that's correct :smile:
No, again, you want to simplify that expression into a simple answer of 3/2, so what you're aiming to do is to combine each log term, not split them up further. Use the [itex]\log(a)+\log(b)=\log(ab)[/itex] rule.
ehild
Nope the [itex]\sqrt{8}[/itex] should be [itex]\log(\sqrt{8})[/itex]
I still don't get it combine them? But aren't they too big? shouldn't I try to get them down to like small numbers and then try to cancel out?
Yes, combine them! If you get them down to small numbers then you'll end up with the fraction you posted earlier that cannot be canceled further.
Use
[tex]\log(a)+\log(b)-\log(c)=\log\left(\frac{ab}{c}\right)[/tex]
for both the numerator and denominator and see if you notice any nice cancellations.
ehild
Looks like a typo.
How about the first one should be:
(log√125 + log √27 - log√8)/ (log 15 - log 2 )= 3/2
As ehild said early on, you need to use sufficient parentheses .
thank you guys.
1. What is the equation (log√125 + log √27 - √8)/ log 15 - log 2 = 3/2?
The equation (log√125 + log √27 - √8)/ log 15 - log 2 = 3/2 is a logarithmic expression that represents the value of x in the equation 15^x = 125√27/2√8.
2. How do you solve the equation (log√125 + log √27 - √8)/ log 15 - log 2 = 3/2?
To solve the equation (log√125 + log √27 - √8)/ log 15 - log 2 = 3/2, you can simplify the expression by using logarithmic properties and then solve for x by taking the logarithm of both sides. The final solution should be x = 1/2.
3. What is the significance of the number 15 in the equation (log√125 + log √27 - √8)/ log 15 - log 2 = 3/2?
The number 15 in the equation (log√125 + log √27 - √8)/ log 15 - log 2 = 3/2 represents the base of the logarithm. In this case, the base is 15 because the expression is set equal to 3/2, which is equivalent to the logarithm of 15. This means that the equation can be rewritten as log15 (125√27/2√8) = 3/2.
4. Is there a specific method or formula to solve equations with logarithms like (log√125 + log √27 - √8)/ log 15 - log 2 = 3/2?
Yes, there is a specific method for solving equations with logarithms. First, you must simplify the expression using logarithmic properties and rules. Then, you can solve for x by taking the logarithm of both sides and using algebraic techniques to isolate the variable. The final solution should be checked for extraneous roots, which may occur when taking the logarithm of both sides.
5. How can the equation (log√125 + log √27 - √8)/ log 15 - log 2 = 3/2 be applied in real-life situations?
This equation can be applied in various situations, such as calculating the decay rate of a radioactive element or determining the time it takes for a population to double in size. It can also be used in finance for calculating compound interest or in biology for measuring the growth of bacteria. In general, logarithmic equations are useful for solving problems that involve exponential growth or decay.
  • Precalculus Mathematics Homework Help
