Expressing a vector as a linear combination
In summary: I think you have the idea. The equation ##c_1\vec v_1 + c_2\vec v_2 + c_3\vec v_3=\vec 0## gives you 3 equations in 3 unknowns. It always works if all the ##c##'s are zero. If those are the only values for which it works, the three vectors are linearly independent. But if there are any non-zero values that work, they are linearly dependent. You have to solve the system and identify the solutions.
zabumafu
express the vector (6,-4,7) as a linear combination of (4,-2,1) and (-3,1,2)
I am not quite sure how to go at it but this is what I am assuming to do:
(C1*4,C2*-2,C3*1)=(6,-4,7)
C1=3/2
C2=2
C3=7
and the same method for the 2nd one? I know how to show linear dependence and dependence as a vector is independent if c1=c2=c3 and not if constants aren't equal. Any help in how to solve this is appreciated.
All you did was express ##(6,-4,7)## as a scalar multiple of the ELEMENTS of the vector ##(4,-2,1)##. You cannot do that.
Karnage1993 said:
All you did was express ##(6,-4,7)## as a scalar multiple of only the vector ##(4,-2,1)##. You need to use ## (-3,1,2)## as well.
So would I need to find the same c1,c2,c3 that satisfy it for both? The only equation my teacher gave us was V=c1v1+c2v2+CnVn
Basically, what you need to do is find scalars ##r, s \in \mathbb{R}## such that
##(6,-4,7) = r(4,-2,1) + s(-3,1,2)##
What your teacher gave you was the general form of a linear combination for any ##n## vectors. In this case, you only have 2 to work with.
C1=3/2
C2=2
C3=7
No. That isn't how you do it. You have to find ##C_1,\, C_2## such that$$
C_1(4,-2,1) + C_2(-3,1,2) = (6,-4,7)$$That will give you 3 equations in 2 unknowns.
Okay that makes much more sense I think I have it:
(1)4c1-3c2=6
(2)-2c1+c2=-4
(3)c1+2c2=7
->(3) becomes c1=7-2C2 -> into (2) -2(7-2C2)+c2=-4
C2=2
C1=3
3(4,-2,1)+2(-3,1,2)=(6,-4,7)
(12,-6,3)+(-6,2,4)=(6,-4,7)?
And these are linearly dependent since c1 doesn't equal c2 correct? For part B. I have to determine the linear dependence of vectors (6,-4,7),(4,2,1), an (-3,1,2) but not quite sure if I set it up the same way since I don't know which of those vectors I set equal to.
(1)4c1-3c2=6
(2)-2c1+c2=-4
(3)c1+2c2=7
C2=2
C1=3
What do you mean by these? You aren't testing anything for linear independence. You are expressing (6,-4,7) as a linear combination of the other two, which you have done correctly at the step I highlighted in blue.
Do you mean (4,-2,1) as the second vector so they are the same three as in part A? If so, look at the definition of linear dependence or independence and think about what you have above in blue.
I was just asking trying to think ahead for part b but I think I might get it now. And no they switched it up for part be its not -2 its (4,2,1).
I assume I'd do something like this (let vectors be v1,v2,v3 to save time)
c1v1+c2v2+c3v3=0 and if it does =0, then that implied c1=c2=c3=0 and therefore they are linearly independent? I am just curious if it its just all the constants have to be zero or if they just all have to be the same? The definition I have written down is basically what I just wrote with c1=c2=c3=0 and then it states if this is the case then the vectors are linearly independent.
I think you have the idea. The equation ##c_1\vec v_1 + c_2\vec v_2 + c_3\vec v_3=\vec 0## gives you 3 equations in 3 unknowns. It always works if all the ##c##'s are zero. If those are the only values for which it works, the three vectors are linearly independent. But if there are any non-zero values that work, they are linearly dependent. You have to solve the system and see.
What does it mean to express a vector as a linear combination?
To express a vector as a linear combination means to represent it as a weighted sum of other vectors. This allows us to break down a vector into its component parts and understand how it can be constructed using simpler vectors.
Why is it useful to express a vector as a linear combination?
Expressing a vector as a linear combination allows us to easily perform operations such as addition, subtraction, and scalar multiplication on the vector. It also helps us understand the relationship between different vectors and how they contribute to the overall vector.
What are the steps to express a vector as a linear combination?
The steps to express a vector as a linear combination are:
  1. Identify the vectors that will be used in the linear combination.
  2. Determine the coefficients (weights) for each vector.
  3. Multiply each vector by its respective coefficient.
  4. Add all the resulting vectors together to get the final linear combination.
Can any vector be expressed as a linear combination?
Yes, any vector can be expressed as a linear combination of other vectors. This is because any vector can be broken down into its component parts, and these parts can then be used as the basis for the linear combination.
How can expressing a vector as a linear combination be applied in real-world situations?
Expressing a vector as a linear combination has many applications in fields such as physics, engineering, and computer graphics. It can be used to represent forces, velocities, and other physical quantities. In computer graphics, it is used to create 3D graphics by combining simpler geometric shapes.
