Register to reply
Help In understanding Rate Of Change in mm per sec
by tomtomtom1
Tags: change, rate
Share this thread:
tomtomtom1
#1
Sep16-13, 12:03 PM
P: 49
Hi everyone
Firstly this is not a homework question, i work in transport engineering. ( i do study part time which is why i sometimes post in the homework section)
Now to the problem.
I am trying to understand how to solve this problem, i already know the answer.
A train is travelling on straight & level track at 136.794kph.
It approaches a transition. The transition is 60m long.
Along the transition the Left Rail rises linearly over the length of the transition relative to the right Rail by 25mm.
Calculate the rate of change the left rail raises over the right in mm per sec over the 60m transition at 136.794kph.
i know that the answer is (25mm * 136.794kph) / (3.6 * 60m)
what i need help with is where does the 3.6 some from? and why do you times 25mm by 136.794kph?
can anyone explain
Thanks
Phys.Org News Partner Physics news on Phys.org
Physicists unlock nature of high-temperature superconductivity
Serial time-encoded amplified microscopy for ultrafast imaging based on multi-wavelength laser
Measuring the smallest magnets: Physicists measured magnetic interactions between single electrons
SteamKing
#2
Sep16-13, 12:11 PM
Emeritus
Sci Advisor
HW Helper
Thanks
PF Gold
P: 6,319
The transition length is 60 m long. In this distance, the rails rise by 25 mm. Doesn't this suggest a slope?
The train is travelling at 136.794 km/hr. How do you convert 136.794 km/hr to a speed measured in m/s?
tomtomtom1
#3
Sep16-13, 12:27 PM
P: 49
Yes there is a slope and the slope is 25mm/60m = 1m per 0.416mm which means for every 1m the train travels along the transition the left rail rises by 0.416mm.
1kph = 0.277777778 m/s so 136.794km/hr in m/s is 136.794*0.277777778 = 37.998m/s.
jacket
#4
Sep16-13, 12:35 PM
P: 32
rate of change the left rail raises = 25mm / (time needed to cross 60m)
= 25 mm / (60 m / velocity)
= 25 mm / (60 m / 136.794 km per hour)
Now, 1 km per hour = 1000 m / 3600 sec = 1/3.6 meter per sec
So,
rate of raise = 25 mm / (60 m / ((136.794 / 3.6) meter per sec))
= 25 mm / (3.6 x 60 / 136.794) sec
= (25 mm x 136.794) / (3.6 x 60) sec
Register to reply
Related Discussions
Rate of change: find rate length is changing at moment Calculus & Beyond Homework 1
Related Rate - Rate of The Change in Distance of Two Ships Calculus & Beyond Homework 17
Rate of emf decline and rate of change of internal resistance Electrical Engineering 1
Related Rate -finding the Rate of Change of an Angle Calculus & Beyond Homework 5
Measuring rate of reaction via rate of temperature change Chemistry 3
