Pinning a gyroscope will resist change in orientation
In summary, a gyroscope resists changes in orientation so that the rotor is still pointing in the same direction. If I point a gyroscope upwards and spin the rotor and I go directly to the otherside of the Earth, the rotor will be pointing downwards. If I spun a gyroscope for a day, I would see it change direction (with respect to my reference frame) along with Earth's rotation and orbit.
Gelsamel Epsilon
315
I know when spinning a gyroscope will resist change in orientation so that the rotor is still pointing in the same direction.
But, is that direction with respect to Earth's center of gravity or is it an "absolute direction".
So, if I point a gyroscope upwards and spin the rotor and I go directly to the otherside of the Earth would the rotor be pointing downwards or will it be pointing upwards still?
Also, if I spun a gyroscope for a day, would I see it change direction (with respect to my reference frame) with Earth's rotation?
And if I spun it for a year would I see it change direction (again with respect to my reference frame) along with Earth's rotation and orbit?
Considering these questions my guess is it stays in the same direction with respect to Earth's Center of Gravity.
It's an "absolute direction" kind of thing.
So assuming the rotor is spinning forever regardless of where I take it in the universe it will always point in the exact direction that I started spinning it at?
If that is the case then how do things which use gyroscopes to determine direction compensate for the Earth's spin and orbit?
That is how they compensate. That's the whole point of the gyroscope - that it isn't affected by the Earth's spin and motion. For example, a gyrocompass on a ship has its axis aligned to the Earth's axis and it stays that way, regardless of which way the ship is pointed or the Earth moves (the Earth's axis doesn't move either, for the same reason), enabling the ship to know its direction.
Ah, I see how that works.
Though if it isn't aligned with the Earth's axis it would not work well as a compass?
You normally use gyroscopes for short time scale things, like acrobatic maneuvers. Over longer time-scales, most gyroscopes tend to slowly "drift" and need correcting anyway (say using accelerometers, or compasses perhaps.. in which case the slow daily rotation may be removed then).
Is that simply because real world is not a "perfect world" situation?
It is because the "gyroscope pointing in the same direction" is only correct if no torque is applied to the gyroscope (that is, a perfect gyroscope is an axially symmetric rigid body that has a fixed point, lying on its axis of symmetry, and is totally free to rotate about that axis, without undergoing any external torque wrt to that fixed point). The suspension of a gyroscope always includes some form of friction or so, which induces a very small torque on the gyroscope, and can slowly alter the direction in which it points.
Thanks for the info guys. :-)
The compass is free to float (IIRC, it is suspended magnetically), so it still works if it isn't aligned quite perfectly. Ships keep logs of their compass error and check it daily against the sun.
'How It Is Made' on Discovery had a segment on the construction of a marine gyroscope a while back. It's quite amazing how complex it is.
What is a gyroscope?
A gyroscope is a spinning wheel or disc that is used to measure or maintain orientation and angular velocity. It is often used in navigation systems, stabilization systems, and other devices.
How does pinning a gyroscope resist change in orientation?
Pinning a gyroscope refers to fixing or securing the axis of rotation of the gyroscope. This allows the gyroscope to maintain its orientation even when external forces are applied. The spinning motion of the gyroscope creates a force that resists any changes in its orientation, making it an effective tool for maintaining stability.
What types of devices use gyroscopes?
Gyroscopes are used in a wide range of devices, including smartphones, drones, airplanes, spacecraft, and even video game controllers. They are also used in various industrial and scientific applications such as robotics and motion sensing.
How do gyroscopes work?
Gyroscopes work based on the principle of conservation of angular momentum. When the gyroscope spins, it creates a force that resists any changes in its orientation. This force allows the gyroscope to maintain its orientation even when external forces are applied. The rate of spinning and the mass distribution of the gyroscope also contribute to its stability.
What are the benefits of using gyroscopes?
Gyroscopes have many practical applications, including navigation, stabilization, and motion sensing. They are also lightweight, compact, and require minimal power, making them ideal for use in various devices. Additionally, gyroscopes are highly accurate and can provide precise measurements, making them essential tools in scientific research and technological advancements.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Mechanics
