Point on a parabola where the tangent intersects a point
In summary, the car's headlights will illuminate the statue when the car is at the point (50*sqrt(2), 50) on the highway. This is found by using the tangent line equation to find the point of intersection between the tangent line and the statue's location.
sp09ta
1. A car is traveling on a highway shaped like a parabola with its vertex at the origin. The car begins at a point 100m west and 100m north of the origin and is traveling easterly. There is a statue 100m east and 50m north of the origin. At what point on the highway will the car`s headlights illuminate the statue.
2. d/dx x^n = x*x^(n-1)
(y2-y1)/(x2-x1)=m
3. The car begins at (-100,100) and travels on the domain [-100,inf).
let f(x) represent the path of the car, thus f`(x) will represent the car`s headlights.
f(x)=(1/100)*x^2 and f'(x)=(1/50)*x
We need to find point P, who's tangent line intersects (100,50).
Since the equation of the tangent is y=mx+b, and m=f'(x), then (50-y)/(100-x)=(1/50)x
I then solved for y to receive y=(x^2+100x+2500)/50
and for y=0, x=50.
So sub y=50 into my original eqn:
Thus, 50=(1/100)*x^2 so, 50sqrt(2)=x
And the statue will be illuminated by the car`s headlights when the car is at (50*sqrt(2), 50)?
Does this look correct?
Yes, your solution looks correct. You have correctly used the tangent line equation to find the point of intersection between the tangent line and the statue's location. Your calculations and reasoning are also sound. Good job!
1. What is the significance of the point where the tangent intersects a point on a parabola?
The point where the tangent intersects a point on a parabola is known as the point of tangency. This point is important because it is the only point on the parabola where the slope of the curve is equal to the slope of the tangent line.
2. How do you find the coordinates of the point of tangency on a parabola?
To find the coordinates of the point of tangency on a parabola, you can use the derivative of the parabola's equation. The derivative will give you the slope of the tangent line at any given point. Then, you can set this slope equal to the slope of the parabola at that same point and solve for the x-coordinate. Once you have the x-coordinate, you can plug it back into the original equation to find the y-coordinate.
3. Can there be more than one point of tangency on a parabola?
No, there can only be one point of tangency on a parabola. This is because a parabola is a smooth, continuous curve and therefore, there can only be one tangent line at any given point on the curve.
4. What does the slope of the tangent line at the point of tangency tell us?
The slope of the tangent line at the point of tangency tells us the rate of change of the parabola at that specific point. This can be interpreted as the instantaneous rate of change, meaning the rate of change at that exact moment or point.
5. How is the point of tangency related to the concavity of the parabola?
The point of tangency is not directly related to the concavity of the parabola. However, the concavity can be determined by looking at the second derivative of the parabola's equation. If the second derivative is positive, the parabola is concave up and if it is negative, the parabola is concave down. The point of tangency will always lie on the parabola's axis of symmetry, which is also a point where the concavity changes.
