Calculate the kinetic energy required to accelerate a proton
In summary: It is better to expand it as (1-0.9999)(1+0.9999) = 1.9999 E-4. mc^2=\frac{100 m_0c^2}{\sqrt{1.9999}} KE=mc2-m0c2, about 70 times the rest energy.
HarleyM
56
Calculate the kinetic energy required to accelerate a proton from a rest position to 0.9999c. The mass of the proton is 1.67x10-27
Find the ratio of kinetic energy to the energy of a proton at rest
Erest = mc2
Ek = mc2/√(1-v2/c2)
Ok So calculating the rest energy is easy
E= (1.67x10-27)(3x108)2
E= 1.503x10-10
Ekinetic= mc2/√(1-v2/c2)
=((1.67x10-27)(3x108)2)/√(1-0.9999c2/c2)
=1.503x10-10/√(1-0.9998)
= 1.503x10-10/ 0.0141418
= 1x10 -8 J
This doesn't seem like a lot of energy to accelerate something to almost light speed I feel like I am missing something...even when using Etotal =Erest+EK I get 1x10-8 J
can someone point out my mistake?
Ratio of kinetic energy to rest energy is
1.503x10-10 / 1x10-8
= 1.503 % of the energy is kinetic energy ? ( really unsure about this) Thanks! Happy monday !
I think you got that backwards
98.5 % of the energy is kinetic energy then?
HarleyM said:
ERest= (1.67x10-27)(3x108)2
ERest= 1.503x10-10
EMoving= mc2/√(1-v2/c2)
= 1x10 -8 J
Your kinetic energy requires will be E when moving - E when at rest !
So it will be 10-8 - 1.503*10-10 = 9.85 * 10-9
v=0.9999c. 1-v^2/c^2 =1-0.9999^2. It is better to expand it as (1-0.9999)(1+0.9999) = 1.9999 E-4.
[tex]mc^2=\frac{100 m_0c^2}{\sqrt{1.9999}}[/tex]
ehild
ehild
I can get an answer of about 66 times the rest energy, can you explain this formula a little more?
What is M0 and by subtracting the kinetic from rest energy it gives you the ratio?
Usually the rest mass is denoted by m0 and the mass of the moving particle is m.
The kinetic energy is the difference between the energy of the moving particle and energy of the particle in rest.
[tex]KE=mc^2 - m{_0} c^2=\frac{m{_0} c^2}{\sqrt{1-v^2/c^2}}-m{_0} c^2=m{_0} c^2 (\frac{1}{\sqrt{1-v^2/c^2}}-1)[/tex]
The ratio of the kinetic energy to the energy in rest is
[tex]\frac{KE}{m{_0} c^2} =\frac{1}{\sqrt{1-v^2/c^2}}-1[/tex]
You might have got different result from mine because of the rounding errors.
ehild
1. What is kinetic energy?
Kinetic energy is the energy an object possesses due to its motion. It is defined as half of the mass of the object multiplied by the square of its velocity.
2. How do you calculate kinetic energy?
Kinetic energy can be calculated using the formula KE = 1/2 * m * v^2, where KE is kinetic energy, m is the mass of the object, and v is the velocity of the object.
3. What is a proton?
A proton is a subatomic particle found in the nucleus of an atom. It has a positive electric charge and a mass approximately 1,836 times that of an electron.
4. How do you determine the mass of a proton?
The mass of a proton is approximately 1.67 x 10^-27 kilograms. It can also be measured in atomic mass units (amu), where one amu is equivalent to 1/12th the mass of a carbon-12 atom.
5. What is the significance of calculating the kinetic energy required to accelerate a proton?
Calculating the kinetic energy required to accelerate a proton can help us understand the amount of energy needed to move a subatomic particle at a certain velocity. This information is important in fields such as particle physics and nuclear science.
