Renormalization and counterterms
In summary, the counterterms introduced in renormalized perturbation theory (see e.g. Chapter 10 of Peskin and Schroeder) have no physical interpretation. They are a book keeping device introduced to separate the physically significant renormalization effects from the mess of infinities that arise ultimately from our ignorance of the physics at short scales.
metroplex021
151
Hi all,
Can anyone tell me whether the counterterms introduced in renormalized perturbation theory (see e.g. Chapter 10 of Peskin and Schroeder) have any physical interpretation? In particular, are they taken to model the self-interactions that take us from a 'bare' to a 'dressed' particle?
Thanks a lot!
The counterterms have no physical interpretation. They are a book keeping device introduced to separate the physically significant renormalization effects from the mess of infinities that arise ultimately from our ignorance of the physics at short scales.
In the Lagrangian we have an constant ##\lambda^i_0## multiplying the ##i##-th term of the Langrangian, let's say.
It turns out that, unlike classical physics, this constant is not directly interpretable as a physical coupling or mass, but simply as just a number in the Lagrangian. Rather some related constant ##\lambda^i## would be physically meaningful.
To make calculations easier we split ##\lambda^i_0## into ##\lambda^i_0 = \lambda^i + \delta\lambda##, this allows the physical coupling to be visible from the beginning, rather than being buried in the poles of some correlation function and involving a complicated calculation to extract.
It's also more convenient as ##\lambda^i## is an input to your theory, a value you fix to experiment, so again it is better to have it visible from the beginning. The counterterms are simply the ##\delta\lambda##.
Now all of this would have to be done anyway, even if QFT had no divergences. The interesting thing though, is that it turns out that in many theories, like QED or QCD, the ##\delta\lambda## are essentially the negatives of any divergence in the theory and so cancel them out.
This has nothing to do with ignorance of physics at short scales. The infinities of QFT do not originate from our ignorance of physics at low scales.
I agree with all of the above except the last part. The counter terms are formally infinite in the calculation because the calculation extrapolates QFT to infinitesimally short scales. That extrapolation is not experimentally warranted. It is conceivable (some would say extremely likely) that at some short scale some new physics must be taken into consideration. It is in that sense that the counterterms are sweeping under the rug our ignorance of the short scale physics. In essence we're declaring that this short scale physics has no other observable consequence at the low energy phenomena aside from a few counterterms. Note that this declaration is akin to the requirement that the theory at hand be renormalizable.
True, in fact the counterterms are rigorously infinite, not just formally. This was proven by Kallén years ago for QED for example.
True.
True.
This where I disagree. The counterterms are simply the difference between the constants of the Lagrangian and the physical constants that directly parameterise the theory. Pure Yang-Mills for example is well-defined on all scales. It might be physically incorrect on very short scales, but it still makes sense and makes well-defined (but probably false) predictions on those scales.
I can write down pure Yang-Mills on ##\mathbb{R}^4## and compute its counterterms. There is nothing being swept into them, as I'm only working with pure Yang-Mills, they are simply the computable difference between the bare and physical constants.
Yes, here we have to distinguish asymptotically free theories like QCD (which are believed to exist at arbitrarily small scales) and non-asymptotically free theories (like QED and the full Standard Model) which are believed to require an explicit modification (often referred to as an "ultraviolet completion") at some sufficiently small scale.
Thanks people. So just to be clear: the counterterms do not in themselves model e.g. the vacuum polarization effects that are taken to 'screen' the electron at finite distances and make the charge well-defined?
As explained above, counterterms just correspond to a renaming of parameters in the lagrangian, and this can have no physical, measurable effect.
1. What is renormalization in physics?
Renormalization is a mathematical technique used in theoretical physics to remove divergences or infinities in calculations. It involves adjusting the parameters in a theory to account for the effects of high-energy particles that are not explicitly included in the theory. This allows for more accurate and reliable predictions of physical quantities.
2. Why is renormalization important?
Renormalization is important because it allows for the calculation of physical quantities that would otherwise be infinite or undefined. It also helps reconcile the discrepancies between theoretical predictions and experimental observations, improving the predictive power of a theory.
3. What are counterterms in renormalization?
Counterterms are additional terms added to a theory in order to cancel out the infinities that arise during renormalization. These terms are usually chosen to have the same form as the original terms in the theory, but with different numerical values. They effectively remove the infinities and allow for finite and meaningful results to be obtained.
4. How does renormalization relate to quantum field theory?
Renormalization is a crucial aspect of quantum field theory, as it helps deal with the infinities that arise when attempting to describe the behavior of particles at high energies. Without renormalization, quantum field theory would not be able to accurately describe phenomena at the subatomic level.
5. Are there different types of renormalization?
Yes, there are different types of renormalization techniques, such as perturbative renormalization, dimensional regularization, and lattice regularization. Each technique has its own advantages and is used in different situations, but they all aim to achieve the same goal of removing divergences in calculations.
  • High Energy, Nuclear, Particle Physics
  • Quantum Physics
  • Science and Math Textbooks
  • Quantum Physics
