reflectivity and absorption
by clanx
Tags: absorption, reflectivity
clanx
clanx is offline
#1
Jan23-14, 09:17 AM
P: 5
i was reading papers and also doing my own simulations for a reflectivity experiment. i noticed though that reflectivity peak say at 3eV will correspond to a absorption peak (in the complex dielectric) at about 3eV too.
I'm just confused here because we all know that R + T +A = 1. But yet when R is high, it corresponds to a absorption peak too? what is wrong with my concept?
Phys.Org News Partner Physics news on Phys.org
Chameleon crystals could enable active camouflage (w/ video)
Atomic switcheroo explains origins of thin-film solar cell mystery
X-ray laser experiment explores how specially shocked material gets stronger
Claude Bile
Claude Bile is offline
#2
Jan24-14, 07:05 AM
Sci Advisor
P: 1,465
What you observe is probably a manifestation of the Kramers-Kronig relations, that dictate that an absorption peak (i.e. a peak in the imaginary part of the refractive index) corresponds to an inflection point in the real refractive index (reflectivity).
Claude.
clanx
clanx is offline
#3
Jan24-14, 07:09 AM
P: 5
yes I understand that. but what about the physical picture? say if we happen to have this material with 100% reflection, shouldn't the absorption be 0?
DrDu
DrDu is offline
#4
Jan24-14, 07:36 AM
Sci Advisor
P: 3,376
Some more information would be helpful, e.g., kind of material ...
clanx
clanx is offline
#5
Jan24-14, 07:46 AM
P: 5
the 100% reflection is just a hypothetical case. for the general case I'm referring to can be found on many scholarly articles. here is one I found on Google http://www.scielo.br/img/fbpe/bjp/v29n4/a06f1.gif
you can see clearly that a reflection peak corresponds to a complex dielectric peak at the same energy.
DrDu
DrDu is offline
#6
Jan24-14, 11:53 AM
Sci Advisor
P: 3,376
What makes you think that a large imaginary part of the dielectric constant corresponds necessarily to large absorption?
DrDu
DrDu is offline
#7
Jan24-14, 11:58 AM
Sci Advisor
P: 3,376
This effect is quite easy to observe btw. Make a line with a foil marker on a black sheet of paper or look at some crystals of a dye. The colour you see is the complementary colour of the one seen in transmission.
Reflection is always high when there is a large difference between the refractive indices (whether real or imaginary isn't important). If the imaginary part is high, the light won't enter deeply into the material. However, absorption is nevertheless low, as most light is reflected. In former times, this was exploited to generate monochromatic light in the far IR. It is called Reststrahlen method.
clanx
clanx is offline
#8
Jan24-14, 07:17 PM
P: 5
hmm. because the imag dielectric can also be written as 2nk where k is the extinction coefficient, and the absorption coefficient is directly proportional to the extinction coefficient? is there something wrong with concept?
UltrafastPED
UltrafastPED is online now
#9
Jan25-14, 11:12 AM
Thanks
P: 1,352
You will find a nice introduction here:
http://www.tf.uni-kiel.de/matwis/ama...ne/r3_7_2.html
This goes on for several pages; follow the links at the bottom.
DrDu
DrDu is offline
#10
Jan25-14, 12:16 PM
Sci Advisor
P: 3,376
Quote Quote by clanx View Post
The problem is that this Beer's law only holds if reflection is negligible.
While k describes still extinction, i.e. the weakening of a ray propagating within the medium, if 2nk is high, most light won't even enter the medium because it gets reflected.
This has especially counterintuitive consequences in the case of metals. There, at low frequencies, n is small but k is high. Hence absorption is low although waves are strongly damped. Most of the light is reflected. If absorption rises, reflectivity becomes smaller and thin sheets of metal (like e.g. gold or copper) become partially transparent in the frequency region where they absorb.
Register to reply
Related Discussions
Absorption band and absorption peak? Atomic, Solid State, Comp. Physics 6
what does divergence in the reflectivity mean? Classical Physics 0
Derivation of reflectivity Advanced Physics Homework 0
Why is the mass absorption coefficient used rather than the linear absorption? Advanced Physics Homework 1
reflectivity of copper Advanced Physics Homework 1
