Two coupled harmonic oscillator, damping each other
In summary, the problem is two damped harmonic oscillators with the same natural frequency and damping constant are coupled. The damping force for the first oscillator is proportional to the velocity of the second oscillator, and vice versa for the second oscillator. The goal is to find the positions of both oscillators as a function of time. The equations for the two oscillators are given, and the next step is to add and subtract them to get independent equations in two new variables, X1 and X2.
dperkovic
The problem is:
Two damped harmonic oscillator are coupled. Both oscillators has same natural frequency [tex]\omega_0[/tex] and damping constant [tex]\beta[/tex].
1st oscillator is damped by 2nd oscillator. Damping force is proportional to velocity of 2nd oscillator. And, vice versa, 2nd oscillator is damped by 1st oscillator, by a force proportional to velocity of 1st oscillator.
Find the positions (of both oscillator) as a function of time.
I started with this:
[tex]\ddot{x_1} + \frac{\beta}{m}\dot{x_2} + \omega_0^2(x_1-x_2) = 0[/tex] ! EDITED !
[tex]\ddot{x_2} + \frac{\beta}{m}\dot{x_1} + \omega_0^2(x_2- x_1) = 0[/tex]
Is that O.K. ? If answer is yes ... what is the next step ? I would really appreciate it if somebody could give me just a hint !
Addition and subtraction of the two eqs is a standard practice. This doesn't seem to work here. Check the last term of your eqs - why do you have omega*(x2-x1) in both eqs ?
Ouch ! Mea culpa ! Must be omega*(x1-x2) in first eq !
Do I need to supstitute [tex]x_n[/tex], with standard eq for harmonic oscillator ( [tex]A_n\cos(\omega_n t+\phi_n)[/tex]), before addition and substraction ?
I don't think so.
Adding and subtracting will give you independent equations in two new variables, X1 = x1 + x2 and X2 = x1 - x2. Try to solve these now in X1 and X2.
1. What is a coupled harmonic oscillator system?
A coupled harmonic oscillator system is a physical system consisting of two or more harmonic oscillators that are connected or coupled to each other. This means that the motion of one oscillator affects the motion of the other oscillator, creating a complex and interdependent system.
2. How do two coupled harmonic oscillators dampen each other?
In a coupled harmonic oscillator system, the oscillators are connected through a medium, such as a spring or a pendulum. When one oscillator moves, it exerts a force on the other oscillator, causing it to also move. This exchange of energy between the oscillators eventually leads to a decrease in the amplitude of their oscillations, resulting in damping.
3. What factors affect the damping in a coupled harmonic oscillator system?
The amount of damping in a coupled harmonic oscillator system depends on several factors, including the strength of the coupling, the mass and stiffness of the oscillators, and the properties of the connecting medium. In general, a higher coupling strength and a larger mass or stiffness will lead to more damping in the system.
4. How does the damping affect the frequency of the coupled oscillators?
The damping in a coupled harmonic oscillator system affects the frequency of the oscillators by decreasing it. As the oscillations decrease in amplitude, the restoring force from the medium becomes smaller, resulting in a decrease in the frequency of the oscillations. This decrease in frequency can also be seen as a lengthening of the period of the oscillations.
5. Can two coupled harmonic oscillators reach a state of resonance?
Yes, two coupled harmonic oscillators can reach a state of resonance, where their natural frequencies match and their oscillations become amplified. This can occur even with damping present, as long as the damping is not too strong to completely dampen the oscillations. Resonance in a coupled oscillator system can lead to large and sustained oscillations, which can have practical applications in fields such as engineering and physics.
  • Classical Physics
  • Classical Physics
