Particles in an energy eigenstate not moving?
In summary, the conversation discusses the concept of energy eigenstates and why particles in these states cannot be moving in the classical sense. It is explained that to answer this question, one needs to understand the interpretation of a wavefunction and how it changes with time. The conversation also mentions that this topic may be better suited for the homework forum and offers hints about "stationary states" and their implications for expectation values.
sheelbe999
I'm really struggling with this one guys, the question is:
Explain why a particle which is in an energy eigenstate cannot be moving in the
classical sense.
What you need to know to answer this is a) the interpretation of a wavefunction, and b) how a wavefunction changes with time. (If you know that the state at t=0 is f, then what is it at arbitrary t? f(t)=(something)f, right?).
(This should probably be in the homework forum).
thanks and will move it
henry
Hints: This has to do with "stationary states".
What is a prerequisite for a stationary state? What do stationary states imply for expectation values?
A particle in an energy eigenstate cannot be moving in the classical sense because it is described by a single, well-defined energy level. In classical mechanics, a particle's energy is directly related to its velocity, with higher energy corresponding to higher velocity. However, in quantum mechanics, the energy of a particle is quantized and can only take on certain discrete values.
When a particle is in an energy eigenstate, it means that it has a definite energy value and is not in a state of superposition, where it could have multiple energy values at the same time. This means that the particle's energy cannot change, and therefore, its velocity cannot change either.
Furthermore, the concept of a particle "moving" in the classical sense is based on the idea of a definite position and trajectory. However, in quantum mechanics, the position of a particle is described by a wave function, which gives the probability of finding the particle at a certain position. This means that the particle does not have a well-defined position at any given time, and therefore, it cannot be said to be "moving" in the same way as a classical particle.
In summary, a particle in an energy eigenstate cannot be moving in the classical sense because its energy is quantized and cannot change, and its position is described by a probability distribution rather than a definite trajectory.
1. What is an energy eigenstate?
An energy eigenstate is a quantum state in which the energy of a particle is well-defined and does not change over time. This means that the particle is in a stable, stationary state and is not moving.
2. What does it mean for a particle to not be moving in an energy eigenstate?
In quantum mechanics, particles can exist in states where they have a well-defined energy but no definite position or momentum. In this case, the particle is described as being in an energy eigenstate and is not moving because its position and momentum are uncertain.
3. How are energy eigenstates related to energy levels?
An energy eigenstate is a specific energy level that a particle can occupy. The energy levels of a quantum system are determined by the allowed solutions to the Schrödinger equation, and each energy level corresponds to a specific energy eigenstate.
4. Can a particle in an energy eigenstate change its energy?
No, a particle in an energy eigenstate cannot change its energy because the energy is well-defined and does not vary over time. The only way for the energy to change is for the particle to transition to a different energy eigenstate.
5. How does the principle of superposition apply to particles in an energy eigenstate?
The principle of superposition states that a quantum system can exist in a combination of different states at the same time. For particles in an energy eigenstate, this means that they can exist in a superposition of different energy eigenstates, each with its own well-defined energy value.
  • Quantum Interpretations and Foundations
  • Beyond the Standard Models
