Exploring Normed Linear Spaces: Homework Problems and Solutions
In summary, The question is about the normed linear space \ell_\infty \mathbb({R}) and the elements x, y, and z in this space. It is asked whether x, y, z are each in \ell_\infty \mathbb({R}) and how to calculate their infinity norms. It is also asked to evaluate x+y and 2^{1/2}y. In order to calculate the infinity norm, the supremum of the set needs to be found. For x, the supremum is the smallest number that is greater than or equal to every number in the sequence {0, 1/2, 2/3, 3/4, ..., n/(n+
bugatti79
794
Consider the normed linear space [itex]\ell_\infty \mathbb({R})[/itex]. Let [itex]x= \frac{n-1}{n}[/itex], [itex]y=(1/n) and z=2^n[/itex]
a) Are x,y,z each in [itex]\ell_\infty \mathbb({R})[/itex]
b) What is x+y? What is [itex]2^{1/2} y?[/itex]
c) Calculate [itex]||x||_\infty[/itex], [itex]||y||_\infty[/itex], [itex]||x+y||_\infty[/itex] and [itex]||2^{1/2} y ||_\infty[/itex]
For a) Does that mean are x,y,z subspaces of [itex]\ell_\infty \mathbb({R})[/itex]?
No, x, y, and z are sequences. The question is asking whether they belong to [itex]\ell_\infty \mathbb({R})[/itex].
x and y are each an element in l_∞ as they are bounded above
z is NOT an element as its not bounded above
In b) what does it mean by 'what is'. Is that asking to evaluate?
You could answer b by evaluating x + y, and then saying whether it is in l(R).
bugatti79 said:
1. Homework Statement
x+y =n implies (n) =(1,2,3,4...) which is not in l∞(R) sicne it is not bounded above.
2^(1/2)*y= 2^(n+1/2) which is not in l∞(R) either...?
Yes, but here's how to say the first part better. x + y = {n} = {1, 2, 3, ...}
No, 21/2y = 21/2{1/n}. That means 21/2 times each element of the sequence {1/n}.
Thanks..that was a mistake on my part. So hence it IS in l∞(R)
For c) do I attempt to evaluate each?
Yes and yes.
Your textbook should have a definition of the infinity norm - if not, there's one in the link I posted in the other thread.
Hmm, I get a different result for x+y... :confused:
Let's make that x + y = {1} = {1, 1, 1, ...}
For x:
1-1/n =(0,1/2,2/3,3/4...) and is bounded.
[itex]||1-1/n||_∞[/itex]=...? I am not sure how to calculate this. If some one can illustrate this one, I can try the others...? I know [itex]||1-1/n||_∞=sup |x_n|[/itex] but don't know how to calculate |x_n|
Thanks
Mark44 said:
See http://en.wikipedia.org/wiki/Lp_space, in the section titled Lp spaces, starting with "One also defines the ∞-norm as ...".
I believe that this is the norm to be used in your problem.
THanks Mark but how to I evalute |x_n|?
What is the supremum of the set {0, 1/2, 2/3, 3/4, ..., n/(n + 1), ...}?
I think the supremum is the smallest real number that is greater than or equal to every number in the set, hence t must be 0...?
What do i do next?
Is it something along the lines of
[itex]|1-1/n|=\sqrt{(1-1/n)^2}=0[/itex] where n=1
Yes.
No. 0 is smaller than, not larger than every number in the sequence except the first.
bugatti79 said:
What do i do next?
Mark44 said:
Yes.No. 0 is smaller than, not larger than every number in the sequence except the first.
Then it doesn't exist, there is no sup...?
Yes! So what is the smallest number that is >= each number in the sequence {0, 1/2, 2/3, 3/4, ..., n/(n+1), ...}
No, it can't be 0. This number is too small, because it's not larger than 1/2 (for example). 2589 is larger than all the numbers in the sequence, but can you find one that is not so large?
1 would be greater than or equal to every number in the set...?
a reasonable guess, can you prove it?
Yes. Why are you uncertain?
Although not required in the problem, Deveno's question is reasonable, given the uncertainty in the answer above.
All I know is that |1- 1/n| < 1 but I don't know to prove its 1.
|1 - 1/n| is never 1.
but...perhaps there might be a least upper bound. what are our likely candidates for this office?
What is:
[tex]\lim\limits_{n \to \infty} (1 - {1 \over n})[/tex]
I like Serena said:
What is:
IF n tends to infinity then the modulus tends to 1 but never 1...so does that mean that
||1- 1/n||_∞=sup |1-1/n|=1?
I don't understand your uncertainty either.
I'm just going to say yes, it is 1.
what does:
[tex]\lim_{n \to \infty} f(n) = L[/tex]
mean?
if you have such a limit, and, you know that f(n) < L for all n, what must sup{f(n)} be?
Deveno said:
what does:
mean?
That L is a finte real number and in this case it is a 1.
Deveno said:
what does:
mean?
You didn't answer Deveno's question. He asked, what is sup{f(n)}?
Is it L?
  • #31
bugatti79 said:
Is it L?
Would you be willing to change that to:
It is L!​
(Or else please clarify what is still puzzling you. :confused:)
  • #32
It is L!​
I don't really get "functional analysis"...but I will battle on anyway :-) Thanks
  • #33
So to go back to what you were trying to figure out much earlier in this thread, the infinity norm of x, where x = {1 - 1/n}, ||x|| = [itex]\lim_{n \to \infty}(1 - 1/n)[/itex] = 1.
1. What is a normed linear space?
A normed linear space is a mathematical concept that combines the properties of a vector space and a metric space. It is a vector space equipped with a norm, which is a function that assigns a length or size to each vector in the space. This allows for the concept of distance between vectors, similar to a metric space, and also allows for the use of algebraic operations, similar to a vector space.
2. How is a norm defined in a normed linear space?
A norm in a normed linear space is defined as a function that satisfies three properties: positivity, homogeneity, and the triangle inequality. Positivity requires that the norm of a vector is always a non-negative value. Homogeneity requires that scaling a vector by a constant also scales its norm by the same constant. The triangle inequality states that the norm of the sum of two vectors is less than or equal to the sum of their individual norms.
3. What are some examples of normed linear spaces?
Some examples of normed linear spaces include Euclidean spaces, function spaces, and sequence spaces. Euclidean spaces, such as R^n, are familiar vector spaces equipped with the Euclidean norm. Function spaces, such as L^p spaces, are spaces of functions equipped with different types of norms. Sequence spaces, such as l^p spaces, are spaces of sequences equipped with different types of norms.
4. How are normed linear spaces useful in mathematics?
Normed linear spaces are useful in mathematics because they provide a framework for studying vector spaces with the added concept of distance. This allows for the use of tools and techniques from both vector spaces and metric spaces, making it a powerful tool for solving problems in various fields such as functional analysis, optimization, and differential equations.
5. How can "Exploring Normed Linear Spaces: Homework Problems and Solutions" help with understanding this topic?
"Exploring Normed Linear Spaces: Homework Problems and Solutions" is a resource that provides a collection of problems and solutions related to normed linear spaces. By working through these problems, readers can gain a better understanding of the concepts and techniques involved in this topic. It also provides a way to practice and apply the material in a structured and organized manner, making it a valuable tool for students and researchers alike.
