Writing three-fold summation over n_x, n_y, n_z as single summation over n?
Next, we can use the second identity to rewrite the double summation:\sum_{n_x} \sum_{n_y} e^{-cn_x^2} \cdot e^{-cn_y^2}= \left(\sum_{n_x} e^{-cn_x^2}\right
PerUlven
On http://www.chem.arizona.edu/~salzmanr/480b/statt02/statt02.html they're going from a three-fold summation to a single summation (cubed) (equation 58-59), something like this:
[itex]
\sum_{n_x} \sum_{n_y} \sum_{n_z} e^{-a\left(n_x^2 + n_y^2 + n_z^2\right)} = \left( \sum_n e^{-an^2} \right)^3
[/itex], where [itex]a = \frac{h^2}{8kTmL^2}[/itex]
Now, I've run into a similar problem, only I have the square root of the n's, like this:
[itex]
Z = \sum_{n_x} \sum_{n_y} \sum_{n_z} e^{-c\sqrt{n_x^2 + n_y^2 + n_z^2}}
[/itex], where [itex]c = \frac{hc}{2kTL}[/itex]
Could anyone show me how they do the first transition, or some hints to how I should start when trying to do a similar transition on my equation? I'm supposed to show that the sum equals
[itex]
Z(\text{high T}) = 8\pi L^3\left(\frac{kT}{hc}\right)^3
[/itex]
in the high-temperature limit. I know that I can approximate the sum with an integral, but I need to convert it to a single-sum first.
[itex]
\sum_{n_x} \sum_{n_y} \sum_{n_z} e^{-a\left(n_x^2 + n_y^2 + n_z^2\right)} = \left( \sum_n e^{-an^2} \right)^3 = \left(\int_0^\infty e^{-an^2} dn\right)^3
[/itex]
[itex]
\int_0^\infty e^{-ax}dx = \frac{1}{a}
[/itex]
[itex]
\int_0^\infty e^{-ax^2}dx = \frac{1}{2}\sqrt{\frac{\pi}{a}}
[/itex]
I've tried letting [itex]\sqrt{n_x^2+n_y^2+n_z^2} = n[/itex], but then I end up with just [itex]n[/itex] and not [itex]n^2[/itex] in the exponent, and then I don't get the factor [itex]\pi[/itex] when solving the integral (see the two last equations for solutions to the integrals).
I might be going at this problem all wrong, so I'm open to all suggestions!
EDIT: Just found the solution myself. I'll show it in detail if anyone wants it, just ask and I'll write it out here.
Thank you for bringing this interesting problem to our attention. I am always excited to see others exploring and learning about mathematical concepts.
I have looked into the problem you mentioned and I believe I have found a solution that may help you. First, let's recap what we know:
We have the following equation:
, where c = \frac{hc}{2kTL}
And we want to show that in the high-temperature limit, this equation becomes:
To do this, we will use the following identities:
1. \sum_{n=1}^\infty e^{-an^2} = \frac{1}{2}\sqrt{\frac{\pi}{a}} \text{ (from integral identity 2)}
2. \sum_{n=0}^\infty e^{-an^2} = \frac{1}{2}\sqrt{\frac{\pi}{a}} \text{ (from integral identity 1)}
Now, let's start by rewriting the original equation:
= \sum_{n_x} \sum_{n_y} \sum_{n_z} e^{-c\sqrt{(n_x^2 + n_y^2 + n_z^2)^2}}
= \sum_{n_x} \sum_{n_y} \sum_{n_z} e^{-c(n_x^2 + n_y^2 + n_z^2)}
= \sum_{n_x} \sum_{n_y} \sum_{n_z} e^{-c(n_x^2 + n_y^2 + n_z^2)} \cdot e^{-c(n_x^2 + n_y^2 + n_z^2)}
= \left(\sum_{n_x} \sum_{n_y} \sum_{n_z} e^{-c(n_x^2 + n_y^2 + n_z^2)}\right)^2
Now,
What is a three-fold summation?
A three-fold summation is a mathematical notation used to represent the sum of a function over three variables, typically denoted by n_x, n_y, and n_z. It is similar to a regular summation, but involves multiple variables.
How is a three-fold summation written?
A three-fold summation is typically written as a single summation over n, where n represents the three variables (n_x, n_y, n_z). This notation is used to simplify the expression and make it easier to work with mathematically.
What is the purpose of using a three-fold summation?
Three-fold summations are commonly used in scientific and mathematical fields to represent the sum of a function over multiple variables. They are particularly useful in situations where the function being summed is dependent on three or more variables.
How do you evaluate a three-fold summation?
To evaluate a three-fold summation, you would first substitute the values of n_x, n_y, and n_z into the function being summed. Then, you would simplify the expression by combining like terms and performing any necessary calculations.
Can a three-fold summation be written as a single summation over a different variable?
Yes, a three-fold summation can be written as a single summation over a different variable, as long as the new variable represents the same three variables (n_x, n_y, and n_z). This may be done for simplicity or to match the notation used in a particular field of study.
  • Quantum Physics
  • Quantum Physics
