I don't understand how to calculate leg3 for x3? ?
  • Thread starter amyparker30
In summary, the rocket sled travels along a straight line and undergoes three different legs of motion. In leg 1, it accelerates at 50m/s2 for 5.0s, reaching a velocity of 250m/s and traveling a distance of 625m. In leg 2, it coasts for 3.0s while maintaining a velocity of 250m/s and travels an additional distance of 750m. In leg 3, the rocket deploys a braking parachute and decelerates at 3.0 m/s2 until coming to a halt, covering a distance of 10416.67m in 83.3 seconds. Therefore, the maximum velocity of the rocket sled is
amyparker30
A rocket sled travels along a straight line. It accelerates at 50m/s2 for 5.0s coasts for 3.0s, then deploys a braking parachute and decelerates at 3.0 m/s2 until coming to a halt. The motion occurs in three different legs.
1. Leg 1:
a. Which type of motion is it?
b. Write the expressions of ?x1 and v1, functions of the time .
c. Calculate ?x1 and v1 at the end of leg 1.
2. Leg 2.
b. Write the expressions of ?x2 and v2 , functions of the time .
c. Calculate ?x2 and v2 at the end of leg 2.
3. Leg 3:
b. Write the expressions of ?x3 and v3, functions of the time.
c. Calculate ?x3 and v3 at the end of leg 3.
4. What is the maximum velocity of the rocket sled?
5. What is the total distance traveled?
x1 = 1/2a*t^2 v1 = a*t
x2 = v2*t v2 = v1
x3 = 1/2a*t^2 + v*t v3 = a*t + v
I just don't know how to get LEG3 x3, i know that v3 is zero because the rocket comes to a halt.
amyparker30 said:
x3 = 1/2a*t^2 + v*t
v3 = a*t + v
Welcome to physics forums.
What are the known variables here, and what is the value for each?
the values for acceleration and time are given in the question.
i don't know how to calculate x3 using the equations provided?!?
If that is true, then I was hoping to see your answer. You have the right equations, but just haven't noticed how to use them.
okay for leg 1 my calculations are:
v1=250 m/s
x1=625m
for leg 2 my calculations are:
v2=v1=250m/s
x2=750m
i don't know how to do leg 3 but i know v3=0m/s
Hi amyparker30! :smile:
Since you know that v3 is zero, can you use the equation v3 = a*t + v to find the corresponding t?
Afterward you can fill in t in the equation x3 = 1/2a*t^2 + v*t.
okay so v3 = a*t + v
which is 0= -3(because deceleration) t +250
t=83.3 seconds
using equation (please IS THIS CORRECT)
x3= 1/2 (-3) (83.3)^2 + 0
x3= 10408.35m
t=83.3 seconds
Yep.
x3= 10408.35m
As you can see, your minus sign is off.
In this formula v is your initial speed, which is 250 m/s.
So it should be:
x3= 1/2 (-3) (83.3)^2 + (250) (83.3)
Apparently you've mixed it up with an alternative method, which we'll get to in a moment if you're interested.
so according to
x3= 1/2 (-3) (83.3)^2 + (250) (83.3) my answer for leg 3 is 10416.6667m?
and therefore What is the total distance traveled? = x1+x2+x3
= 625 + 750 + 10416.67
=11791.67m for total distance travelled?
Right! :)
if this is correct,, thank you so much for you help!
What is leg3 for x3?
Leg3 for x3 is the length of the third side of a right triangle, where x3 is one of the other two sides.
How do I calculate leg3 for x3?
To calculate leg3 for x3, you can use the Pythagorean theorem, which states that the square of the length of the hypotenuse (the longest side of a right triangle) is equal to the sum of the squares of the other two sides. So, you can use the formula c = √(a² + b²) to find the length of leg3.
What information do I need to calculate leg3 for x3?
To calculate leg3 for x3, you will need to know the length of the other two sides of the right triangle, x1 and x2. You can also use the angle measurements of the triangle if they are provided.
Can I use a calculator to find leg3 for x3?
Yes, you can use a calculator to find the square root of the sum of the squares of x1 and x2 to calculate leg3 for x3.
Why is it important to know how to calculate leg3 for x3?
Knowing how to calculate leg3 for x3 is important in many applications, such as in construction, engineering, and navigation. It allows you to find the length of a missing side in a right triangle, which is a fundamental concept in mathematics and science.
  • MATLAB, Maple, Mathematica, LaTeX
